MK MX-350MKII Subwoofer comparable.. - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By stormwind13
post #1 of 15 Old 05-02-2012, 08:25 PM - Thread Starter
Audiophile34's Avatar
I saw a link to subwoofer, thought, that sounds like a nice sub, dual 12's, 600 rms amp.. then saw MSRP of 2600$ and thought WTF?????
All kidding aside, what in the DIY world would be comparable?
They tout the "push pull design" as being paramount to the performance of this sub..
I think (maybe incorrectly) that there are many DIY options that would eat this sub alive.
What do you senior AVS members think about this?
thanks,
Jared
My first DIY project. A dual, dual opposed setup
www.avsforum.com/avs-vb/showthread.php?t=1345494
Audiophile34 is offline
post #2 of 15 Old 05-02-2012, 09:06 PM
stormwind13's Avatar
Quoted: 60 Post(s)
Liked: 96
there are many many diy and ID offerings that would destroy that sub at that price point.
the submersive @ $2,295 + shipping (typ. $135-160 ground shipping cost) would decimate that sub.
captivator, chase ss-18.2 would be better as well.
In the diy realm, the f20, anarchy horn, and many many others come to mind.
Drexler likes this.
stormwind13 is online now
post #3 of 15 Old 05-03-2012, 05:03 AM
LTD02's Avatar
Quoted: 2340 Post(s)
Liked: 2573
"I saw a link to subwoofer, thought, that sounds like a nice sub, dual 12's, 600 rms amp.. then saw MSRP of 2600$ and thought WTF?????"
i've always liked the way that sub looks. $2600 is a little rich, especially today, for that level of performance. that sub was sold at retail, which includes two levels of profit markup (one by the retailer, one by the manufacturer) the push-pull design is to help linearize non-linear drivers and isn't really needed if you are using good drivers. the epic 12 would be a nice driver to use for such a build.
the challenge with diy is that sealed subs rolloff and so typically need some eq on the bottom end in order to produce a flat response. that requires power and moves the drivers quite a bit, either of which could damage the driver. enter the frequency dependent limiter. this is a protection device that recognizes when the system is pushed too hard and simply "limits" the amount of power and the amount of excursion. most diy folks don't use limiters though and choose instead to use an amp that will run out of power before damaging the driver from over excursion and just keep an eye on the clip light on the amp to ensure that the driver isn't being fried with direct current that comes out of clipping amps.
so to beat the performance of the mk sub in the same form factor, two of the epic 12" drivers, a professional rack amp with about 1000 watts per channel, and an eq device will set you back about $800 + the price of the enclosure.
btw, there are other designs that will get you more bang for the buck, but the enclosures tend to be larger.
Listen. It's All Good.
LTD02 is online now
post #4 of 15 Old 05-03-2012, 08:23 AM
Quoted: 60 Post(s)
Liked: 96
Exactly. I think 1 f20 would trump that mk. However the enclosure is about 3x the size. I used to have a mk mx5000thx, and was easily able to outdo it with the chase ss18.2 I replaced it with.
post #5 of 15 Old 05-03-2012, 02:53 PM
pgwalsh's Avatar
Quoted: 392 Post(s)
Liked: 284
thanks,
Jared
I own that sub and it sits in my closet. I built my own sub(s) and I have much better bass for my largish room. However my build may not be normal. I have one Maelstrom 21" and 2 dual opposed MFW 15's.
Diy Sound Group - Information & Tips
Builds: Maelstrom 21 Ottoman Build, Dual Opposed MFW's x 2, Statements, SEOS-12/TD12M x 5.
pgwalsh is offline
post #6 of 15 Old 05-04-2012, 03:09 PM
pennynike1's Avatar
Quoted: 289 Post(s)
Liked: 127
I used to own a M&K MPS-5410 subwoofer. A 400 watt push/pull design akin to the M&K MX-5000THX home version. That sub was fantastic. Now that I have sold that sub, I am looking at JTR and Seaton subwoofers. If you are looking for a DIY sub, the LMS 5400 is a great 18" driver.
