Behringer EP4000 breaker poping... - AVS Forum | Home Theater Discussions And Reviews
post #1 of 38 Old 03-28-2012, 05:33 PM - Thread Starter
Fatshaft's Avatar
Quoted: 591 Post(s)
Liked: 909
I'm hoping someone can help me out.
All of a sudden the breaker on the back of the EP4000 popped.
The music level was very low.
Now every time I turn the EP4000 on, the breaker in the back of the EP4000 pops. When I turn on the EP4000 it hums for less than a second and pop goes the breaker.
What can be causing it to trip.
I disconnected everything but the power cord and still pops.
The knobs in the front are at 0 when I turn it on and pop!
The EP was barely hot.
My Build Thread
Equipment Speakers:
3x 1099's for LCR duty
4x Fusion 8's for surround duty
8x subs: 4x FTW21's and 4x SI18's
Fatshaft is offline
post #2 of 38 Old 03-28-2012, 08:14 PM
michaelddd's Avatar
Quoted: 326 Post(s)
Liked: 209
You've done some good troubleshooting so far by disconnecting everything but the power cord. What was the amp doing at the time of the first shutdown? I.E. were you watching a movie at full blast? Playing test tones? Do you/did you smell any burning coming from the amp? How old is the amp? The EP4000 is a solid, old-school, lead-sled. It's possible something inside just upped and died, but more probable that an external influence may have damaged or killed it. What was plugged into it? Ohm load? Have you tested that speaker? Maybe the amp fried the voicecoil in whatever it was powering and the protection circuitry didn't act in enough time to save the amp. I'm just guesing here. There are many things that could've gone wrong. More info will help with the diagnosis.
michaelddd is offline
post #3 of 38 Old 03-28-2012, 09:02 PM
BassThatHz's Avatar
Quoted: 2386 Post(s)
Liked: 2161
The bad news is, the amplifier is broken and needs repairing or replacement.
A working speaker is a closed circuit (i.e it conducts electricity).
When they blow, the circuit is opened in 99.999% of the cases and nothing more.
There is only one thing worse for an amplifier than a closed-circuit, a direct short-circuit.
Amplifiers actually like open-circuits.
So unless the coil fused in a direct path across the coil or same within the filter electronics (highly unlikely), then it is unlikely that the speaker failing cause the amp any harm.
Assuming the terminals haven't been shorted from loose wiring or liquid poured into it...
The only other thing that amplifiers don't like is excessive heat, or power surges from the powerline or excessive power flow through the device from heavy usage.
Beyond that it simply had a general component failure, independant of the actual usage of the device; bad Quality-Control perhaps.
BassThatHz is offline
post #4 of 38 Old 03-28-2012, 09:06 PM
WiSounds's Avatar
Complete shot in the dark here, but it may be a shorted output transistor. Maybe one let go and now the rails are shorting tripping the breaker.
Originally Posted by Bill Fitzmaurice:
It's also the very sort of Voodoo Engineering that should never be done.
WiSounds is offline
post #5 of 38 Old 03-29-2012, 04:12 AM - Thread Starter
Fatshaft's Avatar
Quoted: 591 Post(s)
Liked: 909
The amp was connected to 4x MFW-15, 2 ohms per channel.
I was listening to music at very low volume and it just popped.
I let it cool down overnight (it wasn't even hot when it happened) connected it this am and it popped again immediately.
I now my speakers are OK cause I then connected them to a BASH plate amp 500 and continued listening to music yesterday night with no problems at all.
Who do I call to try and get it fixed? I'm in Canada
It's only a year old and have not used it the last 8 months cause I'm redoing my Home Theatre.
I can't believe it failed already.
My Build Thread
Equipment Speakers:
Fatshaft is offline
post #6 of 38 Old 03-29-2012, 07:45 AM
laugsbach's Avatar
Quoted: 169 Post(s)
Liked: 223
This is what the repair guy said happened to my EP-4000...
Originally Posted by Fatshaft View Post
Who do I call to try and get it fixed? I'm in Canada.
