Slot port enclosures: successes and failures, please post... - AVS Forum | Home Theater Discussions And Reviews
 2Likes
post #1 of 40 Old 04-27-2012, 09:40 PM - Thread Starter
LTD02's Avatar
Quoted: 2553 Post(s)
Liked: 2888
Hey Folks,
There are many who are looking to build slot ported enclosures with as narrow of a port as possible.
Based on searching around, I have seen some comments like "keep it to a minimum of 2" height" or "don't go lower than an 8:1 width:height ratio", but I couldn't find any really good data to back those claims up, hence this post.
While WinISD models air speed based on cross-sectional area only, so it predicts the same results for a circle as a paper thick port so long as they have the same area, I suspect that this is missing something big.
It has been shown that port chuffing is more of a problem with higher tunings and higher air velocity, so that is not really what I am looking for here, just the missing piece of the puzzle that makes slot ports perform worse than round ports if they get too narrow.
If anybody can link up a study of varying slot port height and audible chuffing/whistling/noise, or even provide some anecdotes based on builds, that would be much appreciated.
Thanks in advance for your replies.
Listen. It's All Good.
LTD02 is offline
post #2 of 40 Old 04-28-2012, 05:14 AM
Bill Fitzmaurice's Avatar
Liked: 5687
The answer is friction. The air in a duct has significant friction with the duct walls within perhaps a quarter inch of each wall. If that high friction zone is a significant portion of the vent cross-section then chuffing will be more apparent and box tuning will be lower than otherwise.
Chuffing is more of a problem with lower tunings, as they result in higher port velocity.
Bill Fitzmaurice is offline
post #3 of 40 Old 04-28-2012, 08:51 AM - Thread Starter
LTD02's Avatar
Liked: 2888
hey bill, thanks for dropping in. i meant that chuffing is more audible at lower velocities the higher in the frequency response that one goes. anyways, since you have experimented with these quite a bit, any thoughts on the "8:1 rule of thumb" before the port is too narrow or any other thoughts?
i skipped school on fluid mechanics day, so i don't have even a rough guess at how laminar drag translates into turbulation that limits air flow in the port nor what the relative importance is of that effect vs. the turbulence created at the exit of the port because of the abrupt change in air presssure as the air exits the port.
i recall seeing a port at one time that had golf ball dimples in it in order to create surface turbulence and reduce the drag, but i don't think there were any measurements.
LTD02 is offline
post #4 of 40 Old 04-28-2012, 11:17 AM
RAWAC's Avatar
Slot ports LOVE them.
Once you have listened to a design with a slot port integrated properly over a flared port same design, the bass unloads very well behaved with the slot port.
Having built a few hundred slot port speakers the main key to the slot.
REAR wall area as well as a radius.
Make sure you have at least 1.5" from the slot to the rear wall for proper air speed.
As well on the slot port on the inside radius the slot port board.f you can add in a full radius around the board you use for a slot port.
Personally I use a sharp punch and yes dimple the radius on the inside of all my slot ports.As well I line the slot port board with a peel stick floor tile for vibration control.
RAWAC is offline
post #5 of 40 Old 04-28-2012, 12:52 PM
riverwolf's Avatar
Liked: 24
LTD, I too have seen the 1:8 "rule" (think it started with a JL "whitepaper"), but haven't found any supporting evidence. My own experience says it doesn't seem to matter. I'm currently running a pair of RSS315HF-4s in ~3.5 ft^3 each. Tuning is 17Hz based on the driver dip/port peak output measured by a Cross-Spectrum calibrated EMM6. Port is 1"x16"x{something} (HxWxL). The port is full cabinet width with a 90° bend to use the top, back, and side walls to form the port. I also don't use a rumble filter and the amp is -3dB at 10hz/3Hz depending on which mode I use. All of that said, I've never gotten any port noise or other apparent misbehavior. The in room measurements also track the WinISD model well once you squint enough to filter out the room effects. My port tuning did come in a bit lower than predicted...probably a combination of net volume possibly being slightly off from plan, a bit of R19 in the cabinet, and the virtual lengthening of the port caused by using the back wall of the cabinet. IIRC, I did shorten the as-built port about an 1" from the model to try to compensate for the virtual lengthening, but that was just my guestimate as there's no ROT to predict the change in tuning that I'm aware of.
