eDesign DIY12" w/LMS-R and Inuke3000DSP - AVS Forum | Home Theater Discussions And Reviews
post #1 of 16 Old 04-23-2012, 11:51 AM - Thread Starter
noobzorta's Avatar
Figured i would post up this recently completed project since i havent seen much on the LMS-R series.
Specs of the build -
Tc Sounds LMS-R 12"
eDesign DIY 12" kit (cheaper then buying tools and MDF)
Inuke3000dsp
I originally had the lms-r and a VMP-12 in a 1.8cf box. It was great, up until i forgot to turn down the gain and snapped the spider off the cone/weight pole on the VMP. I ended up re-epoxying it, but the tuning was no where near the same.
Fast forward to now, without a proper sub for a while, i decided to just finish this box and throw it all together for the time being. I still need to get a router and do the edges and finish it.
Overall, im happy with the output of the sub! The port is as-is at 18in total, which win isd says 20.7hz tuning.
I played with a few HPF on the inuke and there charted as noted on the REW sheet below. I wish the inuke offered lower HPF settings than 20hz. I did do some minor eq work in the 30,60,80,100 ranges to boost it up. These are based off what win isd shows for xmax. Measurements were taken by a RS 33-2055 meter, mac book pro. I use a DI4000 to amp the reciver signal to the pro amp, and also convert my main's signals to XLR for my other amp.
And a finished picture (well not totally finished lol),
noobzorta is offline
post #2 of 16 Old 04-27-2012, 01:32 AM
LTD02's Avatar
Quoted: 2350 Post(s)
Liked: 2587
not sure why nobody posted...
neat. how are you planning to finish it?
Listen. It's All Good.
LTD02 is offline
post #3 of 16 Old 04-27-2012, 06:35 AM
03roadking's Avatar
Great looking build! How are you liking that inuke?
03roadking is offline
post #4 of 16 Old 04-27-2012, 07:09 AM
Looneybomber's Avatar
Liked: 25
In addition to talking about your sub some more, tell us about your amp rack. This is the diy section after all. :-)
YID DIY
Looneybomber is offline
post #5 of 16 Old 04-27-2012, 08:20 AM
smokarz's Avatar
Quoted: 30 Post(s)
Liked: 83
hey, which issue is that Maxim?
btw, nice build.
smokarz is offline
post #6 of 16 Old 04-27-2012, 08:41 AM
NicksHitachi's Avatar
Quoted: 182 Post(s)
Liked: 189
Man that is smooth from 40-20!
NicksHitachi is offline
post #7 of 16 Old 04-27-2012, 09:05 AM - Thread Starter
noobzorta's Avatar
Thanks all!
Im wanting to do some thing like a bedliner or hammertone finish. Im just waiting on funds to buy a router to hit the edges before i finish it.
The inuke amps have been great so far. Have not had any issues with them. The sub amp is ran off a diff breaker then the mains. I have a usb tripped powerstrip being triggered by my avr (poor mans relay lol), that turns on the di4000 and other i nuke for the mains.
The rack, well its kind of a Frankenstein type deal. I originally had a 2post 36" rack, however when i moved last, the movers lost the side rails. So i had to rig something up, so i got a cedar 2x4 and made a little version haha.
I plan to 86 the rack, and either get a new ent center / build one because my kid is about to be walking before i know it lol.
I'll try to find some other pictures on the project. I kept forgetting because it took forever to get the ED kit.
post #8 of 16 Old 05-27-2012, 12:14 AM - Thread Starter
noobzorta's Avatar
After finishing the box and finally doing the sub crawl. I have eq'd the sub and taken measurements with REW.
I am pretty stoked on how amazing a single 12" can be, and am considering doing another one as well.
I didn't get a chance to buy a router, so i eye balled the curves and it seemed to come out pretty good id say. The wife even approves of its looks lol, however she said i cannot build a bigger one...yet...lol
I finished the box with the rustoleum spray on bed liner, no primer. It was sanded to 150grit and then coated 3 times. Unfortunately i got a drip on the face plate, but its not super noticeable.
Anyways, onto the pictures!
Over all, i am happy with the output down low. War of the worlds is pretty much insane for my small 14x20' room lol.
post #9 of 16 Old 05-27-2012, 03:27 AM
LTD02's Avatar
Liked: 2587
"I wish the inuke offered lower HPF settings than 20hz."
you can jury rig something close.
let's say that you want a 2nd order 12db/oct hp filter around 10hz.
set high pass 1 at 20hz, 12db/oct
then go to the parametric eq tab
set filter 1 to gain= -12db, frequency= 20hz, quality/type= HS12
what is happening here is the hp filter starts rolling off the signal at 12db/oct at 20hz, but then the second filter is boosting the signal at 12db/oct from 20hz down to 10hz, as the second filter rolls away at 10hz, the effect of the first filter comes back in.
the cost is that because you are beating down the signal (green line) by 12db, you will lose 12db of signal to noise in the signal chain, but for practical purposes that won't matter.
LTD02 is offline
post #10 of 16 Old 05-27-2012, 08:01 AM
Quoted: 182 Post(s)
Liked: 189
That looks nice!!!
post #11 of 16 Old 05-28-2012, 01:57 PM - Thread Starter
noobzorta's Avatar
That looks nice!!!
Thanks! For a budget build, i think it came out pretty nice!. I loved using the speakon connectors, makes everything much easier once its said and done. Well i guess besides having a 4x11g snake under the carpet lol.
I really havent seen much in the diy of the lms-r 12 segment. Seems like a pretty good driver for what it is.
post #12 of 16 Old 05-28-2012, 03:51 PM
Erich H's Avatar
Quoted: 1411 Post(s)
Liked: 1781
Just curious, what are the dimensions of that box and what's the tuning?
I looked at their site but I don't understand the 18hz tune with the dimensions they posted. Then again, I'm not the best at figuring that stuff either way.
Did you install a longer port?
_______________________
The SEOS Waveguide Project
Erich H is offline
post #13 of 16 Old 05-28-2012, 06:47 PM
christmclean's Avatar
Here is the link to the sub box used for this build.
http://www.edesignaudio.com/product_...roducts_id=905
It looks like it is 13 x 18 x 26
christmclean is offline
post #14 of 16 Old 05-28-2012, 08:15 PM - Thread Starter
noobzorta's Avatar
I think the tuning per winisd was something like 20.7hz or so. I measured the port to 18" end to end with flare, before i glued it together. I think the total vol for the box was 3.8cf or so, not sure if they calculated the brace they sent along with it.
Ive been wondering if possibly a radius'd cone might pick up some power if i put it behind the port. Kind of like a smooth transition?
post #15 of 16 Old 05-29-2012, 01:48 PM
FUN4ME's Avatar
So you could do this and get to just about any frequency (lo pass) between 10 and 20 hz, just by playing with the filters?
FUN4ME is offline
post #16 of 16 Old 05-31-2012, 04:26 AM
omegaslast's Avatar
Very cool post.. if i wanted to do an 18hz 24db/octave butterworth filter on an inuke what would i do?
ive spent like 20 minutes trying to figure this out and im sucking at it
omegaslast is offline
