Question about wiring in DIY SUb - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 04-06-2012, 10:31 AM - Thread Starter
anarkhia's Avatar
Hi every!, Hope you can answer my interrogation I recently purchased that.
http://www.edesignaudio.com/product_...roducts_id=849
which is
http://www.edesignaudio.com/product_...roducts_id=891
I built the whole thing and it doesnt seem to play at normal level, i use the behringer 4000 amp. I used 16 gauge normal speaker wire to wire everything up, is it the problem? do i need stronger wire? what is max watt a 16 gauge speaker wire can handle?
inside sub the wire are all 16 gauge speaker wire hook like this plan :
http://www.edesignaudio.com/wiring/2...esparallel.jpg
From the sub, it is speaker wire 16 gauge to the amp. The amp get signal from my receiver using a RCA to XLR wire ( pre out from receiver to the Imput 1 In from amp)
The speaker wire used are these:
http://www.knukonceptz.com/productMa...?category=Kord Speaker Wire
Do you use special wire when you make your own subs?
P.S : i know the woofer are ok since i can hear TV when plugging directly from my receiver using left tower outs ( at very very very low volume, like if there isnt enough power to drive them, my receiver is 100 wpc) Also, if i turn the gain to max on my behringer the Distortion light up, I think wire cant carry the power, am i allright?
anarkhia is offline
post #2 of 11 Old 04-06-2012, 10:51 AM
Bill Fitzmaurice's Avatar
Liked: 5684
16 ga is fine. Use this calculator to determine gauge requirement:
http://www.bcae1.com/images/swfs/spe...rassistant.swf
You may have something wrong with your amp connection, not unusual when you mix consumer and professional gear.
Bill Fitzmaurice is offline
post #3 of 11 Old 04-06-2012, 10:54 AM - Thread Starter
anarkhia's Avatar
God i'm out of idea... if its not the wire i dont know what it is
is it the same with home theater subs?
anarkhia is offline
post #4 of 11 Old 04-06-2012, 12:38 PM
Mrkazador's Avatar
Quoted: 262 Post(s)
Liked: 390
Are those dual 2 or dual 4ohm drivers?
You may need to get a rca/xlr active converter to boost the signal. One such device is the mic2200 from Behringer
http://www.behringer.com/EN/Products/MIC2200.aspx
Mrkazador is offline
post #5 of 11 Old 04-06-2012, 01:34 PM - Thread Starter
anarkhia's Avatar
they are both 2ohm and 4 ohm depending
http://www.edesignaudio.com/product_...roducts_id=554
There was a 4ohm sticker on mines, so i assume they are 4ohm. If i understand you, i need something between my receiver preout and amp to boost the signal?
anarkhia is offline
post #6 of 11 Old 04-06-2012, 01:40 PM
Mrkazador's Avatar
Quoted: 262 Post(s)
Liked: 390
http://www.the12volt.com/caraudio/wo...2&I=42#results
They should be wired in series/parallel to get a 4ohm load.
I'm not an expert in pro amps and receivers but if the volume is not loud enough then you probably need a booster.
post #7 of 11 Old 04-06-2012, 01:42 PM
Liked: 5684
That's a lot of coils to wire, and a single error would severely compromise the result.
post #8 of 11 Old 04-06-2012, 02:07 PM - Thread Starter
anarkhia's Avatar
Yes exactly, you can see how they are wired in the first post.they are in series/parallel. I think the signal needs to be 2-3 times stronger. Right now if i crank up the Behringer at max and play movie at -40 or -50 below reference lvl i can her the sub from the sofa, but it plays way less noise than my towers, and Xovered at 150...
Also i tried to wire RCA to 1/4 and RCA to XLR. With the 1/4 i get no sound at all... with the XLR i get sound. It's something in the wire signal, hope i'll find out with all your help
anarkhia is offline
post #9 of 11 Old 04-06-2012, 02:13 PM - Thread Starter
anarkhia's Avatar
What you mean by boosting signal. I can plug my RCA on the input, boost signal with the output DB and the signal out will be XLR balanced?
anarkhia is offline
post #10 of 11 Old 04-06-2012, 02:14 PM
Mrkazador's Avatar
Quoted: 262 Post(s)
Liked: 390
RCA to XLR should be wired like this
post #11 of 11 Old 04-06-2012, 10:05 PM - Thread Starter
anarkhia's Avatar
hmm maybe that's why i only get half sound imput about... But there's only one out on my receiver.
anarkhia is offline
