First DIY -2 Ported 3.6cuft 12" Subs - AVS Forum | Home Theater Discussions And Reviews
post #1 of 31 Old 05-08-2012, 09:21 AM - Thread Starter
randyc1's Avatar
Quoted: 238 Post(s)
Liked: 40
After month's of reading threads on the Subwoofer & DIY forums i finally decided to build my own.
These subs will be replacing my (kef cube 2) subwoofer, which did a decent job I found,.. but I never had enything alse to compare to.
I wanted to thank all the forum members who answered countless questions and especially "Mayhem13" , who has basically designed the Subs & guided me from the beginning!!
Each Sub will have 3.6 cuft net and will have a Dayton RSS315 HO-44 Driver ,tuning will be 18hz and both will be powered by a Dayton SA1000.
I built a table "Sled" ,to be able to cut precisely lengths of MDF that extend further than my table fence .
Another tool that i bought is the Digital angle meter , great little tool that makes setting your saw angle, simple and very precise ( 1/10 of a degree)
Front baffle of the subs will be on a angle of 81.5 degree's and the Subs will be used as stands for the bookshelf's that will be built latter !!
I Finally got started mayhem !!
randyc1 is offline
post #2 of 31 Old 05-08-2012, 09:29 AM
guns&motorcycles's Avatar
I'm looking forward to seeing how these turn out. I've been reading quite a bit on this forum as I mentally plan out my first sub build. There are some incredible builds here, but I want my first build to be a simple design that will come in at a reasonable cost (but still perform well enough). This project looks right up my alley.
Do you have plans you can post?
guns&motorcycles is offline
post #3 of 31 Old 05-08-2012, 08:26 PM
mayhem13's Avatar
Quoted: 43 Post(s)
Sloped baffle.........very cool! For some reason I can't see your pix on my iPad with the special AVS app??????
Anyways..... A sled is an excellent tool for the saw.
I'll sit back and enjoy DiY through you for a while. I'm a little DIYed out after completely gutting and Reno of our 4 piece bath. Gotta find a way to get charged up to do 120ft of custom cedar privacy fencing......I promised to have it done by memorial day!
mayhem13 is offline
post #4 of 31 Old 05-08-2012, 08:52 PM - Thread Starter
randyc1's Avatar
Quoted: 238 Post(s)
Liked: 40
Hope you get to see pics, ...weird because i can see them on i phone ?
Gonna start the braces soon. I'll keep u posted !
Have fun with your fence
randyc1 is offline
post #5 of 31 Old 05-21-2012, 07:23 PM - Thread Starter
randyc1's Avatar
Quoted: 238 Post(s)
Liked: 40
Braces are done in birch ply for superior strength. I used this triangular pattern for strength and since i needed a opening up the middle for the port.
The port opening coming out of a angled baffle was a little challenge.I hope the pics help my explaination ?
Had to glue part of the port to the first sheet of angled baffle. glued a coupling on port before cutting it at the right angle to give me more glueing surface. when dried made opening in center to insert router with angled shims attached, this way router is parrallel to port again and used pvc walls to guide the trim bit.... (I could'nt do port hole of both layers of baffle at once,2" trim bit was not long enoughto extend through double baffle+shims )
Now im glueing the second sheet of the baffle together and will repeat same method for port holes.
randyc1 is offline
post #6 of 31 Old 05-21-2012, 07:32 PM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 220
Cool looking project!
Jay1 is offline
post #7 of 31 Old 05-31-2012, 10:35 AM
lopo's Avatar
Do you have the box dimensions and port lenght for this design. I also have a HO-44 that I have been deciding on a project to use it in. But I only have a Bash 500 amp to run it.
Would this design work out for me as well ?
lopo is offline
post #8 of 31 Old 05-31-2012, 04:14 PM
LTD02's Avatar
Quoted: 2340 Post(s)
Liked: 2575
yes lopo. it will work the same. you will just get a little less spl.
Listen. It's All Good.
LTD02 is offline
post #9 of 31 Old 06-01-2012, 02:45 PM - Thread Starter
randyc1's Avatar
Quoted: 238 Post(s)
Liked: 40
The box dimensions are H28 x 16W x 23D (top 19D)
I will be running (both) with one SA 1000 amp .
Made a jig to flare inner ports,i used Bondo and some MDF discs i made ,...went very well.
Heated the PVC with a propane torch, lubricated jig with some dish soap then pushed till reached flat base , let cool with wet rag then.....voila!!
randyc1 is offline
post #10 of 31 Old 06-01-2012, 04:11 PM
lopo's Avatar
whats the port lenght ? Your should look pretty cool with the angled baffle.
Al
lopo is offline
post #11 of 31 Old 06-01-2012, 07:56 PM - Thread Starter
randyc1's Avatar
Quoted: 238 Post(s)
Liked: 40
Al
Port is 26.15" long
randyc1 is offline
post #12 of 31 Old 06-08-2012, 08:04 AM - Thread Starter
randyc1's Avatar
Quoted: 238 Post(s)
Liked: 40
UPDATE: Okay i've got most of the "Guts" of the sub completed. Need to add some Roxul insulation on just the backwall,... binding posts and the woofer wiring, before gluing the sidewall into place.
Since i could'nt add vertical bracing from top to bottom because of the port, I added some 45deg angles to help brace top and bottom panels.
