Keager's Quad RE XXX 18 Underfloor IB Build - Page 12 - AVS Forum | Home Theater Discussions And Reviews
 2Likes
post #331 of 345 Old 12-15-2012, 04:56 PM - Thread Starter
keager's Avatar
Originally Posted by Stereodude View Post
What if you take the MiniDSP out of the loop and plug the receiver directly into the amp?
The amp only accepts xlr and they are in different rooms with the existing xlrs run under the house. I'll see if I have a rca to xlr cable. However the ends that hook up to mini dsp have the plug cut off due to the phoenix connectors.
keager is offline
post #332 of 345 Old 12-15-2012, 05:00 PM - Thread Starter
keager's Avatar
If I remember correctly, there wasn't a hum before the mini dsp. I changed amps and amp location/wiring at that time also, so a lot of things changed at once.
keager is offline
post #333 of 345 Old 12-15-2012, 05:14 PM - Thread Starter
keager's Avatar
keager is offline
post #334 of 345 Old 12-16-2012, 08:09 AM - Thread Starter
keager's Avatar
OK, I can make the hum go away if the mini dsp is unplugged from the outlet or if the rca from the receiver is unplugged. I tried diconnecting my the cable from the wall that goes to the cable modem and no change. I ran a wire from the case of my avr to the cener screw of the outlet and no change.
keager is offline
post #335 of 345 Old 12-30-2012, 09:16 AM - Thread Starter
keager's Avatar
Thanks to FOH, I was able to get my ground loop hum to a minimum. I was dinking with the delay in mini dsp, and noticed there was for some reason a peq that seriously cut around 27hz. I have no idea how it got there,as I haven't applied any eq yet intentionally. I removed that, and will test it out in a bit.
keager is offline
post #336 of 345 Old 02-03-2013, 07:20 AM - Thread Starter
keager's Avatar
I'm trying to make a florr plan of my house so I can get acoustic treatment advice. Can somebody recommend a simple free online program?
keager is offline
post #337 of 345 Old 02-03-2013, 08:59 PM
BassThatHz's Avatar
Quoted: 2381 Post(s)
Liked: 2155
I use Google Sketchup. Check out their learning tutorials. However it doesn't do any acoustical analysis (that I know of) so...
BassThatHz is online now
post #338 of 345 Old 02-04-2013, 05:52 AM - Thread Starter
keager's Avatar
Thanks. i know that I won't find a program that combines anything acoustic with a floor plan. i just need something to show so others that offer advice can see the shape and size of my room.
keager is offline
post #339 of 345 Old 02-21-2013, 03:41 PM
JapanDave's Avatar
Quoted: 171 Post(s)
Liked: 124
Hey Keager, have you got yours setup with EQ? How are you finding it?
My build thread
My 8 x RE XXX 18" Subwoofers, IB build
Couldn't pour water out of a boot with instructions on the heel.
Do you know what Nemesis means?
JapanDave is offline
post #340 of 345 Old 02-21-2013, 05:14 PM - Thread Starter
keager's Avatar
I have messed with the eq a bit. Not much. I will post some graphs later.
keager is offline
post #341 of 345 Old 02-22-2013, 06:01 AM - Thread Starter
keager's Avatar
Here are the individual manifolds without eq. I apparently didn't save the measurement of them combined
keager is offline
post #342 of 345 Old 04-21-2016, 06:30 AM
dtsdig's Avatar
Quoted: 911 Post(s)
Liked: 1037
@keager What happened to this thread? Did you ever finish up? How are the results?
dtsdig is online now
post #343 of 345 Old 04-21-2016, 06:48 AM
desertdome's Avatar
Quoted: 1330 Post(s)
Liked: 1523
He sold the gear and moved.
From 7/24/14:
Originally Posted by keager View Post
I'm clearing out the gear cuz I'm moving. The RE's are gonna be for sale too, but local of course due to the shipping costs. In fact, may even make someone a package deal...
High Impact AV
desertdome is offline
post #344 of 345 Old 04-21-2016, 06:59 AM
dtsdig's Avatar
Quoted: 911 Post(s)
Liked: 1037
From 7/24/14:
Bummer. Thanks for letting me know!
post #345 of 345 Old 04-21-2016, 07:44 AM - Thread Starter
keager's Avatar
Actually, I did move and still have the gear and starting to plan using the same things in my new smaller place. The subs will be "outie" IB setup.
Broke EF and uniquepattern like this.
keager is offline
