Yung Plate Amp - Initial Impressions - Page 5 - AVS Forum | Home Theater Discussions And Reviews
 2Likes
post #121 of 128 Old 08-28-2014, 04:18 AM
Liked: 1
Originally Posted by garciab View Post
For Fc of 20Hz, q of .7, R8 = 25K, R23 = 50K
For Fc of 18Hz, q of .7, R8 = 28K, R23 = 56K
Notice the ratio of 1:2 for a Q of .7, which is maximally flat response. And you can see what happens to Fc as the resistor values increase.
Hi!
Jumping in a bit late. Just built a sub for the Dayton RSS265HO and the bottom end just is lacking. I use the Yung SD300 unboosted, and now I found the answer: it cuts below 30 Hz...!
To my question: what kind of resistors should I buy? Looking into the market there are so many different resistors. I think I'm aiming at 28/56K for an 18 Hz HPF
Later,
Ola
pastorola is offline
post #122 of 128 Old 08-28-2014, 06:44 AM - Thread Starter
garciab's Avatar
Quoted: 155 Post(s)
Liked: 71
You should be looking for SMD (surface mount device) resistors, size is 0805.
Bombelman likes this.
bg
garciab is online now
post #123 of 128 Old 08-28-2014, 02:02 PM
Liked: 1
Hey, quick reply there Thanks alot!
post #124 of 128 Old 09-01-2014, 04:46 AM
Liked: 1
Hey, what will happen with almost 2:1 matching, like 27k and 56k resistors? Can't find exact match for 25/50 or 28/56
post #125 of 128 Old 09-02-2014, 06:32 AM - Thread Starter
garciab's Avatar
Quoted: 155 Post(s)
Liked: 71
Just a very slightly different Fc and Q. Nothing you will notice. Go for it!
bg
post #126 of 128 Old 09-06-2014, 07:08 AM
g.costanza's Avatar
Quoted: 95 Post(s)
Ok. I think I wanna try a stronger amp in my very old, but barely used Velodyne F1200R. This is a servo controlled woofer in a sealed box. I sometimes get a flashing LED as the (100 watt) amp taps out on heavy material. Should I try the boosted 300 Yung? Also, I may leave the factory amp in place for now. Can I tap into the 2 leads going to the woofer and connect them to a set of binding posts on the cabinet, while leaving them connected the the old built-in amp? The idea being, if I plug nothing into the binding posts and power on the original amp, it will drive the woofer, but if I turn off (and unplug) the old built-in amp and plug the output of the new plate amp (mounts in a temp. case) into the binding posts, it will be driving the woofer. Would that work? Or should I just install a double set of posts which when connected together (red to red, black to black) would complete the woofer's connection to internal amp, and when not connected together, would allow hook up to the new, external amp. And I realize that bypassing the internal amp defeats the servo control. I haven't pulled the driver yet, but I imagine leaving the servo sensor in place, but unused, wouldn't cause any issues, yes? Thanks!!!
g.costanza is offline
post #127 of 128 Old 09-07-2015, 06:32 AM
bmxmen's Avatar
Hi! I have problem with my Young sd500 plate amplfier. Something like audio-enthusias problem. Can anybody help me? i need schematic coz names of part are eresed. Help me
bmxmen is offline
post #128 of 128 Old 02-08-2016, 03:46 PM
Liked: 0
for anyone who cares, i jumped the 2 capacitors on
A sd-100 non bass boosted. Still did same thing as it does on bass boosted, so yeah they all do have some form of boost
nickzom is offline
