end table / stealth build 15" ed aluminum driver - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 39 Old 04-13-2012, 07:02 PM - Thread Starter
jayhawk785's Avatar
Quoted: 16 Post(s)
Eventually--I still have swan 6.2s or whatever they are. I'll finish building the stentorians and see how i like them.
finished and installed :
jayhawk785 is offline
post #32 of 39 Old 04-13-2012, 07:05 PM
maxmercy's Avatar
Quoted: 63 Post(s)
Liked: 168
Wow. That is form and function. Congrats on a great build, and please report on the Stentorians, and if they can handle reference level!
JSS
maxmercy is offline
post #33 of 39 Old 04-14-2012, 05:17 AM
tundrSQ's Avatar
Originally Posted by jayhawk785 View Post
Someone else asked about heat with the plate amp being mounted as such. There's plenty of air moving around inside the cabin, and since the air is being forced down underneath the sub, it's bound to cool off the heat sink (those were my rationalizations anyway).
Just had a friend help me move the table in at lunch--we also put the granite top on as well and I snapped a picture. I'll post that up shortly. I need to put some felt feet on on the legs, so I can push it around a bit. It's a heaver f'er.
yes, but the amp's heat is being controlled by the heat sink (top plate)...and its is always best for the air to be allowed to rise up from the heat sink for natural convection cooling. But you will be fine..the box is not big enough to trap heat under it.
PS...i winced when i saw the price tag of the granite, until i scrolled up to see the picture... It gorgeous!! I am looking at how to finish my as yet unfinished (sub is done, finish is not) Baltic Birch subwoofer...and i really like this look. I was going to do a slate top or marble top being from vermont...but that granite looks sweet.
Tim
tundrSQ is offline
post #34 of 39 Old 04-14-2012, 05:20 AM - Thread Starter
jayhawk785's Avatar
Quoted: 16 Post(s)
I did too [wince], every place I called looking for remnants--I know there are decent places in KC that have good prices, but for whatever reason... Florida really thinks remnants are worth the same as large slabs. I think it comes down to finishing cost--I also went with 3cm vs. 2cm.
I was also thinking of doing some sort of tile/travertine in-lay with wood surround, but figured this surface will last a lifetime.
Bad part is, the cabinet already weighed a ton, then you add the driver, then you add the granite (granite alone is about 120-150lbs).
post #35 of 39 Old 04-14-2012, 09:13 AM
jpmst3's Avatar
Quoted: 97 Post(s)
Liked: 233
Looks fantastic in its home!
Joe = LFE Addict
Joe's LOWARHORN build
jpmst3 is offline
post #36 of 39 Old 04-14-2012, 08:54 PM
lowpolyjoe's Avatar
man, that looks so good in it's final spot. makes me want to build some endtable subs .
not sure if i missed it - did you mention your budget for this build?
great work
lowpolyjoe is offline
post #37 of 39 Old 04-14-2012, 09:09 PM - Thread Starter
jayhawk785's Avatar
Quoted: 16 Post(s)
ya, its on the first page i think. somewhere. I didn't really have a budget, but that shows appx what it cost to build.
post #38 of 39 Old 04-16-2012, 04:36 PM
manuetdeo's Avatar
Quoted: 56 Post(s)
Liked: 79
i wanted to say thank you for the pictures, you helped out a lot in trying to convince my wife of a similar build i've be trying to get past her for some time
manuetdeo is offline
post #39 of 39 Old 04-17-2012, 08:40 PM - Thread Starter
jayhawk785's Avatar
Quoted: 16 Post(s)
Haha no problem... Good luck with that--luckily mine doesn't care too much what's do and encourages projects
