Quad RSS390HF-15 Build (in progress) - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 60 Old 06-25-2012, 02:19 PM - Thread Starter
Mrkazador's Avatar
Quoted: 252 Post(s)
Liked: 378
Saturday I completed one and on Sunday, completed another. DONE!
Whats left is the roundover, bondo, primer, and paint. For my first build it came out better than I expected. There are some gaps and one does not sit level but its nothing a little bondo and adjustable spikes can't fix biggrin.gif
I think I'll connect all four to my computer to have a listen for a few hours tomorrow.
Mrkazador is offline
post #32 of 60 Old 06-26-2012, 05:10 AM
maxmercy's Avatar
Quoted: 63 Post(s)
Liked: 167
Very nice, can't wait to hear your impressions and see your measurements!
JSS
maxmercy is offline
post #33 of 60 Old 06-26-2012, 03:27 PM - Thread Starter
Mrkazador's Avatar
Quoted: 252 Post(s)
Liked: 378
I can't remove the drivers from the enclosures... I tried making a hook from a small screw driver and it still won't budge.
I may be able to push a stick through the terminal plate and push the magnet. Would like any other ideas but for now...go to go to work mad.gif This is going to bug me all day!
Edit: Phew! I was able to get it out, used a stick to push up on the basket through the terminal plate.
post #34 of 60 Old 07-05-2012, 10:10 PM - Thread Starter
Mrkazador's Avatar
Quoted: 252 Post(s)
Liked: 378
I have a question about the speaker gasket...do you stick it to the driver or enclosure? The driver already has a thin gasket, I assume I take that off and put on the new one I bought from parts express.
post #35 of 60 Old 07-06-2012, 07:47 AM
petew's Avatar
Quoted: 25 Post(s)
Liked: 68
I stuck gasket tape to the enclosure.
Building Bass - Subs
Surrounds - Easy as Pi
Storage - unRAID unDELL
Mains - Another piece of Pi
petew is offline
post #36 of 60 Old 07-06-2012, 08:10 AM
Baleful's Avatar
No, do not take the gasket tape off of the driver - LEAVE that on there.
The gasket tape that you purchased from PE needs to be applied to the box itself, where the driver will sit.
Baleful is offline
post #37 of 60 Old 07-06-2012, 02:32 PM - Thread Starter
Mrkazador's Avatar
Quoted: 252 Post(s)
Liked: 378
I'm 99.9999% complete with the boxes, I updated my post with some pictures. This saturday I will have them up and running, hopefully with some graphs. biggrin.gif
post #38 of 60 Old 07-06-2012, 08:37 PM
petew's Avatar
Quoted: 25 Post(s)
Liked: 68
Looking forward to graphs. I got some absurdly flat response on my quad build. I'm still questioning if it's reality. Hope you have similar results.
petew is offline
post #39 of 60 Old 09-10-2012, 12:44 AM - Thread Starter
Mrkazador's Avatar
Quoted: 252 Post(s)
Liked: 378
Its been a couple months since I've updated anything. I did run some graphs and I got some pretty nasty dips at 35hz and 80hz IIRC. I tried spinning some of the subs around and it did nothing, not much I can do with placement but Audyssey does flatten it out some. I couldn't be any happier with the sound, when pushed hard it sounds clean. Right now I'm using some old HTIB speakers sitting on top of the subs. I plan to build 3 seos12 speakers in the future.
I did create some videos if anyone cares...
The receiver volume was set to -5 but the subs were running hot, my guess would be +6db. Radioshack meter dial is at 110db. I probably could have gone a bit further but I was too chicken tongue.gif It sounds distorted because the microphone was not designed for such high spl.
Jurassic Park 3
Jurassic Park 1
WOTW
Kung Fu Panda
post #40 of 60 Old 09-10-2012, 06:50 AM
bluestang's Avatar
Quoted: 23 Post(s)
Nice! How about some final product pics...I'd like to see how those grills are mounted and look. Thansk!
TV: Panny 42" Plasma | Sources: nVidia Shield TV (2017); WDTV Live SMP; HDTV cable; SqeezeBox Touch | Receiver: Kenwood Sovereign 4090 | Fronts: JBL Studio S312 | Center: JBL LS Center | Surrounds: JBL N24II | Sub: None (saving for SVS PC-2000)
bluestang is offline
post #41 of 60 Old 09-10-2012, 12:31 PM - Thread Starter
Mrkazador's Avatar
Quoted: 252 Post(s)
Liked: 378
I'll get more pictures when I have some free time.
post #42 of 60 Old 01-31-2013, 08:21 PM
brian6751's Avatar
Quoted: 879 Post(s)
Liked: 675
Uh......... Get any free time yet lol??? I want to see these
That's not science! - Cyborg
Steam ID: The Barbeerian
Rivers Edge Theater
brian6751 is offline
post #43 of 60 Old 01-31-2013, 09:00 PM - Thread Starter
Mrkazador's Avatar
Quoted: 252 Post(s)
Liked: 378
Forgot about that lol. Let's see if I can remember this time and get some pictures tomorrow.
post #44 of 60 Old 02-01-2013, 03:37 PM - Thread Starter
Mrkazador's Avatar
Quoted: 252 Post(s)
Liked: 378
The cloth is not jet black so it does kind of look a little tiny bit purple. Its really not that bad in person in normal lighting conditions.
