Renegade Parties Vol 2, Bass in the Bowl - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 05-20-2012, 07:26 AM - Thread Starter
WiSounds's Avatar
There is a bandshell in Rochester called the highland Park bowl:
There also happens to be the Lilac festival commencing today. So we are doing a renegade show at the bowl today. There are 2 20a circuits to use which will be adequate.
The blazer is loaded:
Sub compliment:
1 B&C 21SW152
1 18Sound 21LW1400
4 Sundown SA12
Amps:
1 NE8250
2 KLR3200
1 KLR2000
1 FTX-2001
More pics later. I left the SoloX at home, too heavy and I chose efficiency because of it being outdoors.
Originally Posted by Bill Fitzmaurice:
It's also the very sort of Voodoo Engineering that should never be done.
WiSounds is offline
post #2 of 7 Old 05-20-2012, 10:39 AM - Thread Starter
WiSounds's Avatar
Got it set up, and RPD shut us down because of no sound permit.
WiSounds is offline
post #3 of 7 Old 05-20-2012, 12:48 PM
04FLHRCI's Avatar
Well, that sucks!
04FLHRCI is offline
post #4 of 7 Old 05-20-2012, 01:39 PM - Thread Starter
WiSounds's Avatar
Officer was kind enough to let me take pictures set up, but not take a video. Will post later. The bass up the hill was simply amazing.
WiSounds is offline
post #5 of 7 Old 05-20-2012, 04:39 PM
BassThatHz's Avatar
Quoted: 2350 Post(s)
Liked: 2113
The video would have been cool.
BassThatHz is online now
post #6 of 7 Old 05-20-2012, 08:32 PM - Thread Starter
WiSounds's Avatar
For the 10 minutes it ran, it was epic. I really wish they would have let me take the video.
WiSounds is offline
post #7 of 7 Old 05-21-2012, 10:25 AM
FOH
FOH's Avatar
Quoted: 39 Post(s)
Liked: 236
Pretty cool rig
If you ever have the opportunity to go back there again, I'd recommend utilizing the rear curved wall in a more optimized manner. Hard to tell from the pics, however boundary cancellation could easily eat up a significant amount of your capability in the 35hz-45hz range. If there was a way to load the acoustic output of the subs as directly to the rear wall as possible you may have much less 1/4 wavelength destructive cancellation.
I'm sure the LF was bad ass, but if you eliminated the negative acoustic elements, it could be spectacular, much smoother response, and more efficient. If the subs are say 8 feet off the back wall, you're going to have a cancellation center approximately at 35hz. A spacing of 7 feet, 40hz, a 6' space, 47hz. So best practice would be keep them quite close, or quite distant. The range between 10' to 3' is problematic.
As you know;
1130/freq=wavelength in feet
So, if a sub is 1/4 wavelength away from a wall (especially outside because the boundaries are simple, and well defined), you'll encounter cancellation at that frequency.
Here's one article pertaining to this.
Best of luck
just found another link here
Active 16.8kw, 7.3 system
(2)Seaton SubM-HP, (4)18" IB
FOH is offline
