Adhesive for Energy RC30's - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 05-27-2012, 04:13 PM - Thread Starter
Still lll's Avatar
Quoted: 26 Post(s)
Hey guys, I have a little problem with one of my woofers. It seems half an inch of the rubber edge has unglued. Speaker sounds fine, but at higher volumes you can hear it flutter. When I apply a little pressure it will seal temporarily. Can anyone recommend a type of glue for a repair like this?
Still lll is online now
post #2 of 7 Old 05-27-2012, 04:18 PM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 220
Jay1 is offline
post #3 of 7 Old 05-27-2012, 06:18 PM - Thread Starter
Still lll's Avatar
Quoted: 26 Post(s)
Here is a picture. Hopefully it helps.
post #4 of 7 Old 05-27-2012, 06:54 PM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 220
That adhesive I linked should work
Jay1 is offline
post #5 of 7 Old 05-27-2012, 07:19 PM
tagaiz's Avatar
I have the RC-10's and had the exact same problem. I contacted them and they sent me a new woofer. They also sent out 2 replacement tweeters because one of mine had a very minor issue. Don't know why they sent 2 though but I'm not complaining. Try contacting them about it.
tagaiz is offline
post #6 of 7 Old 05-27-2012, 08:42 PM - Thread Starter
Still lll's Avatar
Quoted: 26 Post(s)
Tagaiz, did you contact energy directly? Thanks Jay1, I will look into that adhesive.
post #7 of 7 Old 05-28-2012, 12:57 AM
tagaiz's Avatar
I'm pretty sure I emailed them here support@energy-speakers.com
tagaiz is offline
