My Zaph 2.5MMTMM build - AVS Forum | Home Theater Discussions And Reviews
post #1 of 21 Old 05-22-2012, 04:51 PM - Thread Starter
fschris's Avatar
Quoted: 33 Post(s)
Liked: 35
A couple pics to get opinions... on anything I am doing or should be doing.
ASROCK H67 GE / HT/Core i3
Emotiva XPA2 Gen2 x2
Carver AV-705 5Channel AMP
Zaph 2.5MM TT'S DIY
Emotiva UMC 200
2 x MFW 15 Clones DIY
fschris is offline
post #2 of 21 Old 05-22-2012, 04:56 PM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 221
Nice! I really like the look of the mmtmm design.
Jay1 is offline
post #3 of 21 Old 05-22-2012, 05:56 PM
mayhem13's Avatar
Quoted: 45 Post(s)
Liked: 29
Looking good! I'm quite surprised more DIYers didn't
mayhem13 is offline
post #4 of 21 Old 05-22-2012, 09:55 PM
LBDiver's Avatar
More clamps, less glue
LBDiver is offline
post #5 of 21 Old 05-23-2012, 05:25 AM - Thread Starter
fschris's Avatar
Quoted: 33 Post(s)
Liked: 35
LB thanks for the tip.
Zaph 2.5MM TT'S DIY
Emotiva UMC 200
fschris is offline
post #6 of 21 Old 05-23-2012, 08:41 AM
lowpolyjoe's Avatar
good stuff. what's your finishing plan? paint, veneer, etc...?
i don't remember the details of that variant. is that two ports in a single chamber or will that be two different chambers?
lowpolyjoe is offline
post #7 of 21 Old 05-27-2012, 08:08 PM - Thread Starter
fschris's Avatar
Quoted: 33 Post(s)
Liked: 35
i am going to paint it two tone... dark red baffle and black cabinet.
it is a single cabinet with 2 ports
Zaph 2.5MM TT'S DIY
Emotiva UMC 200
fschris is offline
post #8 of 21 Old 05-30-2012, 05:46 PM - Thread Starter
fschris's Avatar
Quoted: 33 Post(s)
Liked: 35
Some more pics....
they came out pretty good considering ... I am doing it.
Zaph 2.5MM TT'S DIY
Emotiva UMC 200
fschris is offline
post #9 of 21 Old 06-04-2012, 05:49 AM - Thread Starter
fschris's Avatar
Quoted: 33 Post(s)
Liked: 35
got some more work done this weekend.
Rounded over the rear baffle and did a 45 degree chamfer on the front.
Zaph 2.5MM TT'S DIY
Emotiva UMC 200
fschris is offline
post #10 of 21 Old 06-04-2012, 06:03 AM
Jinjuku's Avatar
Quoted: 65 Post(s)
Liked: 148
Looking good. I did the MTM center channel of Zaphs ZAW1408 and was very impressed with the driver.
An audiophile likes to talk about how much they spent and how good it sounds.
A DIY'er likes to talk about how little they spent and how good it sounds.
Jinjuku is offline
post #11 of 21 Old 06-04-2012, 07:25 AM - Thread Starter
fschris's Avatar
Quoted: 33 Post(s)
Liked: 35
What stood out to you ? I am going to build a center with those drivers as well.
Zaph 2.5MM TT'S DIY
Emotiva UMC 200
fschris is offline
post #12 of 21 Old 06-04-2012, 07:41 AM
Jinjuku's Avatar
Quoted: 65 Post(s)
Liked: 148
Under critical listening the ZA14W08 was of a more revealing/higher resolving speaker than the ZDT3.5 center channel.
As an example in the Tomb scene in LOTR were Gandalf is flipping the pages in the book there simply is a more crisp note to it and the debris falling off the page onto to the floor more defined.
Now that center channel didn't have the raw output of the ZDT3.5's...
Jinjuku is offline
post #13 of 21 Old 06-06-2012, 01:32 PM - Thread Starter
fschris's Avatar
Quoted: 33 Post(s)
Liked: 35
Thanks for the info. I will pairing these with a Emotiva XPA-3 so I look foward to it. I am currently using some tiny Energy speakers from the Take5.1 Line up. The zaph should blow this away!
