Another day of projects. Do I have a thread for you! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 23 Old 04-08-2012, 04:16 PM - Thread Starter
WiSounds's Avatar
Considering the number of drivers I brought back with me from my Sundown visit, I knew I had some work ahead of me:
I'm compiling pictures, this will take a bit.
Originally Posted by Bill Fitzmaurice:
It's also the very sort of Voodoo Engineering that should never be done.
WiSounds is offline
post #2 of 23 Old 04-08-2012, 04:17 PM - Thread Starter
WiSounds's Avatar
I finished the day by completing a project from last year. I FINALLY loaded the first 21" enclosure I built. I had a problem though, which driver to use?
The 18Sound 21LW1400 or B&C 21SW152-4?
Some comparisons, and yep that is an LMS-R 12":
I added the terminal dish and wiring:
Then drilled for the T-Nuts. I use a spade bit to set up a bit of a center punch after the hole layout.
I then had to make a decision on which driver. When the drivers were clamshelled together, the mounting pattern lined up but the B&C frame required a bit larger of a cutout. I used the B&C to layout the holes because it centered better, and it turned out the 18Sound didn't fit when I was done. That will make up your mind I guess. So I loaded her up.
I have the show coming up on Saturday the 14th, and it turns out the SoloX and Zv3 18" are going to be used in the main room and this B&C 21" will now hold down the second room so I transferred the grill from the other cabinet to protect it. I'm debating on running it with the KLR-2000 to leave the KLR-3200s for the Zv3 and SoloX in the main room.
I also got the vacated 21" cabinet ready for the Zv3 18" this weekend.
WiSounds is offline
post #3 of 23 Old 04-08-2012, 08:41 PM
JimWilson's Avatar
Quoted: 1532 Post(s)
Liked: 2037
I sense the word "pulverizing" in your future...
If you take yourself too seriously, expect me to do the exact opposite
JimWilson is offline
post #4 of 23 Old 04-08-2012, 09:19 PM
Maxjr's Avatar
This is gonna be great! I'm looking forward to this
Maxjr is offline
post #5 of 23 Old 04-09-2012, 12:02 AM - Thread Starter
WiSounds's Avatar
I have all 3 environments covered with my projects, Car Pro and Home. I will be able to evaluate performance of all lines except the Nightshade SPL driver. After seeing the operation I am pretty stoked about these drivers.
First thing I did today was to swap out the 4 JL 12w0 in my car with 4 SD-2 12". I needed a shallow driver with more motor to fit in a compact box in a convertible trunk. The box is 2.5ft3, generously stuffed. They run series parallel into a 1ohm mono load on a Kicker XS100, sharing approximately 1250w for the set. I did the swap at the office in PA, then had the 3hr drive home to figure out what these drivers are made of.
JL's:
Comparisons:
Mounting:
Wiring:
There was a difference expected as the JLs don't have enough motor for that small of an enclosure, but damn. These subwoofers are the real deal. Gobs of output and accuracy. Even with the top down the subbass had the engaging balanced quality I have always been lacking with my prior implementations. The first pair of JL 10w3v3 were great sounding but lacked the output levels, the 12w0s had the output but lacked the displacement and motor to render the real low stuff. These SD-2 are just plain nasty, I actually turned off the Yankees game in order to listen to more music. Complete success.
Next up was an interesting idea for the SD-2 10". We use Triad in-wall subwoofers in some of our multi room systems, and after discussion of a planned implementation, Triad didn't like the idea of feeding one of these subs 500w. They recommended 100w max. That simply won't do. Since there was a 10" SD-2 model, I figured it was worth a shot to upgrade the driver to something a bit more robust. There is no direct indication of what 10" is in this cabinet, but once I took it apart I had a pretty good idea.
Factory:
Glimpse of the future:
Comparison:
The factory driver is a dead ringer for the peerless XLS 10". 2"VC 150w RMS, Qts of .17. Interesting choice for small sealed if so.
