Have a DIY speaker project? Need a Driver? Check this list... - AVS Forum | Home Theater Discussions And Reviews
post #1 of 24 Old 04-21-2012, 12:30 PM - Thread Starter
WiSounds's Avatar
It is time to clean house. The following list is by size. A picture, and condition is listed. Paypal preferred.
The zip they will come from is 14623 to figure shipping. I use a FedEx account, so shipping will be less than quotes on their website.
21"
(Qty 1)B&C 21SW152-4 ($675+ ship)892 new Mounted, used for 2 shows, 4ohm.
http://www.parts-express.com/pe/show...89&FTR=21sw152
(Qty 1) 18Sound 21LW1400 ($400+ship)529 new Mounted, used one show, 8ohm.
http://www.usspeaker.com/eighteensound-21LW1400-1.htm
18"
(Qty 2) Eminence Sigma Pro ($130ea+ship)170 new Mounted, used for 5 shows, 8ohm.
http://www.parts-express.com/pe/show...gma%20pro%2018
(Qty 1) Kicker SoloX Square ($350+ship[100lbs]) Mounted and used.
15"
(Qty 1) Kicker Solo-Baric D-Series (80+ship) Mounted and used lightly for a couple of months in my SUV, 2ohm.
(Qty 1) Kicker Solo-Baric D-Series (80+ship) Mounted and used lightly for a couple of months in my SUV, 4ohm.
(Qty 1) Sundown Audio SA15D2 ($200+ship)290 new NIB
http://www.sundownaudio.com/index.ph...sa-series.html
12"
(Qty 4) Sundown SA12D2 ($150ea+ship)195 new Used at one show
http://www.sundownaudio.com/index.ph...?category_id=2
(Qty 1) Dayton RS315HO-44 ($130+ship)156 new NIB
http://www.parts-express.com/pe/show...number=295-467
(Qty 2) TC Sounds LMS-R 12 ($300ea+ship)369 new New top assemblies.
http://www.parts-express.com/pe/show...number=293-658
(Qty 1)PPI PCX124 ($50+ship) Mounted once for a 5 minute test, mint.
(Qty 8) JL Audio 12w0-4 ($40ea+ship, $275+ship for all 8) Used in sealed enclosures for a couple of years.
10"
(Qty 1) Peerless XLS10 ($135+ship)194 new Mounted from Triad in an in-wall subwoofer, never used.
http://www.parts-express.com/pe/show...umber=264-1108
8"
(Qty 4) B&C 8MDN51 ($120ea+ship)165 new Mounted in tops, used for 3 shows.
http://www.parts-express.com/pe/show...648&FTR=8mdn51
6"
(Qty 2) Dayton PK165-8 ($25ea+ship)32 new NIB
http://www.parts-express.com/pe/show...20&FTR=pk165-8
I will be traveling and returning on May 7th so that will be the earliest I can ship.
Originally Posted by Bill Fitzmaurice:
It's also the very sort of Voodoo Engineering that should never be done.
WiSounds is offline
post #2 of 24 Old 04-21-2012, 12:33 PM
tgaffner1's Avatar
I have 2 Eclipse 15" Titanium SW9152's, like new, in boxs!!
PM me if interested
tgaffner1 is offline
post #3 of 24 Old 04-21-2012, 12:40 PM
omegaslast's Avatar
Im going to be called a hater but oh well:
SA15 new $235 free shipping
http://www.soundsolutionsaudio.com/s...SA%252d15.html
Also the Sundown Zv3 18" is $480 new, but SSA still has to pay shipping, they just roll it into the cost. Shipping on a 60lb box would be $30 even if it was down the street. Someone in california will likely be paying $70-$80.
omegaslast is offline
post #4 of 24 Old 04-21-2012, 12:43 PM - Thread Starter
WiSounds's Avatar
Good spot. Adjusted both. SA15 to $200+ship, Zv3 goes to $400+ship. Tweaked the SA12 as well. I use a fedEx account so shipping will be less than website quotes.
Not out to make a pile of money on these, just get them out of here, and to help fund some new builds now that I have a more solid direction. If you see anything else not comparable let me know.
WiSounds is offline
post #5 of 24 Old 04-21-2012, 03:42 PM
deathinc's Avatar
How Would the SA15 perfom against the Dayton 15" 390 HF ?
Av123 Onix Rockets RS1000 , AV123 RSC200 BIGFOOT, B&W WM6 White, Denon AVR-4311CI 9.2
DIY Stereo Integrity SI 18" Subwoofer X2, HTPC Running XBMC 14TB , Roku HD Player
Sony VPL-VW70 Pojector, Xbox 360 250GB, Yamaha RX-V573
deathinc is offline
post #6 of 24 Old 04-21-2012, 04:06 PM - Thread Starter
WiSounds's Avatar
The SA handles more power, and has more displacement with 19mm vs 14mm xmax. They both favor larger sealed enclosures.