Zaph 2.5MM TT'S DIY
Emotiva UMC 200
fschris is offline
post #14 of 21 Old 12-29-2012, 08:08 AM - Thread Starter
fschris's Avatar
Quoted: 33 Post(s)
Liked: 35
I did get these done and I thought i would throw a picture up for people to see....
Zaph 2.5MM TT'S DIY
Emotiva UMC 200
fschris is offline
post #15 of 21 Old 12-29-2012, 08:10 AM - Thread Starter
fschris's Avatar
Quoted: 33 Post(s)
Liked: 35
Some more pics
Some perspective on size with 52 inch plasma. Its time to build a new center!
Zaph 2.5MM TT'S DIY
Emotiva UMC 200
fschris is offline
post #16 of 21 Old 12-29-2012, 08:26 AM
filtor1's Avatar
Quoted: 218 Post(s)
Liked: 171
Well done!!
filtor1 is offline
post #17 of 21 Old 12-29-2012, 09:44 AM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 221
Very nice! How'd you get the mirror finish?
Jay1 is offline
post #18 of 21 Old 12-29-2012, 12:38 PM
Jinjuku's Avatar
Quoted: 65 Post(s)
Liked: 148
Ok, those are SHARP looking speakers.
Jinjuku is offline
post #19 of 21 Old 12-29-2012, 12:39 PM - Thread Starter
fschris's Avatar
Quoted: 33 Post(s)
Liked: 35
i used rustoleum professional spray enamel. they are shiny but I actually used the semi gloss. I could not imagine how glossy they would be using the full gloss. also you really need to hide every imperfection of the surface you are applying this too. i learned the hard way and i probably spent way to long trying to get them to look half way decent. i painted them in my garage and i hung plastic from the ceiling to make myself a little spray booth. it is very messy and the fumes are bad as well. it does come out nice once you get the hang of it. i am even going to re do my subs that i built... with that spray.
Zaph 2.5MM TT'S DIY
Emotiva UMC 200
fschris is offline
post #20 of 21 Old 12-29-2012, 02:33 PM
phidauex's Avatar
Looks good, I like the contrasting baffle color! I've always thought that most commercial speakers either look incredibly bland to blend in with every home, or try to "stand out" and look ridiculous. One of my favorite parts of DIY is getting to build things to my own taste, regardless of how "marketable" it would be. So good job - they really fit with the room, while still having some pop.
I've built a few of Zaph's designs and always found them very well thought out. I don't think he's ever designed a bad speaker (at least, he hasn't PUBLISHED a bad speaker). I'm just starting the ZA5 based center channel myself, and looking forward to getting it going with my ZDT3.5 powered mains.
Do you have any acoustic impressions for us? How are they sounding compared to your last speakers?
As for painting, now that you've gotten used to the most important aspect (prep, prep, prep) you should consider getting into sprayed automotive-style urethane paints. An Astro LVLP spray gun can be run on a moderately sized air compressor, and the range of primers and single-stage urethanes available for spraying is incredible. For the same amount of prep time you can get a really impressive finish.
-Sam
phidauex is offline
post #21 of 21 Old 12-29-2012, 06:58 PM - Thread Starter
fschris's Avatar
Quoted: 33 Post(s)
Liked: 35
thanks sam. i will very much look into a spray system in the future. as far as previous speakers. i was using the energy take 5.1 classic system! so you can see I made a huge step up. they sound 1000% better. I can also tell they sound better than anything i have heard in best buy of course! i love this DIY stuff. The performance, value and pride knowing I built something is well worth it. I enjoy Movies and music. I even just listen to these without my sub sometimes in a pure 2 channel set up. They sound nice and smooth.
Funny you mention the ZDT3.5 as I believe that will be my next build. So I also need to build a center and I thought why not just build the ZD3 "C" to match the future build ! I figure I could maybe move these TT's to surround duty after the ZDT3.5's are built. Do you have any pics of your 3.5's?
Zaph 2.5MM TT'S DIY
Emotiva UMC 200
fschris is offline
