DIY Speaker Stand feet advice - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 04-27-2012, 01:55 PM - Thread Starter
TVAddikt's Avatar
Quoted: 17 Post(s)
I am building the following stand
http://www.audiocircle.com/index.php?topic=89474.0
My speakers are located behind a false wall and an AT screen. The floor of the speaker area is going to be a piece of carpet or rug runner over concrete (no pad)
So I am looking for advice as to whether to use rubber bumps or spikes. I have been looking at the following rubber bumps because I have the tactile tranducers installed into my couches:
http://www.parts-express.com/pe/psho...00-876&scqty=8
Should I pickup some of these for the stands? These are pretty expensive for what they are, cheaper suggestions are also welcome, that will work for my situation.
TVAddikt is offline
post #2 of 2 Old 04-27-2012, 03:00 PM
A9X-308's Avatar
Quoted: 1322 Post(s)
Liked: 988
Why use either? Won't make any difference sonically.
Spikes and rubber feet (think hardware store) can be had cheaply enough if you do decide to use them.
A9X-308 is offline
