DIY Project (24 X 24 X 46 Limits) - Page 3 - AVS Forum | Home Theater Discussions And Reviews
post #61 of 66 Old 04-20-2012, 03:56 AM
omegaslast's Avatar
car toys or al & eds will probably cut the sws15 price in half eventually. Will be a badass sub then
omegaslast is offline
post #62 of 66 Old 04-20-2012, 08:41 AM - Thread Starter
AVrebel's Avatar
I've done some new compares on the 11 ft^3 @ 18hz.
1 X 18.2.2
2 X SWS-15D4
2 X SWR - 1522D
2 X SWR - 1542D
2 X JBL W15GTI
Decisions ....
resolution good....
AVrebel is offline
post #63 of 66 Old 04-20-2012, 11:34 AM - Thread Starter
AVrebel's Avatar
I'm probably lost it, but while I'm considering drivers total cost < 400... Here is another comparison:
1 X Mach 5 18.2.2 $230 (back ordered)
2 X Alpine SWR-1542 D $200 ea. ~ $400
3 X Alpine SWR-1243 D $130 ea. ~ $390
I had to bring up the tuning on the 12"s to be in line. First graph is with 1000 W input .... second is Max SPL for the drivers. 1000W, 1500W, and 1800W respectively.
resolution good....
AVrebel is offline
post #64 of 66 Old 04-20-2012, 02:10 PM
Sepen's Avatar
Quoted: 27 Post(s)
Liked: 31
I have seen the IXL in 11-13 cu ft builds with a 15hz tuning over at Hometheatershack. In fact I have two of them and have been contemplating a build myself.
Sepen is online now
post #65 of 66 Old 07-21-2012, 10:35 PM
matt overpeck's Avatar
I find the info coming from our friends at Alpine to be rather curious. While it is certainly commendable that they invest in
having a Klippel to test their drivers, then they publish the new data on the SWS 15 (per his thread). Furthermore, they claim
this new series is "underhung" design, but looking at the Bl curve, it does not at all resemble the traditional 'flat Bl curve' that
inverted-coil, aka "underhung" motors exhibit. The data sheet info shows a sectional with extended-gap design, but as there
is no clear image of how long the coil is relative to the gap, nor any info on the VC or gap height, as they typically provide, who
can tell.
To compound this, the posted curve of the SWR "Type R" flat, which IS an "underhung" design (long-gap/short coil), as
illustrated by the lower graph on the SWR, has not been touted as being "underhung," though the gap to VC specs/data,
clearly shows it is. Omitting this designation from the SWR (or an alternative name to denote it is not traditional overhung),
but this seems odd, esp as they now mention the SWS design is 'similar' to the SWR design.
So how do these conflicting circumstances co-exist. You would think they would want to tout the benefits of a more expensive
motor topology (as in Type R Flat), to help justify the price (which they apparently do not), or they would not use that term on
a more affordable (under $200) driver, which ironically for 2012 is FAR deeper than the prior gen type S drivers, and this seems
very strange, as it would make more sense that a 'short-coil' motor would be adopted to "reduce" the motor depth. So the deeper
motor on the new SWS would suggest it is NOT an "underhung" motor at all, and as mentioned, the Bl x curve clearly looks like
it is just a typical, long-coil design (perhaps it is just a long-gap with a long VC, aka "even-hung" motor).
If it is an "even-hung" type design, this would explain the power rating, esp if it is a "short-coil" would not likely handle 500 watts
RMS, even if it is a 2.5" multi-layer (which it no doubt is). If that is the reality, either they are either confused or simply very
concerned with the accuracy of their terminology. In any case it is certainly rather misleading.
Good that Alpine puts the data out there, but really bizarre that they seem to not understand what's what, IMHO. If I have missed
something here, please illuminate me.
Cheers!
M
matt overpeck is offline
post #66 of 66 Old 01-27-2017, 08:46 PM
Doc777's Avatar
Liked: 1
Wink
Originally Posted by Jim Walter View Post
Full Disclosure: I work for Alpine
While there was a post about the R15s, I'd suggest looking at the new S15's, actually using a pair of them in that box.
They are fully new design, a different take on things in the "budget" category. They are an underhung design with a clean 15mm Xmax (one way) 36mm Xmech so you can beat the snot out of them. 500W RMS, but they are quite efficinent, so no need for crazy power.
Hi Jim,
I called Alpine today for SWS10D4 BL info which was 13.6, but that seems half what I expected. Is it doubled for two VC? Do you have Qts etc?
Doc777 is online now