BTW, in the photo, you see the cabinets, but at the time I was comparing a SVS 12.1 with the 315HF-4. Currently, both cabinets are running HF-4s.
-Brent
riverwolf is offline
post #6 of 40 Old 04-28-2012, 01:14 PM - Thread Starter
LTD02's Avatar
Liked: 2888
riverwolf, great post. any chance that you could run a 17hz sine wave through one of your enclosure(s) and let me know where you start to notice port noise? that would be some good data since you are running a relatively narrow port and have the gear to take a good measurement (of the spl levels).
LTD02 is offline
post #7 of 40 Old 04-28-2012, 01:37 PM
Liked: 5687
I've not found any ratio to be better or worse, it's just a matter of velocity versus the narrowest part of the cross-section, and unfortunately the best way to find out that it's too narrow is when you hear it chuffing. I try to avoid less than a 1.5 inch dimension, and that would be with a woofer. I wouldn't go less than 3 inches with a sub.
post #8 of 40 Old 04-28-2012, 01:40 PM - Thread Starter
LTD02's Avatar
Liked: 2888
thanks for the follow-up bfm.
LTD02 is offline
post #9 of 40 Old 04-28-2012, 03:45 PM
A9X-308's Avatar
Quoted: 1506 Post(s)
Liked: 1142
A cylinder is going to give the lowest surface area (port walls) to volume, and also the largest minimum distance between opposite sides. Air flow in a port is assumed to be laminar, and it will be to a large extent, until airspeed becomes high enough that the non laminar flow becomes a significant proportion of CSA and the air stops moving as a 'slug' in the port. This will to my thinking reduce it's ability to behave like you would expect for a helmholtz resonator and begin to compress, more so for slot as the side walls are closer together.
Flares at both ends would be useful for both slot and cylindrical ports to smooth the transition. B&W have done dimpled ports, but they were flared cylinders. Others may have used them too.
Bill's ROT's for dimensions sound OK to me, though I'd be more comfortable with 3 or 4 to 1 as a max.
The only advantage I see to a slot is to ease construction or to give a CSA not easily obtained in a common tube size.
“You are not special. You are not a beautiful and unique snowflake.” Chuck Palahniuk
A9X-308 is offline
post #10 of 40 Old 04-28-2012, 06:14 PM
riverwolf's Avatar
Liked: 24
I'll try to fit a test in, but it'll probably be a few days before it fits in the schedule.
FWIW, when initially built a few years ago (maybe even 5yrs, time flies), I compared and somewhat attempted to find the limits of the 315HF-4 and 12.1 by measuring each individually using the same room placement. I even placed myself and the off cabinet in the same locations to try to limit variable changes to the driver only. Similar to Ilkka's compression testing, I ran successively higher level sweeps listening for bad noises. I quit before hearing any port noise. Somewhat surprisingly given the claimed Xmax/Xsus of the TCS db500 (rumored to be leftover 12.1 stock), the 12.1 started making suspension noise at the low end of the REW sweep (10-20Hz range) while the 315HF was still dead silent, so I stopped there before either driver actually went clank*. Pretty sure I was getting just over 100dB average at the listening position from each for that final sweep level...DUT was corner loaded, ~14' to the measurement position. My notes say MV on the Onkyo 805 was at -1dB for the final sweeps, but that's kind of meaningless without knowing what the signal level coming from REW/laptop were. When I get around to this new test, I'll use Soho's test disc so the input level of the test signal is known.
*As a side note, the 315HF and 12.1 measured virtually identically on each sweep. We're talking <0.5dB variation.
-Brent
post #11 of 40 Old 04-29-2012, 12:33 AM - Thread Starter
LTD02's Avatar
Liked: 2888
don't blow up your drives for the test rw! just trying to correlate various models with real world results here...any data will be much appreciated.
alpha niner, roger your post and i would agree based on my own intuition.
some folks would push on the claim when you say, "though I'd be more comfortable with 3 or 4 to 1 as a max."
what is that based on? is there any data that suggests 4:1 is any better than 8:1?
