Strangest hum in speakers... - Page 2 - AVS Forum | Home Theater Discussions And Reviews
Old 05-03-2012, 11:04 AM
garciab's Avatar
Quoted: 145 Post(s)
Liked: 61
I admire and advocate humor in most cases. I feel often enough some of mine gets lost in translation, but regardless I enjoy a good laugh just about anytime. Ive gotten some great ROFL's off this site over the last year.
I chuckle every time I read the comment about European models in your sig.
bg
garciab is offline
Old 05-03-2012, 11:20 AM
Point Source
beastaudio's Avatar
Quoted: 3703 Post(s)
Liked: 2979
Haha, I chuckled first time I saw that in my AVR's manual and just knew it had to go in the sig. All too appropriate!!! thx
beastaudio is online now
Old 05-04-2012, 06:06 AM
Warpdrv's Avatar
Can you pull the driver and put some shielding around it.
There was a reason there used to be shielded speakers back when CRT TV's were the norm.
Perhaps worth giving it a try.
Warpdrv is offline
Old 05-04-2012, 07:45 AM
Bill Fitzmaurice's Avatar
Liked: 5124
To prevent color distortion on the CRT screen.
Bill Fitzmaurice is online now
Old 05-04-2012, 08:44 AM
Warpdrv's Avatar
10 years ago, I used to live in an apt, that butted up against the freeway....
Installed my ht system and was enjoying the first listening session, when all of a sudden ---- my speakers maxed out with the sound of ---- wait for it....
Truck drivers on their CB's.... clear as day at 100db's....
Scared the *#$& outta me...
My speaker wires were picking up the CB's like an antenna, with their gains...
I ended up running the speaker wires through some 1/2" conduit and problem solved....
Obviously not the same here, but a lesson learned...
Warpdrv is offline
Old 05-04-2012, 01:07 PM
s_carter's Avatar
probably just a ghost haunting your house - no biggie.
Sam Carter
Custom Sounds NW
Custom enclosures, service and installation of mobile electronics and home theater equipment.
Featured in CAE
My Home Page
DIY Dual 18" Sub Project (MK II)
s_carter is offline
Old 11-01-2014, 03:50 PM - Thread Starter
Fatshaft's Avatar
Quoted: 591 Post(s)
Liked: 905
OK...I just had to revive this thread cause I finally found the problem
Maybe this might help someone later on...
I have since tried everything. Had mediums come to my place = No ghosts
placed garlic in every corner of the house = No cure
No electricity close by my house...dug all around my house...no bones. no electrical wires anywhere.
Had scientists come to my house...they did tests for 3 days and couldn't find anything...
All kidding aside. I finally found the problem.
I decided to remove the ground connection to my water pipe and BINGO no more humming in my speaker (When speaker IS NOT CONNECTED)
My right speaker is close (about a foot away) from the incoming city water pipe.
It's been disconnected for a few months now and NEVER got a hum since!
My Build Thread
Equipment Speakers:
3x 1099's for LCR duty
4x Fusion 8's for surround duty
8x subs: 4x FTW21's and 4x SI18's
Fatshaft is offline
Old 11-02-2014, 08:12 AM
Samps's Avatar
Quoted: 831 Post(s)
Liked: 458
If that was the ground for your main panel it's probably not a good idea to disconnect it. You should look into that before you burn up all your electronics or your house down.
Samps is offline
Old 11-02-2014, 04:21 PM
cw5billwade's Avatar
Quoted: 328 Post(s)
Liked: 184
Agree that is very bad you need to see if the power entry panel by the meter has a grounding rod or if that wire ran too the power entry panel
cw5billwade is offline
Old 11-02-2014, 04:29 PM
kingpin111's Avatar
Quoted: 289 Post(s)
Liked: 275
kingpin111 is offline