WiSounds is offline
post #7 of 24 Old 04-21-2012, 04:13 PM
deathinc's Avatar
So The Sa15 would go lower and louder I assume. I have 2 390 hfs and 2 oaduio amps. Never build the subwoofers lol. I'm regretting buying those HFs now lol. I'm wonder which one will do better in the sound quality dep since the HF's are known to be very very high SQ drivers.
deathinc is offline
post #8 of 24 Old 04-21-2012, 05:10 PM
LTD02's Avatar
Quoted: 2499 Post(s)
Liked: 2831
the two are very different approaches to driver design.
the hf employs a weak motor and very compliant (loose) suspension. good inductance management.
the sa15 employs a little stronger motor, but pretty low compliance (stiff) suspension. not sure about inductance management.
hf is designed to be better for listening to a cello, upright bass, et al where the little nuances are important hence its name and different choice in design than the ho, while the sa15 is designed to survive all kinds of dumb acts with a ton of power which is VERY important in the car audio world where sundown has its roots.
for a sealed application in home theater where you know what you are doing either should work fine, but the larger xmax of the sa15 gives it the edge in the bottom octaves spl. however, since you are limited to 500? watts, you are going to end up with similar spl because you will run out of amp before you run out of excursion with the sa15.
Listen. It's All Good.
LTD02 is offline
post #9 of 24 Old 04-21-2012, 06:37 PM - Thread Starter
WiSounds's Avatar
The SA15 has a pair of Faraday Rings, the HF uses three shorting rings.
The SA's 600w Pe rating is very conservative. Real world 800-1kw would not be out of line considering the extensive venting and motor parts used.
WiSounds is offline
post #10 of 24 Old 04-21-2012, 08:56 PM
Thatsnasty's Avatar
Quoted: 51 Post(s)
Liked: 44
Pmed you about the ZV3.
Still wondering on what size would be good sealed for this, hmm.
I think my winisd has it right, modeled it vrs an LMS-U, UXL-18, and SDX15.
It only loses out below <20hz, but still handles more power (minus the LMS).
Looks good in 200l.
Thatsnasty is offline
post #11 of 24 Old 04-22-2012, 08:55 AM - Thread Starter
WiSounds's Avatar
Looks good in 200l.
Use 2.5kw for Pe and 30mm Xmax, 45mm Xlim. Those are very realistic home theater specs.
WiSounds is offline
post #12 of 24 Old 04-23-2012, 10:33 AM
LTD02's Avatar
Liked: 2831
bump
LTD02 is offline
post #13 of 24 Old 04-24-2012, 05:55 AM
cecaa850's Avatar
The 15" Sundown is $235.00 inc shipping new, or am I looking at the wrong driver. My son was wanting one.
120@20@14'
cecaa850 is offline
post #14 of 24 Old 05-04-2012, 05:44 AM - Thread Starter
WiSounds's Avatar
Prices reduced:
B&C 21sw152: $500+ship
18Sound 21lw1400: $300+ship
SoloX 18: $250+ship
Dayton rs315ho: $110+ship
WiSounds is offline
post #15 of 24 Old 05-04-2012, 06:43 PM
lowpolyjoe's Avatar
lowpolyjoe is offline
post #16 of 24 Old 05-04-2012, 06:56 PM - Thread Starter
WiSounds's Avatar
I have a pair of a/d/s 308rs. $75+ ship for the pair.
WiSounds is offline
post #17 of 24 Old 05-04-2012, 07:04 PM
N8DOGG's Avatar
Quoted: 1104 Post(s)
Liked: 1201
That PPI sub is actually pretty good and a great deal at $50. Good deals all around! GLWS! if shipping wouldn't kill the deal, I'd even grab a few to mess with but being in Canada, kinda ruins it lol
N8DOGG is offline
post #18 of 24 Old 05-05-2012, 05:25 AM - Thread Starter
WiSounds's Avatar
If you are anywhere near Niagara Falls/Buffalo in Canada shipping is a non issue as I'm an hour from there on the US side.
WiSounds is offline
post #19 of 24 Old 05-05-2012, 09:31 AM
N8DOGG's Avatar
Liked: 1201
nope, I'm in Winnipeg. Thats a good selection of different drivers, you have something for everyone!
N8DOGG is offline
post #20 of 24 Old 05-05-2012, 10:46 AM
lowpolyjoe's Avatar
Thanks. Any chance youve measured the t/s Params for those? I want to model them for an existing enclosure but the online users manual doesn't list t/s
post #21 of 24 Old 05-05-2012, 10:50 AM - Thread Starter
WiSounds's Avatar
I have a .pdf of them at home, but I'm on the road to Detroit. I found it through google, on a random forum post. I'll look in a few hours when I get to Detroit if you can't find it.
WiSounds is offline
post #22 of 24 Old 05-05-2012, 12:12 PM
noobzorta's Avatar
Just for giggles, what would shipping be on the solo-X to 84056? Not sure if the wife would ever let me, but worth a shot lol.
noobzorta is offline
post #23 of 24 Old 05-05-2012, 12:15 PM - Thread Starter
WiSounds's Avatar
UPS.com has an estimator. 100lbs from 14450.
WiSounds is offline
post #24 of 24 Old 05-05-2012, 06:02 PM
omegaslast's Avatar
These prices are nuts and it makes me mad that im all the way across the country in CA..
