speaker stand build - AVS Forum | Home Theater Discussions And Reviews
Old 04-18-2012, 11:45 AM - Thread Starter
cmryan821's Avatar
Quoted: 195 Post(s)
Liked: 59
Guys, I'm trying to build a set of stands for my LCR(jtr triple8's) and I've got something simple to start. Any suggestions that you can see from this pic that I should try to add? Should I close in the columns and fill with something heavy to lower the center of gravity? Or anything else?
cmryan821 is online now
Old 04-23-2012, 12:29 PM
LTD02's Avatar
Quoted: 2343 Post(s)
Liked: 2581
could be an interesting experiment.
put the left side on your stand. put the right side on a couple of solid concrete blocks.
test.
if you can't hear any difference, then you are good to go. :-)
Listen. It's All Good.
LTD02 is online now
Old 04-23-2012, 05:35 PM
Looneybomber's Avatar
Liked: 25
I would add more bracing for strength/stability purposes. You have two flat boards parallel to each other, so they will be easy to collapse in the left/right direction.
YID DIY
Looneybomber is offline
