Unity horn with 2 x Eminence Alpha 6 drivers - Page 3 - AVS Forum | Home Theater Discussions And Reviews
 2Likes
post #61 of 78 Old 09-18-2012, 09:13 PM - Thread Starter
johnbomb's Avatar
Well, I thought I'd quit at the "two hole" data set above, but I wanted to see if I could do better. I added another row of holes closer to throat, and ended up with this iteration. The "5/6/3/2" hole pattern seems to provide the best balance of low end and high end response (kind of looks like that sailboat I used to see on those old "light-brite" commercials from the 70's and 80's... or maybe just an origami paper hat).
I've shown comparison to the original "two rows" data (shown in my lat post) as well as another pattern in the hole plate. Notice the extended low end response of the BMS 4550 from 1-1.5k as well as the smother top end from 3-6k. And, compared to "two holes", I'm only taking <1db hit on the alphas from 350-500hz.
I'll now have to make a dedicated plate with only this pattern so that I can confirm its superiority and move forward with further testing. We'll see what happens next!
John
Edit: adding some construction data: hole plate 3/16" thick; distance to first row (the "5" of "5/6/3/2") is 7.3 cm compass radius from outside center point at CD mounting plate attachment
johnbomb is offline
post #62 of 78 Old 09-19-2012, 05:59 PM
dlouw's Avatar
This thread is a great experiment and education tool. Hats off for all the effort to do this and share it with us. You sir deserve a DIY award of excellence.
Looking at your graphs it seems that covering more holes closer to the throat and CD benefits the low end extension of the CD. The mids seem to care more about the amount of breathing room. These observations and Ivan’s comments of position and wavelength leads me to wonder what would happen if you taped the rows closer to the throat? This would allow more un interrupted expansion for the HF driver. Any thoughts?
Derek
dlouw is offline
post #63 of 78 Old 09-19-2012, 10:22 PM - Thread Starter
johnbomb's Avatar
Thanks, Derek.
I think your observations are correct. Many of the iterations that I tested (whose results I didn't post) had holes and other port shapes that were further out from the throat than what I am currently evaluating, and these all caused the alpha high end rolloff to occur at a lower frequency than I wanted. I suspect that I'm at the point of diminishing returns with respect to trying out new hole combinations, unless further testing of this "5/6/3/2" arrangement doesn't hold up to my requirements at 119db. I'll post those results when I have them, along with more specific design information if all goes well. That way, if someone wants to build one of these things, they will have the completed recipe. smile.gif
John
johnbomb is offline
post #64 of 78 Old 09-27-2012, 03:31 PM
Nisse.p's Avatar
Why not try to drill the holes like they do the EnABL process?
http://www.positive-feedback.com/Issue21/standingwaves.htm
Nisse.p is offline
post #65 of 78 Old 09-27-2012, 08:35 PM - Thread Starter
johnbomb's Avatar
That's a pretty cool idea, although I'm not sure how I'd get enough holes close enough to the horn with that pattern to get enough port area. Did you have a specific pattern in mind?
johnbomb is offline
post #66 of 78 Old 09-28-2012, 05:59 AM
Nisse.p's Avatar
No just thinking out loud.
There is probably somebody here that have more knowledge about exactly what pattern to use.
You could try to use tape and EnABL the area before and after your existing port.
Its suppose to do some kind of difference to diffraction horns. So why not try it?
The patent
http://www.google.com/patents/US5304746?dq=US5304746&hl=sv&sa=X&ei=8JJlUMiVHcSRhQeUgYHQDg&sqi=2&pjf=1&ved=0CDMQ6AEwAA
Maybe this can help you with ideas.
http://www.diyaudio.com/forums/full-range/146275-enabl-how-fostex-fe127e-other-speakers-2.html#post1865471
Nisse.p is offline
post #67 of 78 Old 09-28-2012, 01:50 PM - Thread Starter
johnbomb's Avatar
I've been reading the related threads at diyaudio: fascinating stuff. Here's the "daddy" thread:
http://www.diyaudio.com/forums/multi-way/100399-enabl-processes.html?perpage=25&pagenumber=1
From what I have gathered so far, this EnABL process is used to create a kind of diffraction grid to reduce (eliminate?) standing waves that originate from driver cones and speaker enclosures... potentially very useful in the horn domain, as the terms "honk" and "bite" come up quite often. I'll have to think about this some more and try to come up with a pattern to line the mouth of the horn.
Other methods for reducing horn harshness include surrounding the periphery of the horn mouth with absorptive material, stuffing the whole horn with 30ppi foam, and using exotic horn mouth terminus profiles such as that used by Le'Cleac'h
johnbomb is offline
post #68 of 78 Old 09-28-2012, 02:13 PM
bwaslo's Avatar
Quoted: 66 Post(s)
Liked: 182
Is there any objective evidence that enable does anything? Not being smart alecky, just wondering if there's some objective data out there somewhere.