Ports are going through braces at 1/4" gap, and are secured to to braces with silicone to try and minimize vibrations. IMG_1083.JPG 2169k .JPG file IMG_1084.JPG 1565k .JPG file
ID:	24360   Click image for larger version
randyc1 is offline
post #13 of 31 Old 06-08-2012, 08:23 AM - Thread Starter
randyc1's Avatar
Quoted: 238 Post(s)
Liked: 40
Why are'nt my pictures posted right away like they were before in previous posts ??
randyc1 is offline
post #14 of 31 Old 06-08-2012, 08:40 AM
baniels's Avatar
Quoted: 208 Post(s)
Liked: 318
A lot of creativity in this build. Nice work so far.
baniels is offline
post #15 of 31 Old 06-16-2012, 06:18 PM - Thread Starter
randyc1's Avatar
Quoted: 238 Post(s)
Liked: 40
Thanks Baniels !
randyc1 is offline
post #16 of 31 Old 06-18-2012, 08:50 AM
BeerParty's Avatar
I could be that they are too big, try resizing them smaller.
Chris
--Despair, Inc. "Regret"
My AviaTrix TM Build
BeerParty is offline
post #17 of 31 Old 06-19-2012, 10:29 AM - Thread Starter
randyc1's Avatar
Quoted: 238 Post(s)
Liked: 40
i used my iphone camera just like the rest of pics?
randyc1 is offline
post #18 of 31 Old 06-19-2012, 12:24 PM
noobzorta's Avatar
Just a fyi for shaping the pvc, you might find it easier in the future to boil some vegtable oil and put the end that needs shaping into it. This is a easier way to move the material without burning it, and possibly inhaling the fumes. I used this method to make pvc darts for a air cannon lol.
noobzorta is offline
post #19 of 31 Old 06-19-2012, 02:16 PM
Mrkazador's Avatar
Quoted: 252 Post(s)
Liked: 378
Don't attach the photos (paperclip icon), use "insert image" which looks like a photo of a landscape.
Mrkazador is offline
post #20 of 31 Old 06-19-2012, 06:57 PM
mayhem13's Avatar
Quoted: 43 Post(s)
Looking good Randy!
You went through quite an effort for port flares. Maybe next build, you can try inserting the raw PVC into the back of a double thick baffle only .75 in, and then rounding over the outer layer with a 3/4 roundover bit. Much faster, secure, and a clean front baffle.
mayhem13 is offline
post #21 of 31 Old 06-19-2012, 07:05 PM - Thread Starter
randyc1's Avatar
Quoted: 238 Post(s)
Liked: 40
Looking good Randy!
That's excactly what im doing for the exterior port , the picture u see is for interior port.
randyc1 is offline
post #22 of 31 Old 06-20-2012, 12:44 PM
mayhem13's Avatar
Quoted: 43 Post(s)
oh...sorry. I didn't realize you were flairing the inside. Whether it's right or wrong, i've never flaired the inside before.eek.gif
mayhem13 is offline
post #23 of 31 Old 06-20-2012, 02:41 PM
Mrkazador's Avatar
Quoted: 252 Post(s)
Liked: 378
I've seen lots of people flare the inside of the port. Usually they will make a donut then flare with a round over like this
http://www.subwoofer-builder.com/ring.htm
post #24 of 31 Old 06-20-2012, 03:23 PM - Thread Starter
randyc1's Avatar
Quoted: 238 Post(s)
Liked: 40
Hey Mayhem, if you dont think it's a good idea ,i could cut the flare off ,and bring the total length back to the original 26.11 (I had forgotten the double baffle , 1.5" of port length) ??
26.11 is the lenght for a 18hz tune, now im about at 17.5 hz.???
thanks Mayhem.
randyc1 is offline
post #25 of 31 Old 12-14-2012, 07:45 PM - Thread Starter
randyc1's Avatar
Quoted: 238 Post(s)
Liked: 40
IMG_1623.JPG 1508k .JPG file IMG_1621.JPG 1830k .JPG file Update on my Sub build,: I took a long break from the build ,but now they are almost completed,
I Dampened just the back wall with 2'' of Safe and Sound Roxul insulation, and was then ready to complete the enclosures ,
Continued with enclosure esthetics (roundovers) and sanded. Sealed with a oil based primer ( Zinnser Cover Stain) tinted grey,
which builds well ,seals the router edges very well and sands very well also!!
2 coats sanding in between and i was done.
Now im ready for the finished coats ?
ID:	65619   Click image for larger version
randyc1 is offline
post #26 of 31 Old 01-03-2013, 05:30 PM - Thread Starter
randyc1's Avatar
Quoted: 238 Post(s)
Liked: 40
Just a few pics of my new Subs still on primer , they look pretty cool, and will look great with the bookshelves that i will eventually build to go on top ( Tarkus style).
They sound just as Awesome,!! creating a lot of deep bass and the impession of weight with movies. They are powered by a SA1000 .
I have not yet measured their FR with REW and am using no EQ yet.
Want to thank "Mayhem13" for all his help designing thes subs for me !!!!
randyc1 is offline
post #27 of 31 Old 01-03-2013, 05:37 PM
brian6751's Avatar
Quoted: 879 Post(s)
Liked: 674
Very cool. Nice job.
That's not science! - Cyborg
Steam ID: The Barbeerian
Rivers Edge Theater
brian6751 is offline
post #28 of 31 Old 01-03-2013, 06:03 PM
Stereodude's Avatar
Quoted: 3085 Post(s)
Liked: 2236
Those are some pretty fancy looking subs!
Stereodude is offline
post #29 of 31 Old 01-03-2013, 06:30 PM
baniels's Avatar
Quoted: 208 Post(s)
Liked: 318
baniels is offline
post #30 of 31 Old 01-03-2013, 06:34 PM
jpmst3's Avatar
Quoted: 97 Post(s)
Liked: 233
Great job!
Joe = LFE Addict
Joe's LOWARHORN build
jpmst3 is offline
