Running Cable - AVS Forum | Home Theater Discussions And Reviews
Old 04-30-2012, 09:23 PM - Thread Starter
BirdRider's Avatar
I'm wondering what the easiest (but still professional) way to route cable to my rear speakers. Here is the room. Behind the TV and to the right of the tv is the outside of the house. There are doors on both sides of the room so running it inside the base molding is out. I'm thinking about just going strait outside and running the cable out there. Is this a bad idea? Would I need a special type of cable for this?
BirdRider is offline
Old 05-01-2012, 01:09 AM
A9X-308's Avatar
Quoted: 1307 Post(s)
Liked: 971
If you're going to run it outside, I'd put it in a conduit for mechanical and environmental protection.
A9X-308 is offline
Old 05-01-2012, 01:20 AM
LTD02's Avatar
Quoted: 2344 Post(s)
Liked: 2583
+1 to what alpha niner said if you go that route.
there are some "flat" cables that are designed specifically to be run underneath carpet. a search on "flat speaker wire" pulls up many results.
Listen. It's All Good.
LTD02 is offline
Old 05-01-2012, 05:10 PM
poormanq45's Avatar
You should get your walls and floor checked. They're all really warped!
poormanq45 is offline
Old 05-01-2012, 08:06 PM
Bill Fitzmaurice's Avatar
Liked: 4700
Add cove molding at the wall/ceiling joints. It would dress the room up too.
Bill Fitzmaurice is online now
Old 05-01-2012, 08:11 PM
Quoted: 3269 Post(s)
Liked: 2751
Flat wire under the carpet.
Old 05-01-2012, 09:11 PM
Drew Eckhardt's Avatar
What's downstairs and upstairs?
Drilling a hole in the toe plate and running wire through floor joists is easy with a basement and wouldn't be too hard with a crawl space although you'd want knee pads, long sleeves, and a head lamp.
Fishing up through a wall into a crawl space beneath the roof is pretty easy too and there's often enough room to stand up there. Wear long sleeves and pants and stay away from fiberglass insulation - that stuff itches.
That would look bad.
Drew Eckhardt is offline
Old 05-02-2012, 07:27 AM
fschris's Avatar
Quoted: 18 Post(s)
running it outside is a bad idea. get a gang plate behind TV and fish the wires from the attic.
ASROCK H67 GE / HT/Core i3
Emotiva XPA2 Gen2 x2
Carver AV-705 5Channel AMP
Zaph 2.5MM TT'S DIY
Emotiva UMC 200
2 x MFW 15 Clones DIY
fschris is offline
Old 05-02-2012, 03:06 PM
Mrkazador's Avatar
Quoted: 253 Post(s)
Liked: 378
You would have to remove some drywall so the wire fits behind the baseboard.
Attachment 245318
I think this is the best way to go about it if you have no attic, crawl space, or basement. No drywall patching and best looking IMO. The rear speakers might be a little close to the seating area because you would set one up right next to the door molding. If you don't mind it, you can set one high above the door close to the ceiling angled down.
Attachment 245319
Mrkazador is offline