The primary differences are depth, magnet size, and cabinet protrusion:
The whole thing could be for naught, with a quick flip of the tape measure it is determined to be VERY close but dooable:
The cabinets are well assembled and finished MDF, with soldered leads and T-Nuts to mount the driver:
First step is to temporarily remove the blocks of high density foam filing the enclosure:
So I go to plunk in the driver and whoops:
Flip it over to verify cutout and mounting pattern to find that it doesn't line up, we'll deal with this later:
First is removal of a bit of brace material, time to make a mess:
That wasn't quite enough, so MORE MORE MORE:
Seems we still have a bit of trouble:
Your turn there other brace:
Close, but yet no cigar:
When in doubt, just remove more:
Winning!
Seal and wire:
Done!
I haven't yet hooked this up, but I will for sure in the next couple of days. The brace removal is rough looking, but this is the first one I have had to do. I may have 20 more in a few months for one install. More conclusions on this one later.
Next up is the WiEasy sub getting loaded with an 18" Zv3. This is going to resume duty as my studio/movie sub in my room. It is going to be placed in one of the touring sub cabs for the 2 shows this weekend.
Oh look it fits! Handy 16/2 lift wires there too:
I decided it might be a good idea to finally add a jack and some wiring:
Thanks to the size of the enclosure and the heft of the driver, I figured mounting it where it will rest will be wise.
Wired:
More of those lifting wires:
And dropped in:
Hook it up and place it:
This thing has easily become my favorite driver. I can't wait to shoot it up with 3200w this weekend to see what it really can do wide open.
Next is the slot ported 12" enclosure loaded with SA-12. I took another driver out of these and needed something robust to take over:
I haven't even given one of these power yet, so I have no conclusions other than they look nice in there. More to come once I can try em out.
Last but not least, I replaced another pair of 12w0s. This one is a bit more fair, entry level against entry level and all. I picked up a pair of E12s by chance, there were just a few B-Stock items left at HQ and among them were this pair of E12s. A bit too much glue at the dustcap joint rendered them to the B-Stock shelf. These reside in a 1.25ft3 per driver premade cabinet, generally in my SUV, but these will be going to work with me for evaluation instead of the pair of aforementioned 10w3v3s. More detail on the system at work someday. Back to it:
Nice thing about premades, it doesn't always fit:
A bit of round file work and all is good, on to the second:
Sharp looking little entry level buggers:
This is an E12 compared to the SA12, they appear cosmetically similar but you can see the larger surround and stitching on the SA:
Well, that wraps it up for today. Saturday will be quite the day getting ready for the show that night, followed by renegade parties Vol 2 on Sunday.
Night.
WiSounds is offline
post #6 of 23 Old 04-09-2012, 03:33 AM
kgveteran's Avatar
Quoted: 465 Post(s)
Liked: 174
.... and all posted at 3am... You rock. Great pics of the venture. Those 15's look great. I will be needing two for my 12" Dayton project that all but failed.
kgveteran is offline
post #7 of 23 Old 04-09-2012, 06:50 AM
JimWilson's Avatar
Liked: 2037
I'd love to hear your impressions on that one. Seems like a nice little sub. Are you using a plate amp or external? Were the extended side panels for esthetics, or was that done for a specific reason? I'm not sure I've ever seen a design like that before, but it does present an interesting appearance.
post #8 of 23 Old 04-09-2012, 07:12 AM - Thread Starter
WiSounds's Avatar
The amps are external, but a plate amp could fit in the end or the non ported side. The cabs were built in a 6 pack, it was intended to start as 6 and end up as a pile of 16-20.:
The extended side panels are to accommodate grilles that I haven't yet installed. You could probably get creative with trimming the extended fronts into legs and stand the enclosure up on end.
The cabs sound great, I haven't had a chance to put any power the the SA12s yet. If I had it to do over I would tweak the porting to my full circumference style, but then the cab gets bigger. The compactness and output were the focus of this design. Grab a pair for house parties or smaller gigs, and start stacking them for the bigger shows. I have used it in the house as my studio/theater sub when the WiEasy sub was unloaded. I have unfortunately little listening time on them due to some driver issues with the LMS-R, but that is in the process of getting resolved.
