DIY sub - Page 4 - AVS Forum | Home Theater Discussions And Reviews
post #91 of 112 Old 02-15-2013, 04:42 PM - Thread Starter
niners's Avatar
First off i want to thank everyone for their help to this point. i am not sure i would have done it without all the input. This is a greatr community.
with that i finally have everything and the box is built but unpainted. i went with the following:
mini dsp
ep4000
6 cubic foot 5.5 cubic foot box
uxl 18 by mach 5
i have one last question i am hoping to get help with and thats the mini dsp.
can i just change the low pass cut off filter at 100 and then hook it up? the mini also has a dc in plug so i assume i have to buy a power supply as well.
niners is offline
post #92 of 112 Old 02-16-2013, 11:35 AM - Thread Starter
niners's Avatar
so i tried and hooked everything up today accept the mini dsp as i don; thave a 12 volt source yet.
I hope i have something wrong with the set up as i would say it doesn;t sound as good as my current sub.
here is how i have it hooked up as of now
the sub out is conected to the ep4000 via a modified xlr to rca cable and i have it set on the bridge mono mode with only switch 1, 6 and 7 turned on.
i but the gain almost to the max and the anthem at my regular level and you can hardly hear the sub.
any ideas as too what might be wrong?
niners is offline
post #93 of 112 Old 02-17-2013, 06:40 AM
NicksHitachi's Avatar
Quoted: 182 Post(s)
Liked: 192
Set dipswitches:
1 l
2 l
3 r
4 r
5 r
6 l
7 l
8 r
9 l
10 l
If using two input channels then 4 and 5 to the left
unhook subs speaker wire from amp, turn amp front attenuator knobs to max, set AVR to your listening level, turn put in heaviest bass movie you got, see if clip lights come on, if not increase sub gain on AVR until clip lights come on during bass heavy seq, then turn AVR gain down ~3db. If you cant keep clip lights out with avr sub gain setting, use the attenuator knobs on amp.
This is very quick and dirty "gain" structure setting, but you should search and read gain structure to do it proper. You must keep the clip light out.
NicksHitachi is offline
post #94 of 112 Old 02-18-2013, 05:16 PM - Thread Starter
niners's Avatar
Thanks for the insights.
It works great. Now too the fun part the boxes finish.
niners is offline
post #95 of 112 Old 02-20-2013, 11:34 AM
caper_1's Avatar
Liked: 26
HT: Yamaha RX-V565 | 3 X Energy Take FPS, 2 X VS Surround, 2 X Take LCR | DIY Subs: SDX12 APR15 & TRIO12 Dual APR 12's | 47" LCD
Music: Yamaha RX-V863 | 2 X Energy RC-70 | MA RXw12 Sub
Bathroom: 2 X Energy Take LCR
Car: Sony Xplod HU, Xplod 6X9s, Kenwood 4"s, Alpine 12" Type-S, Rockford Amp,...
caper_1 is offline
post #96 of 112 Old 02-20-2013, 05:33 PM
HuskerOmaha's Avatar
Quoted: 66 Post(s)
Liked: 56
HuskerOmaha is offline
post #97 of 112 Old 02-25-2013, 06:02 PM - Thread Starter
niners's Avatar
I picked up the roll on Duratex today and will post picks soon.
Do you clear the duratex?
How can I text the subs performance once complete?
niners is offline
post #98 of 112 Old 02-25-2013, 07:18 PM
caper_1's Avatar
Liked: 26
No need to clear it. 2 coats usually does the trick. You can sand lightly between coats, and even after 2nd for the texture you prefer.
caper_1 is offline
post #99 of 112 Old 02-25-2013, 07:31 PM
N8DOGG's Avatar
Quoted: 1116 Post(s)
Liked: 1218
You can also add a bit of water to the duratex to make the texture finer. It about 5% water to thin it out.
N8DOGG is offline
post #100 of 112 Old 02-26-2013, 05:36 AM - Thread Starter
niners's Avatar
I am worried as I thought I read for a sealed box you could go with 5cf.
So I made it that size.