LTD02 is offline
post #12 of 40 Old 04-29-2012, 12:56 AM
A9X-308's Avatar
Liked: 1142
Engineering gut response that I have learned to trust over the years. Other people can argue the point and/or build whatever they want, won't make any difference to me. I was saying what I feel comfortable building not issuing a fiat.
The cylinder is the standard and anything away from that will be a compromise to some extent for the reasons above. If a 6" cylinder gave you what you needed , then the same CSA rectangular would too, up until turbulence reduces performance. The closer the walls, the earlier in my view this will kick in limiting output near max and I don't see the point in building a compromise.
Not that I have, but it would be an interesting experiment. I have no ported designs in planning or under construction, so I won't be doing it.
A9X-308 is offline
post #13 of 40 Old 05-12-2012, 04:21 PM
riverwolf's Avatar
Liked: 24
Well, it took me a little longer than expected to get to it, but I finally had the house to myself and a few minutes to throw at setting up the measurement rig. I fed the pair of 315HF-4s the 17hz LFE test tone from Soho54's audio test DVD at Reference level master volume. Mic is 11 feet from the subs according to Audyssey MultEQ XT.
As shown in the attached RTA capture from REW, there was nothing but the 17Hz fundamental within at least 35dBs of the 17Hz peak. I only got smart and did the RTA cap on my last run (of several at full Reference plus a few at lower levels) and didn't think about widening the SPL range until the gear was put away and the data actually examined...sorry. REW's capture function didn't include the THD window, but it was running <2% when this was taken...though, I'm not sure if REW can accurately calculate THD when it doesn't generate the signal. As for what I heard, well there was a ticking sound that was either lead slap, suspension noise, or the interconnects inside the cabinet. There was a good breeze coming from the ports, but not anything I would interpret as "chuffing" the way I've read it described and the RTA would seem to support that. Subjectively, Reference (0dB MV) sounded the same as -10dB MV, only louder.
-Brent
post #14 of 40 Old 05-12-2012, 04:31 PM
riverwolf's Avatar
Liked: 24
BTW, if you're interested, here are the REW sweeps from that session. No smoothing applied, green=Audyssey ON, purple=Audyssey Off. Throw a little smoothing at it and the green curve nearly becomes a straight line. :-) As I said earlier, they measure pretty much the way WinISD predicted they should.
-Brent
post #15 of 40 Old 05-12-2012, 05:32 PM - Thread Starter
LTD02's Avatar
Liked: 2888
it seems that your port air speed is pretty low. my guess is that right now you are at only 11 m/s air speed at 17hz and may be why you aren't getting any port chuffing. it seems that a 1" port works up to that level at a minimum. while i don't want you to blow up your drivers, if you could turn up your system until you hit some chuffing, that might be useful. if you know the tuning frequency of your cabs, a sine wave right on the tuning frequency won't cause them to over go over excursion, but will be blowing maximum air out of the port.
thanks for kicking some really good data into the mix brent.
LTD02 is offline
post #16 of 40 Old 05-12-2012, 05:33 PM
Looneybomber's Avatar
Maybe check out this site.
http://www.subwoofer-builder.com/flare-testing.htm
The long and short is that flares help some, but can't compensate for an undersized port. Next is the audibility threshold is reached with a higher port speed as the ratio of cross sectional area to surface area increases. In layman's terms, chuffing will be more pronounced with a thin, wide slot port for the same port air speed.
YID DIY
Looneybomber is offline
post #17 of 40 Old 05-12-2012, 06:43 PM - Thread Starter
LTD02's Avatar
Liked: 2888
"In layman's terms, chuffing will be more pronounced with a thin, wide slot port for the same port air speed."
where did he show that? all his tests seem related to total cross-sectional area and roundovers, not the shape of the port.
LTD02 is offline
post #18 of 40 Old 05-12-2012, 09:29 PM
riverwolf's Avatar
Liked: 24
That's a negative, Ghostrider. Considering my typical playback volume is only -15dB to Reference, 0dB is as hard as I'm willing to push, especially since I'm not sure what was causing the ticking I was hearing. While tuning point represents minimum excursion, it also likely means maximum heat being sunk by the coil. And P-E doesn't put the 315HF's on sale for $100 any more like they did when I bought this pair so skirting the envelope of distructive testing is not in my budget.
