f20 help - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 05-16-2012, 06:19 PM - Thread Starter
Krbass's Avatar
Hi all, it has been a seriously long time since I have really been doing anything with my subs. Back in the fall I built 2 F20s to go with my THTs. My father passed away in December from a long battle with lung cancer, so everything I was doing from October till recently has been on hold. Im finishing up my theater room and decided to roll the F20s in and use them as my stage.
The F20 on the right is missing an access panel atm and a sub. The one on the left will just not play loud. I am using an EP1500(the same amp that has powered both THTs for over a year) and an MFW driver. My THTs are corner loaded, not sure if this makes a huge difference. I also never sealed the MFW drivers with silicone like I did the Dayton DVCs. Any idea what I might be doing wrong?
Krbass is offline
post #2 of 13 Old 05-16-2012, 06:30 PM
Brad Horstkotte's Avatar
Liked: 68
Sorry about your dad's passing - cancer sucks.
Did you check for leaks? Did you try switching the wires from the amp to make sure both channels are OK?
Brad Horstkotte is offline
post #3 of 13 Old 05-16-2012, 07:00 PM - Thread Starter
Krbass's Avatar
He beat cancer 11 years ago, but this time it was stage 4.
Both channels work. how would I check for leaks?
Krbass is offline
post #4 of 13 Old 05-16-2012, 10:03 PM
Maxjr's Avatar
Easiest way is with a lighter. Hold the lighter and move it around all the joints, especially the access panel while playing a test tone. If you see e flame move sideways due to air, you have a leak.
Maxjr is offline
post #5 of 13 Old 05-16-2012, 10:37 PM
stormwind13's Avatar
Quoted: 60 Post(s)
Liked: 96
^^ what he said, they should be very loud. The most typical reason is leaking air.
stormwind13 is offline
post #6 of 13 Old 05-17-2012, 03:27 AM
ovrrdrive's Avatar
Placement could also be having an affect on the sound too depending on what your version of "not very loud" is. I know if I push my F20 in the corner up against the wall the sound drops off big time compared to pulling it about a foot away from the wall. When you walk around the room does the F20 get louder in some spots?
Sorry to hear about your Dad btw... That's terrible news.
ovrrdrive is offline
post #7 of 13 Old 05-17-2012, 09:16 AM
lilmike's Avatar
Quoted: 64 Post(s)
Liked: 160
My condolences.
As far as the F-20's performance? Really - I can't help unless we have some data. Measure impedance and SPL, that way I have data to compare, and I can help identify a problem.
As others have said, leaks will kill the performance. Also, room placement is huge. Not that the F-20 is all that, but putting the best sub in the worst spot will still sound bad.
The F-20 is essentially in the same league as the THT, they measure within a dB and a Hz or two where it matters most. As I understand it, you have THTs, so if your F-20s do not compare, something is wrong with the F-20s, the signal feeding them, or the room placement.
lilmike is offline
post #8 of 13 Old 05-17-2012, 11:43 AM
WiSounds's Avatar
I'll be home Saturday, I can stop over and help take a look this weekend if you want.
Originally Posted by Bill Fitzmaurice:
It's also the very sort of Voodoo Engineering that should never be done.
WiSounds is offline
post #9 of 13 Old 05-17-2012, 11:50 AM
ZivkoF's Avatar
Quoted: 22 Post(s)
Liked: 27
Originally Posted by lilmike View Post
My condolences.
Hi lilmike,
or it is the leaks or worst spot. Could you tell me how long is the horn path in the F-20 and if you know how long is the horn path in the THT. Thanks.
ZivkoF is online now
post #10 of 13 Old 05-17-2012, 01:56 PM - Thread Starter
Krbass's Avatar
I will post results later after work. I also plan on corner loading it in the same place I had the tht.
Krbass is offline
post #11 of 13 Old 05-17-2012, 04:36 PM
lilmike's Avatar
Quoted: 64 Post(s)
Liked: 160
Originally Posted by ZivkoF View Post
Hi lilmike,
All the F-20 information is in my thread fully documenting it.
THT information is tied to owning the plans. I bought a copy years ago, long before I learned how to design and fold my own horn cabinets.
lilmike is offline
post #12 of 13 Old 05-17-2012, 06:06 PM - Thread Starter
Krbass's Avatar
OK so I got home and got the f20 into the THTs spot. Room placement matters more than I ever knew. My house is splitting in half. Can't wait to have all 4 subs corner loaded.
As a side note I checked with a lighter and one screw in the access panel was missing. Sounds the same with or without it filled.
Krbass is offline
post #13 of 13 Old 05-17-2012, 09:12 PM
lilmike's Avatar
Quoted: 64 Post(s)
Liked: 160
Glad it was an easy fix.
lilmike is offline