WiSounds is offline
post #9 of 23 Old 04-09-2012, 12:09 PM
jbelljbell's Avatar
looks like a 300 to me.....
jbelljbell is offline
post #10 of 23 Old 04-09-2012, 12:21 PM - Thread Starter
WiSounds's Avatar
I'll actually be in Baton Rouge LA bowling at the USBC nationals in a couple weeks, May 2nd and 3rd I believe.
WiSounds is offline
post #11 of 23 Old 04-09-2012, 12:25 PM
maxmercy's Avatar
Quoted: 63 Post(s)
Liked: 168
Great Stuff, Wi. You have been BUSY!
JBell, nice to see you checking in....
JSS
maxmercy is offline
post #12 of 23 Old 04-09-2012, 12:38 PM
PassingInterest's Avatar
Quoted: 185 Post(s)
Liked: 504
Very nice!
PassingInterest is offline
post #13 of 23 Old 04-09-2012, 12:49 PM - Thread Starter
WiSounds's Avatar
Here is the shop pictures. When I'm not doing installs and builds I drill bowling balls. Can't not have music at work!
The tops are simple Niles OS5 outdoor speakers:
The rest is a B&K PT5 feeding a Sherbourn 2/150 powering the highs, and an FTX-2001 powering the subs. The pair of E12s are currently being used, the JL10s on the left edge are headed home with me tonight.
The drill press is right across a little space and it completely rocks driven off the PC.
WiSounds is offline
post #14 of 23 Old 04-09-2012, 12:54 PM
robseyes's Avatar
Hey! Cool stuff you got there. Care to share dimensions & specs for the "Wieasy" reference design. Looks like it would really rock!
robseyes is offline
post #15 of 23 Old 04-09-2012, 01:02 PM - Thread Starter
WiSounds's Avatar
This thread details the WiEasy sub and WiEasy cube with graphs and plans:
http://www.avsforum.com/avs-vb/showthread.php?t=1380474
WiSounds is offline
post #16 of 23 Old 04-09-2012, 01:04 PM
Dezmond's Avatar
Nice way to celebrate easter, lol . Looks great, nice builds.
Dezmond is offline
post #17 of 23 Old 04-09-2012, 05:34 PM
maxmercy's Avatar
Quoted: 63 Post(s)
Liked: 168
I recognize that background on the laptop....
JSS
maxmercy is offline
post #18 of 23 Old 04-09-2012, 05:44 PM - Thread Starter
WiSounds's Avatar
JSS
The design is proven, it is just waiting for me to set aside a few grand.
WiSounds is offline
post #19 of 23 Old 04-10-2012, 12:14 AM
Bass Enabler
Scott Simonian's Avatar
Quoted: 5972 Post(s)
Liked: 5025
Scott Simonian is offline
post #20 of 23 Old 04-10-2012, 07:04 PM
Jstslamd's Avatar
Id love to hear your impression on the sd-2 10" as I just a won one on a sundown giveaway and I'm trying to figure out what I want to do with it. It's will be pairing with two small energy speakers
Jstslamd is offline
post #21 of 23 Old 04-10-2012, 07:09 PM - Thread Starter
WiSounds's Avatar
Ill hook up the Triad box right now and take a listen for you.
WiSounds is offline
post #22 of 23 Old 04-10-2012, 09:15 PM - Thread Starter
WiSounds's Avatar
In this tiny sealed box it isn't crazy efficient, but that is part of the alignment. The sound quality is great though. I'll crank on it tomorrow and see how it does under stress, getting a little late tonight.
WiSounds is offline
post #23 of 23 Old 04-11-2012, 03:40 AM
Jstslamd's Avatar
Thanks a ton. How big is the triad enclosure and how much power are you feeding it ?
Jstslamd is offline