When I reread it sounds like it's not ideal
What can I expect and am I safe to run full out with the ep4000
niners is offline
post #101 of 112 Old 02-26-2013, 12:42 PM
Quoted: 182 Post(s)
Liked: 192
Whats the ideal volume? If you need smaller you can always close off some of the interior volume and make it effectively smaller. If you need bigger you'll need a board stretcher.wink.gif
Too small = Safe but less efficient in lower FR
Too big = more risk of mechanical damage to driver from overexcursion(assuming excursion not power limited). Greater LF efficiency.
post #102 of 112 Old 02-27-2013, 07:32 PM - Thread Starter
niners's Avatar
I think I might have the world's only board stretcher.
If it works awesome.
,I have no idea on ideal size as I don't have winsd.
I am going to download however reality is its done
So the question is how do I test the result.
Any input is appreciated
niners is offline
post #103 of 112 Old 03-11-2013, 04:15 PM - Thread Starter
niners's Avatar
Finally going to upload some pics... still not 100% complete but getting there. FIrst coat of black paint on the majority as well as the grill somehwat made. will be duralex on next
will upload final pics once complete this weekend. back 8k .jpg file front view.jpg 8k .jpg file sideview.jpg 7k .jpg file
ID:	67817   Click image for larger version
ID:	67818   Click image for larger version
niners is offline
post #104 of 112 Old 03-11-2013, 04:34 PM
Quoted: 182 Post(s)
Liked: 192
Looks nice should be a nice little sub!
post #105 of 112 Old 03-11-2013, 05:48 PM
Jon S's Avatar
Quoted: 926 Post(s)
Liked: 303
Kinda hard to see those 8kB pics... they show up in a little 1.5" x 1.5" square on my monitor...
If it's not a BIG screen, it's not a theater...
Jon S is offline
post #106 of 112 Old 03-11-2013, 06:25 PM - Thread Starter
niners's Avatar
Is there a better way to upload them
niners is offline
post #107 of 112 Old 03-13-2013, 02:57 PM
Jon S's Avatar
Quoted: 926 Post(s)
Liked: 303
same way, just use a larger file... usually 100-200kB would suffice.
Jon S is offline
post #108 of 112 Old 03-14-2013, 06:11 PM - Thread Starter
niners's Avatar
Should I put insulation in the box? If so what would it do to the sound
niners is offline
post #109 of 112 Old 03-15-2013, 02:19 AM
LTD02's Avatar
Quoted: 2553 Post(s)
Liked: 2888
the primary reason for stuffing an enclosure is to reduce resonances. these tend to be mostly out of band though for smallish subs.
Listen. It's All Good.
LTD02 is offline
post #110 of 112 Old 03-16-2013, 08:34 AM - Thread Starter
niners's Avatar
Thanks LTDO2. I don't bother with stuffing the box.
I am almost finished and ready to fire up this project. I was hoping for some mini dsp help.
It's running the sub only.
Any thoughts or help to set this up or direction to a guide would be awesome
On the input gain do I leave at zero
Parametric eq - filter type peak. Low self or high self?
Frequency
Gain
Q
Cross over : low pass
Cut off frequency
Filter type
Bypass filter
High pass
Cut off
Filter type-
Bypass-
Parametric eq output 1:
Filter type
Frequency
Gain
Q
Delay / gain / rms:
Output
niners is offline
post #111 of 112 Old 03-16-2013, 10:01 AM
LTD02's Avatar
Liked: 2888
"What can I expect and am I safe to run full out with the ep4000"
it would be wise to run the 4 ohm driver off of one channel for 650 watts in your 5 cubic foot enclosure, at least until you get a good sense for what the sub can handle.
650 watts should get you right up near xmax at 15hz and below.
LTD02 is offline
post #112 of 112 Old 03-16-2013, 10:21 AM - Thread Starter
niners's Avatar
So I finally got the sub together the only thing left is to put the grill on.
I will start off by thanking everyone for their support answering all my crazy questions during this build. I must say the UXL in the 5FT3 box with the EP400) sounds better then I expected.
I am not certain I have the mini dsp hooked up right but will continue to look for a guide to better understand that thing.
Some pictures of the finished box. IMGP5173.JPG 3773k .JPG file IMGP5174.JPG 3886k .JPG file IMGP5175.JPG 3683k .JPG file
ID:	67909   Click image for larger version
ID:	67910   Click image for larger version
niners is offline
