amp and box for diy 12w7 - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 50 Old 05-09-2012, 01:36 PM - Thread Starter
thomasy52's Avatar
I have no idea how to build a box I was going to go down to a local car stereo store and tell them what I'm wanting to do and have them make me a box.
thomasy52 is offline
post #32 of 50 Old 05-09-2012, 01:37 PM - Thread Starter
thomasy52's Avatar
What is PM
post #33 of 50 Old 05-09-2012, 01:40 PM
Mrkazador's Avatar
Quoted: 259 Post(s)
Liked: 387
Private Message
Click his username, Send Message, Send a private message
Mrkazador is offline
post #34 of 50 Old 06-01-2012, 05:56 PM - Thread Starter
thomasy52's Avatar
So I picked up a ipr 3000 for my amp. I went to talk to a local shop about making me a box and the told me that tuning my box to 20hz was to low and that 32hz would be better I really have no clue about making a box.
post #35 of 50 Old 06-01-2012, 06:59 PM - Thread Starter
thomasy52's Avatar
If I go with a sealed box do I need to worry about a hpf?
post #36 of 50 Old 06-01-2012, 07:08 PM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 220
Well of course a car audio shop isnt going to understand what you're doing. Give them the box dimensions you want and tell them to build it.
Sealed doesn't need a HPF for the reason's a ported sub does, it is possible you could need one if you're giving them to much power down low.
Jay1 is offline
post #37 of 50 Old 06-04-2012, 07:41 AM - Thread Starter
thomasy52's Avatar
I have been messing around with winisd and I just about have it figured out but how do I calculate for bracing?
post #38 of 50 Old 06-04-2012, 07:43 AM
Point Source
beastaudio's Avatar
Quoted: 3614 Post(s)
Liked: 2920
if you are going sealed, the bracing wont make a big enough difference to matter. assuming even moderate amounts of bracing, youll be just fine
beastaudio is offline
post #39 of 50 Old 06-04-2012, 11:23 AM
Mrkazador's Avatar
Quoted: 259 Post(s)
Liked: 387
http://www.hometheatershack.com/foru...me-calculator/
Use the box calculator for bracing, just enter the WxHxD and thats it. If you were to use a 2x4(1.5x3.5") that is 18" long as a brace, the volume that would take up is 1.549 liters.
post #40 of 50 Old 06-04-2012, 11:54 AM - Thread Starter
thomasy52's Avatar
Ok so if I account for the bracing and make my box a little bigger isn't it going to change my port size?
post #41 of 50 Old 06-04-2012, 12:01 PM - Thread Starter
thomasy52's Avatar
When building the box would I use a nail gun or would I be better off with screws?
post #42 of 50 Old 06-04-2012, 12:26 PM
kgveteran's Avatar
Quoted: 399 Post(s)
Liked: 144
Nailgun makes for smaller cleanup, screws are great, i dont use clamps
kgveteran is online now
post #43 of 50 Old 06-04-2012, 12:45 PM
Point Source
beastaudio's Avatar
Liked: 2920
Never used anything other than screws and good ole PL premium. works great but does add to some hole puttying if you are going for a really good looking box. nail guns seem like the next logical step though
post #44 of 50 Old 06-04-2012, 01:51 PM
Mrkazador's Avatar
Quoted: 259 Post(s)
Liked: 387
Bracing will affect tuning but not by much unless you go crazy with the braces. A simple crossbrace is only around 2-5l.
post #45 of 50 Old 06-04-2012, 02:53 PM - Thread Starter
thomasy52's Avatar
Does winisd give u port velocity? And what is acceptable?
post #46 of 50 Old 06-04-2012, 02:56 PM
Mrkazador's Avatar
Quoted: 259 Post(s)
Liked: 387
post #47 of 50 Old 06-06-2012, 06:33 PM - Thread Starter
thomasy52's Avatar
How would I connect speaker wire to the ipr 3000?
post #48 of 50 Old 06-06-2012, 07:32 PM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 220
Jay1 is offline
post #49 of 50 Old 06-07-2012, 06:07 PM - Thread Starter
thomasy52's Avatar
I am looking to possibly build a box on my own and was wondering if these specs would be ok.
5.80ft^3 tuned to 21Hz with a slot vent 3.5"x15"x47.5"
the box would be made with 1" MDF and be 24"W x 37"H x 15"D
post #50 of 50 Old 06-17-2012, 04:07 PM - Thread Starter
thomasy52's Avatar
I picked up some of the neutrik speakon NL4FX adapters and it has two positive connections and two negative so how do I hook my speaker wire up?