Without knowing how much SPL I'm losing to distance, it's hard to guestimate where on the power curve I really am. And even then we're all trusting the models to be accurate regarding air velocity with excursion. Think Cantori's anemometer can measure port air speed? If we assume I'm losing only 6dB for distance (say 11'=4m for easy math), I'm getting more like 15m/s in the WinISD model. If the chuffing threshold is as low as some tend to believe and then made even worse by a 1:16 slot ratio, one would expect even your 11 m/s estimate to be producing some type of measureable unintended noise.
When I get time for another measurement session, I'll focus on the RTA more to try to find any "noise" being created by port turbulence. As it is now, any noise being created is more than 35dB down for me and would easily be masked by real world content.
-Brent
post #19 of 40 Old 05-13-2012, 04:35 AM
kgveteran's Avatar
Quoted: 487 Post(s)
Liked: 178
Wisound has a pretty neat idea with the ports all along the edge of the baffle. Check out some of his posts..
kgveteran is offline
post #20 of 40 Old 05-13-2012, 04:49 AM
Well, wait a sec, he does. As port diameter increase, cross sectional area increases more than surface area.
The noise limit of a 6" port has a higher (air velocity) noise threshold than a 4" port. The difference between them is the 6" port has a higher cross-sectional to surface area ratio. So, 2, 4" ports that have reasonably the same cross-sectional area as a 6" port, but will have the same noise threshold as a single 4" port. What's different between 2, 4" ports and 1, 6" port? Lower cross-sectional to surface area ratio. And skinny slot ports have a lower cross-sectional to surface area ratio. If A=B and B=C, A=C.
YID DIY
post #21 of 40 Old 05-13-2012, 01:12 PM - Thread Starter
LTD02's Avatar
Liked: 2888
"That's a negative..."
completely reasonable.
"If the chuffing threshold is as low as some tend to believe and then made even worse by a 1:16 slot ratio, one would expect even your 11 m/s estimate to be producing some type of measureable unintended noise."
agree. your estimation of 15 m/s is just as good of a guess as mine btw. this is why i like your data, it is kind of blowing up the 1:8 rule of thumb.
"Wisound has a pretty neat idea with the ports all along the edge of the baffle."
i follow his builds and threads and like his approach. he tunes a little higher for p.a. and he doesn't mind dumping a ton of power into his subs, so perhaps he will weigh in.
"The noise limit of a 6" port has a higher (air velocity) noise threshold than a 4" port. The difference between them is the 6" port has a higher cross-sectional to surface area ratio."
i'm not completely sure that i follow what you are saying bomber. the 6" port also has more plain vanilla cross sectional area (2.25 times), so will flow better than a 4" port. did he compare two fours vs. a six? i haven't read through his work in a while.
LTD02 is offline
post #22 of 40 Old 05-13-2012, 05:18 PM
WiSounds's Avatar
Biggest thing I have yet to do is an impedance sweep to determine cab tune. I was targeting 30hz. I have had several makes and models of driver in the bottom subwoofer cabs and they all have sounded awesome, 18s and 21s. No noticeable/audible chuffing. If sidewall friction lowers the tune, I'm all for that.
Here are a few examples of slot ports I have worked successfully:
Originally Posted by Bill Fitzmaurice:
It's also the very sort of Voodoo Engineering that should never be done.
WiSounds is offline
post #23 of 40 Old 05-31-2015, 09:22 PM
Liked: 0
The resonance in a port is due to the Helm Holtz resonance. Wikipedia is a good read on this topic. Did anyone ever get to low in the port tuning frequency to the point that the resonance started to show up in the used frequencies? How far away from the crossover point was this?
SaltyPaws is offline
post #24 of 40 Old 06-01-2015, 05:34 AM
JackNC's Avatar
Quoted: 141 Post(s)
Liked: 39
I read the thread and heard the theory that chuffing was due to friction with the walls of the slot.
