Bookshelf Build - AVS Forum | Home Theater Discussions And Reviews
post #1 of 15 Old 05-25-2012, 11:20 AM - Thread Starter
shortyg83's Avatar
Quoted: 1049 Post(s)
Liked: 951
Guys I am in a contest with a friend to build bookshelf speakers.
First off no neither of us are any good but it is still happening.
I do not want to build my own crossovers and I have heard that the ones from partsexpress are not great. can anyone give me idea on good place to by crossovers from? They will be two way speakers. drivers are not yet decided on.
shortyg83 is offline
post #2 of 15 Old 05-25-2012, 11:46 AM - Thread Starter
shortyg83's Avatar
Liked: 951
post #3 of 15 Old 05-25-2012, 11:50 AM - Thread Starter
shortyg83's Avatar
Liked: 951
post #4 of 15 Old 05-25-2012, 11:52 AM
BeerParty's Avatar
What is the contest for? If you are not building your own crossovers it sounds like you are not trying to design your speakers. Designing the crossover is the main effort in creating a DIY speaker design.
Are you both going to use the same drivers and crossover and just see who can build the better box? If that is the case, I would suggest you go with an existing design that includes a crossover. If you provide more info we can point you to several existing designs that should work.
You need to provide:
  • max cost for 2 speakers (for drivers and crossover, or for everything)
  • approx size of the speaker cabinets you want
  • location (against a wall, away from the wall)
  • usage (music, home theater system, indoors, outdoors, etc.)
  • any other constraints you think may impact the design/build (for example, if you have limited tools available)
Chris
--Despair, Inc. "Regret"
My AviaTrix TM Build
BeerParty is offline
post #5 of 15 Old 05-25-2012, 12:08 PM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 220
If you dont want to build a proven design, at least have madisound measure and simulate a crossover for you
http://www.madisound.com/services/leap.php
You just have to pick from drivers they carry.
Jay1 is offline
post #6 of 15 Old 05-25-2012, 01:39 PM - Thread Starter
shortyg83's Avatar
Liked: 951
Hmm that madisound seems like a good deal
post #7 of 15 Old 05-25-2012, 01:51 PM - Thread Starter
shortyg83's Avatar
Liked: 951
The competition is who can build a better sounding bookshelf in 2 weeks
Any drivers we want from parts express with woofer under 8" and total cost for woofers and tweets under 250
cost of crossover is 100max
everything else as in box and such price does not matter.
How bad are the crossovers they sell on partsexpress?
I was looking at a crossover like this
http://www.parts-express.com/pe/show...number=260-142
post #8 of 15 Old 05-25-2012, 01:59 PM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 220
Bad. Go with a proven design
Jay1 is offline
post #9 of 15 Old 05-25-2012, 02:03 PM - Thread Starter
shortyg83's Avatar
Liked: 951
a proven design?
I do not want to copy another speaker.
post #10 of 15 Old 05-25-2012, 02:38 PM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 220
Good luck! Just try and find drivers with a smooth response, that have matched sensitivities, and impedances at the x-over point
Jay1 is offline
post #11 of 15 Old 05-25-2012, 02:54 PM
ovrrdrive's Avatar
Crossover for under $100 might be a tall order... I was spec'ing out the price on the MT speakers that John Marsh built on HTG and the cost of the crossovers was more than the speakers. IIRC it was almost $200 for the crossover parts alone. FWIW, I got one of the MTM speakers from PE using the dayton RS180s and RS28A and their crossover and it sounds amazing. As long as it's the right crossover for the speakers that are used I bet they would be acceptable...
Here's the thread I'm referring to: http://www.htguide.com/forum/showthread.php4?t=13154
ovrrdrive is offline
post #12 of 15 Old 05-25-2012, 03:53 PM
tuxedocivic's Avatar
Quoted: 2177 Post(s)
Liked: 2047
Newer designs use smaller cheaper cross overs, if the designer puts thought into that. The modules use an insane cross over. $100 is lots for a 2-way xo, IMO. A recent design I did could be done for $30 in cross over parts. 1 inductor was it.
My youtube channel: Impulse Audio
tuxedocivic is offline
post #13 of 15 Old 05-25-2012, 04:09 PM
Subjga's Avatar
I've been pricing crossovers for Carody's builds and they do price out to well under $100 for 2-way crossovers.
To the OP:
I've been looking into doing the same, but it's not straightforward at all (quite the opposite). You'll need measuring equipment to get it right.
Subjga is offline
post #14 of 15 Old 05-25-2012, 04:31 PM - Thread Starter
shortyg83's Avatar
Liked: 951
Thanks for the info so far. I am gonna read some more threads on others builds.
post #15 of 15 Old 05-30-2012, 05:56 AM - Thread Starter
shortyg83's Avatar
Liked: 951
New question
The system will be hivi f6 woofer
hivi rt1.3 tweeter.
It will have a 2 inch aero port. But the issue is where to place the areo port?
I am not really sure there is room on the front of the box. Will placing it on the back sound bad?
