MFW-15 sealed (x4) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 101 Old 04-20-2012, 07:08 PM - Thread Starter
petew's Avatar
Quoted: 27 Post(s)
Liked: 68
I finally got started building some plywood boxes for the things in these cardboard boxes. Muchas gracias to Erich.
Building Bass - Subs
Surrounds - Easy as Pi
Storage - unRAID unDELL
Mains - Another piece of Pi
petew is offline
post #2 of 101 Old 04-20-2012, 07:10 PM
michaelddd's Avatar
Quoted: 322 Post(s)
Liked: 207
michaelddd is offline
post #3 of 101 Old 04-20-2012, 07:51 PM - Thread Starter
petew's Avatar
Quoted: 27 Post(s)
Liked: 68
I started with the top, bottom and sides. Material is 3/4" AraucoPly.
One box on the floor, another on the bench, number three in clamps, four leaning on the doghouse waiting to be assembled.
petew is offline
post #4 of 101 Old 04-20-2012, 07:52 PM - Thread Starter
petew's Avatar
Quoted: 27 Post(s)
Liked: 68
Can't have too many clamps.
petew is offline
post #5 of 101 Old 04-20-2012, 07:53 PM - Thread Starter
petew's Avatar
Quoted: 27 Post(s)
Liked: 68
Another view. Helpers are hanging in the shadows.
petew is offline
post #6 of 101 Old 04-20-2012, 07:56 PM - Thread Starter
petew's Avatar
Quoted: 27 Post(s)
Liked: 68
I cut dados in the top and bottom pieces and along the front and back of all four sides (to receive bracing). Dados make assembly so easy - no nails or screws, just Titebond II wood glue. Bessey K body clamps are a wonderful piece of engineering.
petew is offline
post #7 of 101 Old 04-20-2012, 07:58 PM - Thread Starter
petew's Avatar
Quoted: 27 Post(s)
Liked: 68
Closeup of the dado
petew is offline
post #8 of 101 Old 04-20-2012, 07:59 PM - Thread Starter
petew's Avatar
Quoted: 27 Post(s)
Liked: 68
Number four in the clamps.
petew is offline
post #9 of 101 Old 04-20-2012, 08:13 PM - Thread Starter
petew's Avatar
Quoted: 27 Post(s)
Liked: 68
Bracing the corners. I nailed plywood triangles into the dados. I had to clamp one box corner-to-corner to square it up. All the others were within 1/16" on the diagonal measurements.
petew is offline
post #10 of 101 Old 04-20-2012, 08:14 PM - Thread Starter
petew's Avatar
Quoted: 27 Post(s)
Liked: 68
Closeup of the corner braces. I'll eventually glue the front and back baffles to these braces.
petew is offline
post #11 of 101 Old 04-20-2012, 08:15 PM - Thread Starter
petew's Avatar
Quoted: 27 Post(s)
Liked: 68
Another closeup. Dado is ready to receive the corner brace.
petew is offline
post #12 of 101 Old 04-20-2012, 08:16 PM - Thread Starter
petew's Avatar
Quoted: 27 Post(s)
Liked: 68
Before I nailed the braces in I pulled them tight to the corner with a clamp. That forced the warped plywood flat and made the corners square.
The pocket holes don't have any function in these boxes. The braces were cut out of left over scraps from my oak coffered ceiling project.
petew is offline
post #13 of 101 Old 04-20-2012, 08:19 PM - Thread Starter
petew's Avatar
Quoted: 27 Post(s)
Liked: 68
Big stack of braced boxes.
Time for a Samual L. Jackson.
petew is offline
post #14 of 101 Old 04-20-2012, 08:26 PM - Thread Starter
petew's Avatar
Quoted: 27 Post(s)
Liked: 68
I made a quick and dirty jig to nail up braces. I just used the finish nailer to attach wood scraps to the bench top.
petew is offline
post #15 of 101 Old 04-20-2012, 08:27 PM - Thread Starter
petew's Avatar
Quoted: 27 Post(s)
Liked: 68
Here's a brace in the jig, freshly nailed.
petew is offline
post #16 of 101 Old 04-20-2012, 08:28 PM - Thread Starter
petew's Avatar
Quoted: 27 Post(s)
Liked: 68
A few braces made and a stack of sticks in line for glue and nails.
petew is offline
post #17 of 101 Old 04-20-2012, 08:28 PM - Thread Starter
petew's Avatar
Quoted: 27 Post(s)
Liked: 68
Finished braces ready to install in the boxes.
petew is offline
post #18 of 101 Old 04-20-2012, 08:30 PM - Thread Starter
petew's Avatar
Quoted: 27 Post(s)
Liked: 68
Closeup of bracing. X marks the bottom.