Thus it makes sense to look at the ratio of area of the opening to its perimeter, for a constant length, and normalized to a height of 1
This is another way of saying cross-sectional area to surface area
For a circle, I get pi r squared/ 2pi r = 1/2
for a square, I get r squared / 4 r = 1/4
For a slot, I get N/(2N+2), where N is the aspect ratio
for N = 1, 2, 3, 4 ... I get:
.25, .33, .375, .4 heading towards .5 as an asymptote
That a narrow slot tends towards the same ratio of perimeter to area of a circle is counter-intuitive until/unless you recall the derivation of the formulas for area and perimeters of a circle. These involve dividing the circle into wedges, flipping every other one over end for end, laying them out side by side and then taking the limit as the number of wedges approaches infinity.
If chuffing results from some sidewall related effect, than slot aspect ratio matters a little, for low aspect ratios, but not much.
I would expect things to get progressively worse as the aspect ratio increased and that isn't the case for this metric so I don't think this ratio is a good indicator of slot performance.
Perhaps slot aspect ratio doesn't matter until the slot gets so narrow it starts to show some resistance effects. This would be highly non-linear, no doubt.
JackNC is offline
post #25 of 40 Old 06-01-2015, 07:14 AM
Bassment's Avatar
Quoted: 946 Post(s)
Liked: 379
In my opinion, I don't think the dimensional ratio matters, it's all about keeping the resonant frequency out of the audible range of the speaker, and minimizing air speed.
Bassment is offline
post #26 of 40 Old 06-01-2015, 08:20 AM
the-jessman's Avatar
Quoted: 30 Post(s)
Liked: 52
I build a lot of car audio subwoofers, most of those being a slot port design. Due to space constraints, high port velocities are pretty common in the car audio world. My experience is you can get away with a lot of less-than-optimal port configurations as long as you keep port velocity low. Air resistance quadruples every time velocity doubles, so keeping velocity down makes a HUGE difference.
With the boxes I build I try to keep the aspect ratio as low as I can, Under 1:4 is ideal. If I get above that I'll compensate by added some more port area. Here is a formula I use to compare the flow efficiency of a slot port to what a round port would be:
"Nothing prevents people from knowing the truth more than the belief they already know it."
"Making bass is easy, making music is the hard part!"
My Audio Facebook page - http://www.facebook.com/triticumaudio
Instagram: http://instagram.com/triticumaudio
the-jessman is offline
post #27 of 40 Old 06-02-2015, 12:05 AM
Liked: 0
LTD, from trawling through the various threads, I think you can be called the resident slot port guru. At the moment, I know just enough to cause serious damage, and not enough to properly understand the trade offs. Let me summarize the info you used in the varius posts and please correct me if I am wrong:
1) WINisd does not correctly model for slot ports. Take the WinISD port and reduce the length by 10-15% (any chance we can pin this number down further), to get the physical port length, as measured through center. Is this value correct for Marty subs, or all slot ports in general.
2) When lengthening your port, the 1st port resonance will creep up on you. When modeling the Marty subs, I get a value close to 160 Hz for all of them. Does this mean you lowered the tuning frequency as far as you could till you set the port first resonance frequency to 160 Hz? 160 Hz is one octave above 80 Hz, the typical X-over setting. Does this mean you can lower the tuning of your box when you are planning to X-over at e.g. 50 Hz?
3)What trade off are you making with regards to port velocity? Do you keep max velocity below 23 m/s at max power?
post #28 of 40 Old 06-02-2015, 12:24 AM
notnyt's Avatar
Quoted: 2791 Post(s)
Liked: 2573
@SaltyPaws my bigass subs have a first resonance at 108hz, no audible effects, can barely see it in a spectograph. WinISD also nailed the port length in my subs. Some people fail to compensate for the outer wall effectively lengthening their port, as well as their floor if the port is on the floor.
SaltyPaws likes this.
notnyt is offline
post #29 of 40 Old 06-02-2015, 04:40 PM
More is Better's Avatar
Quoted: 620 Post(s)
Liked: 344
What freq are you crossing them at and what slope?
More is Better is offline
post #30 of 40 Old 06-02-2015, 04:45 PM
notnyt's Avatar
Liked: 2573
80hz or 90hz depending on content, LR4
notnyt is offline