WTB: Gently used Trinnov Altitude 16-24 or 16-32. WTB: Gently used JVC DLA-RS4500 or Sony 5000ES
pennynike1 is online now
post #7 of 15 Old 05-05-2012, 02:00 AM
A9X-308's Avatar
Quoted: 1280 Post(s)
Liked: 951
thanks,
Jared
Looks well overpriced to me.
From the pics I found, there doesn't seem to be much of a surround, so I'd guess less than 15mm of Xmax. An IXL18, EP amp and MiniDSP would likely exceed it in output. Make it a pair of IXL18 in push pull and you'll get the potential distortion reduction of even harmonic components and definitely exceed this in output. Probably for not much more than a thousand dollars and some time.
A9X-308 is offline
post #8 of 15 Old 05-05-2012, 07:14 AM
Martycool007's Avatar
Quoted: 280 Post(s)
Liked: 176
I had an M&K MX-250 and absolutely loved it. I have a buddy that has an HSU vtf-15 and the M&K sounded equal, in terms of sound quality. The M&K sub had a hell of a thump, and, would get down very low. I believe the M&K sub would go down a bit lower than an F-20. My M&K would hit 16hz in my small room.
Martycool007 is offline
post #9 of 15 Old 05-05-2012, 02:04 PM
Quoted: 60 Post(s)
Liked: 96
no doubt it would go lower then the f20, it's not designed for <20hz use. Sheer output though, I'd say they are very different.
post #10 of 15 Old 05-05-2012, 03:27 PM
LTD02's Avatar
Liked: 2573
"no doubt it would go lower then the f20, it's not designed for <20hz use. Sheer output though, I'd say they are very different."
so what you are saying is that there are tradeoffs? brilliant.
LTD02 is online now
post #11 of 15 Old 05-05-2012, 05:52 PM
pgwalsh's Avatar
Quoted: 392 Post(s)
Liked: 284
Being an MX-350 owner and having built a setup with multiple subs for less, I'd rather have my new setup than the mx-350 any day. There's no comparison in spl and frequencies reached. It's in the closet for a reason. So you can do better with DIY for less.
pgwalsh is offline
post #12 of 15 Old 05-05-2012, 08:21 PM
zora's Avatar
Quoted: 48 Post(s)
Liked: 51
Look for old posts about M&K subs. It comes up all the time. I've never understood the fascination with their subs (past the late 70's and early 80's when they were one of the few choices for stand alone subs), especially given the price points. They are simple designs that are well-engineered, but nothing special.
JP
zora is offline
post #13 of 15 Old 05-06-2012, 02:00 AM
LTD02's Avatar
Liked: 2573
"I've never understood the fascination with their subs (past the late 70's and early 80's when they were one of the few choices for stand alone subs)..."
that is probably a big part of the fascination, as they were one of the first and that leads to nostalgia.
something however needs to be cleared up.
!!!M&K DID NOT INVENT THE FIRST SUBWOOFER!!!
the earliest system to employ a subwoofer, though admittedly a humble one, was the compass triphonic system in 1968.
now their 'subwoofer' probably produced less actually output than some of the system going back to the 1930's, but as far as i can find, it was the first company to consider the idea of a stand alone sub.
LTD02 is online now
post #14 of 15 Old 05-06-2012, 02:13 PM
zora's Avatar
Quoted: 48 Post(s)
Liked: 51
Good points, that is why I said "one of the first" component subwoofers
I also think their push-pull design was impressive to many consumers that did not understand the concept.
zora is offline
post #15 of 15 Old 05-06-2012, 02:23 PM
LTD02's Avatar
Liked: 2573
oh, i wasn't pointing the finger at anybody here...
my comment was based on the repeated claims on the m&k website.
LTD02 is online now
