Polyfiber stuffing BIC F12 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 05-25-2012, 07:47 AM - Thread Starter
eyelobes's Avatar
Was just wondering if anyone has experience with the insides of this sub and know if additional stuffing would be beneficial in any way. Have my sub being delivered today to replace my lowly Orb Super 8 (before the amp upgrade).
Drew
eyelobes is offline
post #2 of 9 Old 05-25-2012, 07:52 AM
Bill Fitzmaurice's Avatar
Liked: 5684
Sealed or vented? If sealed additional stuffing will lower Q and may improve it, but if you don't have gear to measure Q and/or FR it's a trial and error exercise to find out.
Bill Fitzmaurice is offline
post #3 of 9 Old 05-25-2012, 07:55 AM - Thread Starter
eyelobes's Avatar
It is a ported box with a 12" speaker. The dimensions of the box are 2.5 cubic feet.
eyelobes is offline
post #4 of 9 Old 05-25-2012, 09:00 AM
Liked: 5684
Originally Posted by eyelobes View Post
It is a ported box
Then it should only be lined, not stuffed.
post #5 of 9 Old 05-25-2012, 11:03 AM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 221
That sub could benefit greatly from an increase in apparent box volume. If you get some thick fiberglass insulation and line over the walls again (hot glue around the corners of each panel), without blocking the port, you should achieve this.
Jay1 is offline
post #6 of 9 Old 05-25-2012, 01:23 PM
Liked: 5684
Doing so will lower Q and change the box tuning, which isn't necessarily a good idea.
post #7 of 9 Old 05-25-2012, 01:33 PM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 221
It is for that sub, which has a high inductance peak around 50-60hz and a fairly steep roll off to 30hz. Raising volume should give it more capability where most people want it, down low. It might be possible to damage the sub if to much output is gained of course.
Jay1 is offline
post #8 of 9 Old 06-03-2012, 05:34 PM
Jrunr's Avatar
Quoted: 75 Post(s)
Has anyone actually added polyfill and found an audible difference with this sub?
Jrunr is offline
post #9 of 9 Old 06-04-2012, 10:10 AM
noobzorta's Avatar
What dimensions are you using for ft^3 calculation? I think i recall it was tuned to somewhere like 27-30hz by the length/size of port.
I messed around with a broken one by slapping a lms-r and vmp-12 into it. Great extension and response, just output was not that of a ported which i was wanting.
noobzorta is offline
