Yesterday's project, custom door panels to fit an 8" midbass - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 05-27-2012, 09:17 AM - Thread Starter
WiSounds's Avatar
Got the itch to upgrade my doors to Sundown NeoPro 8s after fryign one of my JL C5 6.5s:
I decided to make a custom MDF plates because of how the driver fit the door. The following is the process.
Remove old drivers:
Make a cardboard rough template:
Transfer to MDF:
I didn't get photos of the rough cut and belt sand to fit nicely, I also hit the front edge with a bit of roundover. This is the result of about 45 minutes of sanding and fitting. Also cut out the driver opening:
Spray about 6 coats of flat black, MDF soaks it up:
Mount the plate to the door and test fit the driver:
Mount the tweeter:
Cut a small amount of steel out of the door, and put the door panel back on:
And here it is, a front stage that can finally keep up with 4 12s:
Originally Posted by Bill Fitzmaurice:
It's also the very sort of Voodoo Engineering that should never be done.
WiSounds is offline
post #2 of 10 Old 05-27-2012, 09:58 AM
tundrSQ's Avatar
Looks great...and i love your tweeter placement.
Tim
tundrSQ is offline
post #3 of 10 Old 05-27-2012, 11:54 AM
gpmbc's Avatar
Quoted: 340 Post(s)
Liked: 207
Any change in the xover to accommodate the 8" vs the jl?
gpmbc is offline
post #4 of 10 Old 05-27-2012, 12:02 PM - Thread Starter
WiSounds's Avatar
I am going to run them active once the 125.4 comes out, didn't change anything yet so it still is running off the JL crossover.
WiSounds is offline
post #5 of 10 Old 05-27-2012, 12:37 PM
tundrSQ's Avatar
i'll give you a heck of a deal on an arc audio KS 300.4.....
Tim
tundrSQ is offline
post #6 of 10 Old 05-27-2012, 03:48 PM
maxmercy's Avatar
Quoted: 63 Post(s)
Liked: 168
Very nice!
JSS
maxmercy is offline
post #7 of 10 Old 05-28-2012, 02:30 PM
Bass Enabler
Scott Simonian's Avatar
Quoted: 5972 Post(s)
Liked: 5025
Sweet! I bet those pound the front real good.
Scott Simonian is offline
post #8 of 10 Old 05-28-2012, 05:06 PM - Thread Starter
WiSounds's Avatar
They handle the midbass nicely.
WiSounds is offline
post #9 of 10 Old 05-28-2012, 05:08 PM - Thread Starter
WiSounds's Avatar
It isn't Sundown, sorry :/ /fanboy off
WiSounds is offline
post #10 of 10 Old 05-28-2012, 06:30 PM
tundrSQ's Avatar
I can scape the label off....
Tim
tundrSQ is offline