Sorry to hear about your amp Fatshaft. I had the exact same problem. I started with the Behringer web-site and really didn't find much help in my area. Next, I searched for Amp Repair and located a guy in my home town who worked on Behringer Guitar Amps and music equipment.
I am in for $180 bucks to repair my unit...
laugsbach is offline
post #7 of 38 Old 03-29-2012, 08:27 AM
beastaudio's Avatar
Quoted: 4152 Post(s)
Liked: 3514
I didnt think it was good to run the ep4k at 2 ohm stereo either???
beastaudio is online now
post #8 of 38 Old 03-29-2012, 12:28 PM
michaelddd's Avatar
Quoted: 326 Post(s)
Liked: 209
http://www.behringer.com/assets/EP2000_P0A38_M_EN.pdf
The EP4000 is rated down to 2 ohms per channel, stereo, but it's never a good idea to run an amp at the limit all the time. At 2 ohms stereo, loud passages will require the amp to process huge amounts of current. And while the EP series are very reliable workhorses, they're no $20K touring company PA amp. Most probably, some output devices got fried due to too low of an ohm load/too much current.
The EP4000 is stupid cheap for how much power it puts out. I'd have bought two and paralleled two subs, mono on each amp for a 4-ohm mono load. Should be able to do that all day long.
post #9 of 38 Old 03-29-2012, 03:24 PM - Thread Starter
Fatshaft's Avatar
Quoted: 591 Post(s)
Liked: 909
I don't understand your logic here.
If I parallel 2 subs that would give me 2ohm load.
Sorry just trying to understand.
I'm upset that it let go on me already...I used it only 6 months out of the year cause the other 6 months it sat in it's box cause I was redoing my HT Room.
PLUS, I called the store I bought it from... I bought it on March 12th last year and they don't want to honor the warranty cause it's past a few days!
Anyway I had already done the fan swap thingie so I'm sure it would've voided the warranty.
Does anyone have any used EP2500 or EP4000 to sell me?
I'd like to buy 2 of them.
I'll connect my subs in series and drive them bridged on a 8ohm load.
Thanks all
My Build Thread
Equipment Speakers:
Fatshaft is offline
post #10 of 38 Old 03-29-2012, 04:45 PM
michaelddd's Avatar
Quoted: 326 Post(s)
Liked: 209
That totally blows that they won't honor the warranty at only two weeks past the expiration date. That's just bad business. Two MONTHS, sure. But a couple of weeks, for a cheap product...it's not worth losing business over. Which I'm hoping they've LOST with you. I wouldn't go back there.
I guess I should've worded it more accurately. Your subs are 4 ohm, not 8 ohm, correct? My bad.
You could connect two subs in series for an 8-ohm load. Do that with the other pair as well. Now you have two 8-ohm loads. Run those in parallel, in mono on the amp for a 4-ohm load. You'd be sharing 2,400 watts b/t the four drivers...nothing to sneeze at by any means.
Now, this series/parallel wiring isn't optimal but it's done all the time and would work just fine.
post #11 of 38 Old 03-29-2012, 04:50 PM
N8DOGG's Avatar
Quoted: 1116 Post(s)
Liked: 1218
Just take it to a electronics shop and have them fix it. I have 8 ep's and they've never been turned off in 5 years. Running perfect, your situation sucks but yours, is not the norm with the ep line.
N8DOGG is offline
post #12 of 38 Old 03-29-2012, 05:42 PM
BassThatHz's Avatar
Liked: 2161
I've put 800 hours on my EP4k in 4-ohm bridged (or dual 2-ohm) and it does just fine; sounds like you got a lemon.
post #13 of 38 Old 03-29-2012, 05:58 PM
michaelddd's Avatar
Quoted: 326 Post(s)
Liked: 209
I have an EP4000 that I've run for two years with a small DJ setup. It drives two crappy 18" ported subs, 8 ohms per channel. The drivers are Neos and very efficient so they don't need a ton of power. True, it's no real "load test" but I've pounded that amp outdoors in 105-degree ambient heat and it's never given me a lick of trouble. See what it would cost to fix. If it's less than half the cost of buying a new one, fix it. That's what I'd do.
post #14 of 38 Old 03-30-2012, 10:31 AM
rlj5242's Avatar
Quoted: 59 Post(s)
Liked: 49
My EP-2500 did the same thing. It was a few months past warranty and I had done the fan mod but the fan wasn't turning on reliably. Probably my fault. So I called the closest authorized repair facility in St. Louis. I explained my situation and he said it would be cheaper to buy a new one. I did.