That's all I got done on day two. Must have been the Samuel L. Jacksons.
petew is offline
post #19 of 101 Old 04-20-2012, 08:43 PM - Thread Starter
petew's Avatar
Quoted: 27 Post(s)
Liked: 68
Day Three...
More bracing. I installed four more sticks to brace the middle of the panels. I cut the ends at a 3 degree angle so I could tap the sticks into place without bowing the panels out. I didn't nail the ends but the braces are nailed together at the intersection. I've got gobs of glue everywhere.
petew is offline
post #20 of 101 Old 04-20-2012, 08:44 PM - Thread Starter
petew's Avatar
Quoted: 27 Post(s)
Liked: 68
More bracing. I've added more sticks to connect the first set of braces to the cross braces. Are we done yet? I think so....
petew is offline
post #21 of 101 Old 04-20-2012, 08:49 PM - Thread Starter
petew's Avatar
Quoted: 27 Post(s)
Liked: 68
Test fit. The driver is sitting on the brace in this shot. The back of the speaker will be about 1/4" from the brace once I have the baffle mounted.
petew is offline
post #22 of 101 Old 04-20-2012, 08:52 PM - Thread Starter
petew's Avatar
Quoted: 27 Post(s)
Liked: 68
Next steps....
Rough sanding of the rabbit joints.
True up the edges where the front and rear baffles go. (mostly clean up glue squeeze out).
Do a round-over on the corners.
Fabricate baffles - I have a sheet of Chinese birch plywood for baffles.
petew is offline
post #23 of 101 Old 04-21-2012, 03:34 AM
Fatshaft's Avatar
Quoted: 591 Post(s)
Liked: 906
very nice work Pete...
Are you going to stuff your cabs with polyfill?
My Build Thread
Equipment Speakers:
3x 1099's for LCR duty
4x Fusion 8's for surround duty
8x subs: 4x FTW21's and 4x SI18's
Fatshaft is offline
post #24 of 101 Old 04-21-2012, 05:48 AM - Thread Starter
petew's Avatar
Quoted: 27 Post(s)
Liked: 68
Originally Posted by Fatshaft View Post
...Are you going to stuff your cabs with polyfill?
What's the general consensus about stuffing? I've heard it makes the cabinet model slightly larger. Any other audible effects? This is my first speaker construction project so any suggestions are welcome.
petew is offline
post #25 of 101 Old 04-21-2012, 07:45 AM
Looneybomber's Avatar
Liked: 26
Just a heads-up, if you haven't already, take those woofers out of the box. I noticed, with mine, when boxed up, the surrounds push up against the cardboard, which forces the cone in a little. After being boxed up for a while, I noticed my woofer cones, at rest, settled in (towards magnet) from center. If you can, have them in a down firing situation/position for a while so gravity will help push those cones back to rest in the center of their stroke.
YID DIY
Looneybomber is offline
post #26 of 101 Old 04-21-2012, 08:17 AM - Thread Starter
petew's Avatar
Quoted: 27 Post(s)
Liked: 68
Thanks for the heads-up Looney. I'm off to the Big Orange Box for tee nuts and a new router bit...
petew is offline
post #27 of 101 Old 04-21-2012, 08:51 AM
nube's Avatar
Quoted: 76 Post(s)
Liked: 443
All looking good. Seems like a LOT of bracing; at least you know those boxes won't be going anywhere!
Depending on how much power you're giving each, and how hard you're driving them, AIUI, stuffing a pillow or two in each will help with efficiency, but might make you reach xmax a little sooner (higher up in frequency).
nube is offline
post #28 of 101 Old 04-21-2012, 10:16 AM - Thread Starter
petew's Avatar
Quoted: 27 Post(s)
Liked: 68
I'll be driving them with a BK 5000 series II five channel amp rated at 145 into four ohms.
I think I'll run them unstuffed to start. I'm not going to do any wood finishes right away - can always stuff later when I take the drivers out to finish the cabs.
petew is offline
post #29 of 101 Old 04-21-2012, 10:20 AM - Thread Starter
petew's Avatar
Quoted: 27 Post(s)
Liked: 68
Originally Posted by nube View Post
...Seems like a LOT of bracing....
OCD on display. I kept adding sticks until the "rap test" gave a consistent sound everywhere. I'll calculate internal volume now that the bracing is in place.
petew is offline
post #30 of 101 Old 04-21-2012, 10:45 AM
Kanaris's Avatar
Nice work,I see your're well equipped.What are you gonna power them with?
Kanaris is offline
