Thoughts on SI Mag - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 05-18-2012, 10:49 AM - Thread Starter
wth718's Avatar
Quoted: 194 Post(s)
Liked: 311
I currently have an AV15H sealed build and after using minidsp, it sounds pretty damn good. But with the acoustics in my room, there are a couple of nulls that make the response drop off below 30 (even though there is definitely useable output well below that). Sub placement doesn't seem to help, and I'm now looking into duals. Obviously, the AV is nowhere to be found anymore, so I came across this option available for under $200
http://stereointegrity.com/index.php?id=53
Anyone with experience or thoughts? Specs below.
T/S parameters: 15 inch
Re (coils in series) 3.5 3.5
Fs 22
Le 3.7
Qms 3.7
Qes 0.39
Qts 0.35
Cms 197
Mms (grams) 262
Vas (liters) 184
Sd (cm^2) 810
BL 18.35
SPL (1W/1M) 88.8
Power handling RMS 950
Xmax 26mm
wth718 is offline
post #2 of 5 Old 05-18-2012, 11:19 AM
Bass Enabler
Scott Simonian's Avatar
Quoted: 5337 Post(s)
Liked: 4220
What kind of amp are you using? Tell us more about the room the sub is in.
Scott Simonian is online now
post #3 of 5 Old 05-18-2012, 11:40 AM - Thread Starter
wth718's Avatar
Quoted: 194 Post(s)
Liked: 311
Room is about 2000 cubes. Currently is a travesty of wood panels and those BEAUTIFUL frosted plastic ceiling tiles in the drop ceiling. Hopefully both of those will be remedied in the next month. Will likely be using the same 500 watt bash plate amp I used for the av. The new model with the hp at 17 Hz and almost no boost. Worked really well for the av, in the end.
wth718 is offline
post #4 of 5 Old 05-19-2012, 01:17 AM
zora's Avatar
Quoted: 48 Post(s)
Liked: 51
Fs 22
Le 3.7
Qms 3.7
Qes 0.39
Qts 0.35
Cms 197
Mms (grams) 262
Vas (liters) 184
Sd (cm^2) 810
BL 18.35
SPL (1W/1M) 88.8
Xmax 26mm
Isn't it vaporware? The SI subs availability has been spotty at best the last few years. I wouldn't count on one for a build anytime soon.
zora is online now
post #5 of 5 Old 05-19-2012, 04:24 AM - Thread Starter
wth718's Avatar
Quoted: 194 Post(s)
Liked: 311
^^^ I don't know about the the current models, but this is a used version 3 model, which is definitely available.
wth718 is offline