Here is the clamp. I added a piece of USB cable to fill in the gap and the grip is pretty good, no play at all. The clamps were made for woofers that are mounted on top of the baffle, thats why there is a gap. I plan to replace these with some Angled Clamps, I think these will look nicer.
This is what the setup currently looks like. I plan to build 3 slim sealed SEOS Tempest. I was thinking of placing the left and right Tempests in the the corners but I don't know where to put the lamps without it looking weird.
post #45 of 60 Old 02-01-2013, 08:59 PM
brian6751's Avatar
Quoted: 879 Post(s)
Liked: 675
Nice. Where's the other two?
Rivers Edge Theater
post #46 of 60 Old 02-01-2013, 09:22 PM - Thread Starter
Mrkazador's Avatar
Quoted: 252 Post(s)
Liked: 378
Under the lamps.
post #47 of 60 Old 03-31-2013, 01:44 PM
andy133's Avatar
Hi, I started yesterday a thread about finding good void free but also formaldehyde free plywood. PureBond satisfies the latter but I was wondering about your experience about the void-free part. Is it dense enough, and did you notice any voids while you were cutting? I am thinking of the maple variety (shipped only) as I would like to finish it, not paint it. Would you say it is finish quality?
thanks
andy133 is offline
post #48 of 60 Old 04-01-2013, 01:05 AM - Thread Starter
Mrkazador's Avatar
Quoted: 252 Post(s)
Liked: 378
There wasn't a lot voids in it but I wouldn't use it again because of the thin veneer on the outside. The veneer is pretty nice but its useless in a cabinet if you only plan to use glue and no screws.
post #49 of 60 Old 04-01-2013, 04:51 PM
andy133's Avatar
Thanks. It seems that going for Baltic Birch or cabinet grade ply might be a solution for me.
However, I do not understand why a nice veneer is useless with glue..
andy133 is offline
post #50 of 60 Old 04-01-2013, 05:54 PM - Thread Starter
Mrkazador's Avatar
Quoted: 252 Post(s)
Liked: 378
Its a very thin veneer and I would think the veneer would separate from the plys if its only held by glue.
post #51 of 60 Old 06-17-2013, 05:22 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
What do you use for an AMP on your subs ?
Mfusick is offline
post #52 of 60 Old 06-17-2013, 05:51 PM
Bass Enabler
Scott Simonian's Avatar
Quoted: 5284 Post(s)
Liked: 4168
As it is mentioned in the very first post, he is using a Behringer ep4000.
Scott Simonian is offline
post #53 of 60 Old 06-17-2013, 06:34 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
I noticed many people are using this amp. Is there some special reason why it's so popular ?
Mfusick is offline
post #54 of 60 Old 06-17-2013, 06:53 PM
auburnu008's Avatar
Quoted: 438 Post(s)
Liked: 596
Cheap, reliable and high powered. One of the best bang for your buck amps out there.
auburnu008 is offline
post #55 of 60 Old 06-17-2013, 07:20 PM
Bass Enabler
Liked: 4168
post #56 of 60 Old 06-17-2013, 09:05 PM - Thread Starter
Mrkazador's Avatar
Quoted: 252 Post(s)
Liked: 378
And its been measured
http://www.avsforum.com/t/855865/measuring-amplifiers
post #57 of 60 Old 06-19-2013, 06:32 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
Got it ! Awesome! Thanks for great replies.
What else is an option ? Is this clearly the go to amp ?
Mfusick is offline
post #58 of 60 Old 06-19-2013, 09:25 AM
Bass Enabler
Liked: 4168
I certainly would but there are other choices out there too and especially so if you want/need very high power out of a single chassis.
It really depends on what gear you are powering and what kind of system you are trying to build. Are you trying to build what Mrkazador has built?
post #59 of 60 Old 06-19-2013, 12:24 PM
Trepidati0n's Avatar
Quoted: 39 Post(s)
Liked: 107
Other one that gets a bit of credit is the cerwin vega since it will also do 2 ohm.
I must be guilty because people say I am guilty because they chose to call me guilty because they refuse to see the truth. Much easier to be part of the mob..
Trepidati0n is offline
post #60 of 60 Old 06-19-2013, 01:26 PM
Bass Enabler
Liked: 4168
