Mounting the driver faced in..... - AVS Forum | Home Theater Discussions And Reviews
post #1 of 14 Old 05-21-2012, 05:14 PM - Thread Starter
kgveteran's Avatar
Quoted: 362 Post(s)
Liked: 130
So, can you mount a driver facing in ? That would allow you the stiffest cabinet walls as the driver back usually compromises the design by taking up bracing.
Just wondering...
As of Jan 2017, im still looking for (1) Outlaw M-200 mono amp, and a used Marantz 7010
kgveteran is online now
post #2 of 14 Old 05-21-2012, 05:19 PM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 220
A bass driver with an open frame can get away with that (sub). Once you get higher in frequency the outside cone profile is needed.
Jay1 is offline
post #3 of 14 Old 05-21-2012, 05:21 PM
WiSounds's Avatar
It works great for subwoofers.
The only caveat is potential motor noise. Undersized venting and such can lead to excess noise.
I prefer it because it will increase the internal volume of the cabinet a bit because of the airspace in the cone, and really helps cool the motors in open air instead of heating up the inside of a cabinet.
And it looks sweet to have all that metal just hanging there.
Originally Posted by Bill Fitzmaurice:
It's also the very sort of Voodoo Engineering that should never be done.
WiSounds is offline
post #4 of 14 Old 05-21-2012, 05:33 PM
Bass Enabler
Scott Simonian's Avatar
Quoted: 5284 Post(s)
Liked: 4168
Just wondering...
Yup. People do it all the time....as Wi just posted above, even.
Scott Simonian is offline
post #5 of 14 Old 05-21-2012, 05:39 PM
keager's Avatar
In my IB manifolds for my xxx 18's, I'm having one in and one out dual opposed. Saves alot of space with the magnet of the xxx. Have to reverse the polarity on one driver of course
keager is offline
post #6 of 14 Old 05-21-2012, 05:41 PM
notnyt's Avatar
Quoted: 2155 Post(s)
Liked: 1982
The main benefit of doing it like that is to balance out driver non-linearity.
notnyt is offline
post #7 of 14 Old 05-21-2012, 05:43 PM
keager's Avatar
Thats what ive been told. Thanks for confirming.
keager is offline
post #8 of 14 Old 05-21-2012, 06:28 PM - Thread Starter
kgveteran's Avatar
Quoted: 362 Post(s)
Liked: 130
Do you guys use the huge rubber ring around the driver, or do you ise a gasket material
post #9 of 14 Old 05-21-2012, 06:32 PM
WiSounds's Avatar
I use speaker gasket tape from PE on the cabinet itself, between the rubber and wood, to seal a bit better between mounting points.
WiSounds is offline
post #10 of 14 Old 05-22-2012, 07:04 AM
Point Source
beastaudio's Avatar
Quoted: 3496 Post(s)
Liked: 2826
Closed cell foam that you can get from any hardware store. Comes in rolls. seals up the driver much tighter than the stock rubber ring.
beastaudio is offline
post #11 of 14 Old 05-23-2012, 05:36 PM - Thread Starter
kgveteran's Avatar
Quoted: 362 Post(s)
Liked: 130
Does that huge rubber ring serve any other purpose, other than a not so good gasket. Why do i feel like it has something to do with the surround and keeping it in place..... Weird, maybe I'll do a little reworking of that area of my subs...
post #12 of 14 Old 05-24-2012, 05:39 PM - Thread Starter
kgveteran's Avatar
Quoted: 362 Post(s)
Liked: 130
So, their just wired out of phase ?
post #13 of 14 Old 05-24-2012, 05:44 PM
keager's Avatar
Are you referring to my situation with one in and one out?
keager is offline
post #14 of 14 Old 05-24-2012, 06:36 PM
Bill Fitzmaurice's Avatar
Liked: 4631
So, can you mount a driver facing in?
It does make the drivers more vulnerable to damage. You can remedy that by extending the top, bottom and sides, which also will lend a bit of additional loading while not requiring any calcs, like a bandpass does. Then you can add a grille as well if further protection is required, as in having kids in the house or anything else in the trunk.
Bill Fitzmaurice is online now