Face2 likes this.
___________________________________________
DIY Synergy horn spreadsheet Synergy horn spreadsheet and pdf
XSim -free crossover designer and simulator XSim install file
Easy and cheap sound diffusers (the "Depot Diffusers") making easy DIY depot sound diffuser-panels-step by step.html
SmallSyns - point source controlled directivity in a manageable size SmallSyns
bwaslo is offline
post #69 of 78 Old 10-03-2012, 07:34 PM
eXa
eXa's Avatar
Im fairly new to Unity/synergy so ive been reading several build threads lately (it passed seos as my #1 do want).
What seemes to be a rule of thumb is that they place the holes close to the corners in the horn because there is where it affects the CD the least, since the corners is where the horn loads/affects the CD the least.
And if your original holes didnt affect the CD very much, wouldnt it be a good idea to keep them and then use some small holes too, where ever you find that they affect the CD the least ofc.
Also, im curious as to why you choose closed back, instead of a small chamber behind the drivers ala Bwaslo? Or even a box ported into the horn ala Dag Johanson?
eXa is offline
post #70 of 78 Old 10-03-2012, 09:49 PM - Thread Starter
johnbomb's Avatar
Hey guys,
Sorry I'm just now responding.
Bill- I'm not sure what to believe regarding enABL. The white paper posts some measurement differences toward the end, but I don't know what to make of them.
eXa- My hole arrangement is the best way I could find to balance the response of the sealed back alpha 6 drivers and that of the BMS 4550 compression driver. There are likely better arrangements to be had. I changed the original port layout because I was getting distortion and extreme port air velocities at very high volumes. I chose the sealed back drivers because they are the most efficient of the drivers I've tested.
John
johnbomb is offline
post #71 of 78 Old 10-03-2012, 10:05 PM
eXa
eXa's Avatar
You seemed to get good results with the original holes EXCEPT when driven hard due to port noise. So i was think why not keep them 4 big holes since they dont interfere with the CD anyways, and then just add some of thoose smaller holes(will need less of them with the bigger original holes in place) to get the air velocity down?
eXa is offline
post #72 of 78 Old 10-03-2012, 10:41 PM - Thread Starter
johnbomb's Avatar
Woops, reread your first post- I missed that suggestion the first time (time for me to go to bed!). See the last graph in post #47, which shows a FR comparison of the original ports to that of one of the multi hole iterations. The original port arrangement is less efficient than the newer multi hole layouts. Adding smaller holes next to the original ports might work, but that adds design complexity. I can drill a pattern of 1/4" holes quickly once marked out, and I don't need a router to cut the back flanges- only a recess bit, which is much safer to use.
Also, I think that multiple small holes produce less port noise than a single port of comparable area, presumably secondary to increased laminar flow of air.
John
johnbomb is offline
post #73 of 78 Old 10-03-2012, 10:55 PM
eXa
eXa's Avatar
Yes, the swiss cheese aproach was clearly better for the mids, but screwed it up for the CD. Thats why i thought a combination would be good. Less smaller holes needed.
But yes, it would add to complexity, and create more work. And it may not even pay off, im just guessing here (purely based on the good results in the beginning).
eXa is offline
post #74 of 78 Old 02-13-2013, 06:07 PM
eXa
eXa's Avatar
Bump... just curious if there has been any progress?
eXa is offline
post #75 of 78 Old 02-14-2013, 12:23 PM - Thread Starter
johnbomb's Avatar
Not yet, but hopefully before too long. I've been working on my theater. Thanks for asking!
John
johnbomb is offline
post #76 of 78 Old 11-16-2014, 08:07 PM
martinq's Avatar
Quoted: 23 Post(s)
Originally Posted by johnbomb View Post
Not yet, but hopefully before too long. I've been working on my theater. Thanks for asking!<br><br>
John
Bump again, some good stuff in this thread. Any news?
Bombelman likes this.
martinq is offline
post #77 of 78 Old 11-28-2014, 09:29 PM - Thread Starter
johnbomb's Avatar
Hey guys- thanks so much for the interest. No news yet. However, I'm finally closing in on several projects, and as soon as I get back to this one, I'll start posting again. Hopefully soon!!
John
johnbomb is offline
post #78 of 78 Old 11-16-2015, 07:01 AM
Liked: 0
Any news?
Hi Mr. J. Bomb.
Any news on how the build turned out? Final pics? Final measurements? Which horn did you choose for complimenting the Unity horn below 350 Hz?
I am currently trying to figure out if I am going to build a couple of horns like yours. They are MAX fine! I plan to use them in small scale PA applications. Any advise/comments to that?
Loved to read this thread with all the comments and advise from many super experienced speaker builders!
BR
Peter
Peter Ricardo Poulsen is offline
