LMS Ultra 5400 voice coil - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 04-29-2012, 02:40 PM - Thread Starter
harrikuk's Avatar
Hi,
I received my LMS Ultra 5400 earlier this week, but I noticed a weird gap in the "pipe" inside the voice coil, it doesn't wrap completely around.
As I don't really have much experience with subwoofer drivers I don't know if that is normal or not. Should I contact TC Sounds about it, or is that gap supposed to be there?
harrikuk is offline
post #2 of 5 Old 04-29-2012, 03:41 PM
BassThatHz's Avatar
Quoted: 2040 Post(s)
Liked: 1570
Originally Posted by harrikuk View Post
Hi,
Supposed to be there. If it was whole it would have higher back EMF as it would be a solid circular conductor.
BassThatHz is online now
post #3 of 5 Old 04-30-2012, 01:23 AM
DL86's Avatar
Mine has the same. I have had no problem whatsoever.
To improve the black level performance of your projector: Shine bright light into your eyes every 5 minutes.
DL86 is offline
post #4 of 5 Old 04-30-2012, 01:41 AM
notnyt's Avatar
Quoted: 2178 Post(s)
Liked: 2000
notnyt is offline
post #5 of 5 Old 04-30-2012, 07:21 AM - Thread Starter
harrikuk's Avatar
Thank you very much for the information, big relief
My plan is to build most likely a ~85-100 liter sealed box for the sub. But I'll borrow an existing suitable thread (or make a new build-thread) once I get those designs sorted out.
harrikuk is offline