I kept the old one in case I found a good repair place. Turns out there's a guy near me that fixes blown amps as a hobby. His normal expertise are Memphis Audio and other, similarly designed car amps. After chatting about a Memphis amp he was fixing for me, I mentioned my Behringer. He said he had been looking for a pro amp to learn how to fix. Well, it took him a few weeks to trace the problem down to a few blown MOSFETS on the output side of one channel. He replaced them and it now works. It was only a few dollars worth of parts but I "tipped" him an extra $20. He learned on my amp and I have a repaired amp. We both came out ahead.
Long story to get to this - he will happily fix these at a reasonable cost but I'm sure the shipping to Memphis would be a LOT for you Canadian guys.
rlj5242 is offline
post #15 of 38 Old 03-30-2012, 11:02 AM
A9X-308's Avatar
Quoted: 1506 Post(s)
Liked: 1142
And in doing this, each channel is effectively driving a 2 ohm load.
“You are not special. You are not a beautiful and unique snowflake.” Chuck Palahniuk
A9X-308 is offline
post #16 of 38 Old 03-30-2012, 12:01 PM
exojam's Avatar
Liked: 33
A9X,
I wonder if he actually meant in say run it in bridged mode for the 4 ohm load (just using the word mono instead of bridged).
James
exojam is offline
post #17 of 38 Old 03-30-2012, 12:15 PM
A9X-308's Avatar
Liked: 1142
Originally Posted by exojam View Post
A9X,
James
It doesn't work any other way: two 4R in series, to get 8R. Two lots of that wired in parallel gets 4R. In mono/bridged you have a net 4R load. One pair on each channel has an 8R load/ch.
Paralleling a pair of 4R drivers/ch gets a 2R/ch load. There aren't any other combinations. So criticising a 2R/ch load and then advising a 4R bridged load makes no sense as they are functionally identical.
Edit: EP2500 spec is 2400W, 4R bridged.
A9X-308 is offline
post #18 of 38 Old 03-30-2012, 12:24 PM
exojam's Avatar
Liked: 33
A9X,
I cannot disagree with your information but where did the criticising part come into play?
James
exojam is offline
post #19 of 38 Old 03-30-2012, 12:38 PM
A9X-308's Avatar
Liked: 1142
A9X,
James
Post 8.
"The EP4000 is rated down to 2 ohms per channel, stereo, but it's never a good idea to run an amp at the limit all the time. At 2 ohms stereo, loud passages will require the amp to process huge amounts of current."
A9X-308 is offline
post #20 of 38 Old 03-30-2012, 12:39 PM
exojam's Avatar
Liked: 33
Post 8.
Fare enough.
James
exojam is offline
post #21 of 38 Old 03-31-2012, 06:14 AM - Thread Starter
Fatshaft's Avatar
Quoted: 591 Post(s)
Liked: 909
Just wanting to give you all a n update:
Yesterday I called the music store where I bought the EP4000 to complain abit.
I told them that my order was placed on the 12th of March 2011.
They shipped my amp on the 15th.
Delivered to my door on the 21st of March 2011.
I used the amp till end of July...put it back in the box till a week ago because I am redoing my HT Room. I did not use this amp for almost 8 months! I Explained all this to the guy.
They 1st came back and said sorry can't help you. Naturally I told him that I was extremely disappointed and he then came back and said he will talk to his Behringer rep next week and see what they can do.
I also told him that I want to purchase another amp and will not if they don't warranty my unit for just being a couple days over a year.
Anyone have any experience with Behringer?
Are they reasonable with this stuff?
Thanks all...
