Woofer braces - AVS Forum | Home Theater Discussions And Reviews
Old 05-17-2012, 12:22 PM - Thread Starter
pjoseph24's Avatar
I came across this the other day and was curious about the "woofer braces"
First time i have ever seen them was wondering of the benefits if any
http://www.subwoofer-building.com/
pjoseph24 is offline
Old 05-17-2012, 01:42 PM
Point Source
beastaudio's Avatar
Quoted: 3519 Post(s)
Liked: 2835
Youll never see me siliconing my driver onto some braces inside the box. In certain cases I have seen people with SUPER heavy drivers supporting the drivers under the magnets, but other than that, the benefits are minimal if any at all.
beastaudio is offline
Old 05-17-2012, 01:47 PM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 220
Thick gasket foam might be a smarter choice if you ever want to take the woofer out. I cant see much benefit if the driver is properly tightened down.
Jay1 is offline
Old 05-17-2012, 02:09 PM
Point Source
beastaudio's Avatar
Liked: 2835
yup, im holding an 85 pound driver on with just the 1 1/4" wood screws. That's 10.625 pounds of load per screw. I think they can handle that. Braces behind the sub touching the driver? where does that guy think it's going to go? fall into the box? hehe
Old 05-17-2012, 03:03 PM
ovrrdrive's Avatar
It's actually the secret of the box. The guy that told him to do that is now a salesman. Didn't you read the story?
(lol)
I bet the guy is a salesman alright... I wonder if he can also sell a ketchup Popsicle to a woman in white gloves.
ovrrdrive is offline
Old 05-17-2012, 06:23 PM
Drew Eckhardt's Avatar
http://www.linkwitzlab.com/frontiers_2.htm#N
http://www.linkwitzlab.com/orion-rev1.htm
To quote Siegfried Linkwitz:
There are two potential problems with the traditional way of mounting a driver by clamping it with screws to a baffle. One, the magnet/mass and basket/compliance can form together a very high Q resonant structure, where the magnet moves relative to the voice coil at a resonant frequency, which is typically in the 150 Hz to 450 Hz range. Two, structure borne vibration, which is generated by the considerable force that the accelerating cone of the driver exerts on the basket, is transmitted through the mounting scheme into the baffle. There it might be stored and re-radiated unevenly at different frequencies.
The resonance wouldn't be an issue with sub-woofers if it's out of the pass-band although I have no clue how the added magnet mass interacts with the larger basket structure.
Drew Eckhardt is offline
Old 05-17-2012, 11:40 PM - Thread Starter
pjoseph24's Avatar
Ahh i feel better now, i was thinking with all the reading i did before building my sub how could i have missed something like this!
Old 05-18-2012, 06:39 PM
BassThatHz's Avatar
Quoted: 2035 Post(s)
Liked: 1566
Isolating the mechanical resonances is "technically" ideal, but NOT AT ALL practical; and it is really only needed for frequencies above 120hz. Midranges and mid-woofer type stuff; in particular where the basket or box is very thin and thus prone to resonance.
(B&W uses this mounting method on all of their 800 series mids for example, although done much more professionally.)
For such a tiny/weak subwoofer that much bracing is a bit overkill (but it doesn't harm anything), and he was being way too generous with the anti-leak sealant... a properly glued joint will not leak air!!!
That type of support is not even needed for a heavy XXX-18 or LMS-18 magnet, the screws will hold it.
For subwoofers with high excursion that dig deep, the moving-mass begins to increase to a point where the enclosure may begin to shake and walk about. This can be solved by making it dual-opposed or mounting it perpendicular with respect to the floor or adding more box mass or by adding feet that counter it with increased surface "sticktion" (or spikes that dig in).
BassThatHz is offline
