low pass filter questions - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 04-21-2012, 10:05 PM - Thread Starter
darkrider7589's Avatar
Hi everyone thank you for your time.
I need to set up a 250 Hz lpf. So I need to find out what info?the ohm at 250hz for that speaker? Anything else?
darkrider7589 is offline
post #2 of 5 Old 04-21-2012, 11:36 PM
michaelddd's Avatar
Quoted: 326 Post(s)
Liked: 209
Need more info before we can help you. Are you trying to build a passive crossover for your speaker? What type of speaker is this? L/C/R? Subwoofer? 250Hz lowpass is an odd xover frequency for a speaker, unless that speaker is a component in a mulit-driver speaker cab.
250Hz is way too high for a subwoofer xover.
michaelddd is offline
post #3 of 5 Old 04-21-2012, 11:53 PM
LTD02's Avatar
Quoted: 2527 Post(s)
Liked: 2869
dark,
you are in over your head. i tried to warn you.
what order cross do you want?
how do you plan to level match the components?
what about baffle step compensation?
Listen. It's All Good.
LTD02 is offline
post #4 of 5 Old 04-22-2012, 01:16 AM
A9X-308's Avatar
Quoted: 1506 Post(s)
Liked: 1142
You need to measure it.
“You are not special. You are not a beautiful and unique snowflake.” Chuck Palahniuk
A9X-308 is offline
post #5 of 5 Old 04-22-2012, 09:24 AM
kgveteran's Avatar
Quoted: 470 Post(s)
Liked: 174
Just a little forwarned..... I was setting up my AUX subs yeasterday for the hundreth time hahaha, i was experimenting with Hipass and Lopass. If i added lo and hi pass to them i had to invert phase. Now i knew this because i was running OmniMic at the same time. No way i would have known that with out MiniDSP software and OmniMic monitoring.....
This is not for the faint of heart....
kgveteran is online now