My Build Thread
Equipment Speakers:
Fatshaft is offline
post #22 of 38 Old 04-02-2012, 03:45 PM - Thread Starter
Fatshaft's Avatar
Quoted: 591 Post(s)
Liked: 909
Well Monday has come and gone now and did not hear from them yet.
They did say Monday or Tuesday!
I'll keep this thread updated in case further down the line someone searches.
I hope Behringer comes through and replaces my unit.
My Build Thread
Equipment Speakers:
Fatshaft is offline
post #23 of 38 Old 04-02-2012, 06:54 PM
FOH
FOH's Avatar
Quoted: 39 Post(s)
Liked: 236
I'd never recommend 2 ohm operation, yes, many enjoy years of no issues.
2 ohm operation may easily encounter even more demanding loads at certain frequencies. Over time, the design just isn't robust enough to endure.
Like nearly all of us here, I've read a great deal of posts regarding the Berry EP2.5/4k. Many stories just like this one. It's a great amp for the money,...I own two EP4000's.
When asked, I always say the same thing;
Never operate into two ohm loads
Never mod the thermal capability
Good luck
Active 16.8kw, 7.3 system
(2)Seaton SubM-HP, (4)18" IB
FOH is offline
post #24 of 38 Old 04-04-2012, 12:27 AM
omegaslast's Avatar
If behringers shouldnt be run at 2ohm stereo/4ohm bridged then that means that you have to run their inuke 6000 at 8ohms on each channel. With most DIY drivers its very hard to present an 8ohm load, especially to each channel...
omegaslast is offline
post #25 of 38 Old 04-04-2012, 12:37 AM
gperkins1973's Avatar
I run two ohms stereo and although have only tripped the fuse twice with low bass stuff, wouldnt again.
gperkins1973 is offline
post #26 of 38 Old 04-04-2012, 01:21 AM
A9X-308's Avatar
Liked: 1142
Agreed.
Agreed. Ensure you replace the fans with the same or better CFM capacity.
A9X-308 is offline
post #27 of 38 Old 04-04-2012, 02:43 PM - Thread Starter
Fatshaft's Avatar
Quoted: 591 Post(s)
Liked: 909
Well,
I feel obliged to let everyone know...
Tuesday and Wednesday has come and gone...no call back from my store where I purchased my unit.
So here's the info:
I'll never buy again through them just for this. A few "days" out of warranty and they won't help me? no more business from me...period.
The store is Tom Lee Music in Canada...
I called and spoke with 3 different sales people and none can help me.
This tells me they just don't care
So, today I brought my unit in to a service store near my place and will see how much it costs to get fixed.
will let you know what they say.
sorry for the rant
PS. I'm looking to buy another amp...either a EP2500 or EP4000. Does anyone know where I can purchase one at a good price? New or used
thank you
My Build Thread
Equipment Speakers:
Fatshaft is offline
post #28 of 38 Old 04-04-2012, 02:56 PM
FOH
FOH's Avatar
Quoted: 39 Post(s)
Liked: 236
NewEgg would be about the cheapest shipped.
All the others are about the same, at about $20-$30 more. Since they're all so close, I'd buy from whichever retailer you would prefer reputation wise.
I always get Muscians Friend, Guitar Center, etc., e-coupons emailed to me. I bought one thru Parts Express the last time, merely because I like the way they do business.
Good luck
FOH is offline
post #29 of 38 Old 04-12-2012, 04:04 PM - Thread Starter
Fatshaft's Avatar
Quoted: 591 Post(s)
Liked: 909
UPDATE!
Tom Lee Music just called me to say that Behringer will honor the warranty and fix my EP4000 amp!
I'm completely surprised I got a call back.
I brought my unit to a qualified technician and after spending a little over an hour with the unit...all the transistors on one channel was blown!
He said it wasn't worth fixing it and also said he did not want to fix it!
I'm totally impressed Behringer stepped up to the plate and have offered to fix my unit under the warranty.
They are supposed to send me a local address here in Montreal to get it fixed. Will keep this thread posted.
My Build Thread
Equipment Speakers:
Fatshaft is offline
post #30 of 38 Old 04-12-2012, 04:23 PM
WiSounds's Avatar
Very nice.
WiSounds is offline
