How are you guys finishing your Baltic Birch projects? - AVS Forum | Home Theater Discussions And Reviews
Old 05-06-2012, 07:48 AM - Thread Starter
tundrSQ's Avatar
I finished by subwoofer...baltic birch...it came out pretty nice, but now i am going to try and not screw it up with a crappy stain job.
Pictures and technique would be appreciated...thanks!!
Tim
tundrSQ is offline
Old 05-06-2012, 11:36 AM
DiscoDuck's Avatar
Quoted: 14 Post(s)
Some people use a stain with clearcoat and many use various finishes of black. Some even use bedliner textured black. I'm starting a plywood pair of boxes next week and it will probably go black with a clear finish but I'm not going for piano glossy black lacquer. I have considered using a fomica type laminate because it is so durable and relatively easy to apply. My room thus far is all utilitarian and I want the speakers to disappear so black is my choice.
Sr7009 + external amp for 9.3.4
jbl - northridge x11; sp6cii ceiling
Dayton HF15 sealed x2 on xls1500
av123 mfw15 w/ bash 300
DiscoDuck is offline
BassThatHz's Avatar
Quoted: 2036 Post(s)
Liked: 1568
I recommend practicing on scrap pieces first.
Lots and lots of uber-fine sanding.
I use a pneumatic sander, polisher, air gun.
Marine quality woodboat supplies is ideal.
BassThatHz is offline
Old 05-06-2012, 12:00 PM
Hot Grits's Avatar
Might want to try applying stain per conditioner before staining your samples. Helps to evenly distribute the stain so it doesn't get blotchy.
Hot Grits is offline
Old 05-06-2012, 02:59 PM
Drew Eckhardt's Avatar
Shellac rubbed down to a satin finish with synthetic steel wool. With miter joints so the plies don't show and hardwood lumber edges for accents.
_Definitely_ experiment with scrap first.
Drew Eckhardt is offline
