15in Dayton Audio Horn build - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 06-03-2012, 02:57 PM - Thread Starter
Ronoman's Avatar
I'm going to be making a custom sub-box for my 15" Dayton Titanic MKIII, with the Dayton 1000w plate amplifier. I'm deciding between folded horn and ported, from what I've heard folded horn is really worth the extra work, anyone have some input? Also, if I do go with the folded horn, could someone come up with some dimensions?
-Thanks
Ronoman is offline
post #2 of 13 Old 06-04-2012, 08:16 PM - Thread Starter
Ronoman's Avatar
Bump!
Anyone? Please?
Ronoman is offline
post #3 of 13 Old 06-04-2012, 09:07 PM
WiSounds's Avatar
Put it in a THT.
Originally Posted by Bill Fitzmaurice:
It's also the very sort of Voodoo Engineering that should never be done.
WiSounds is offline
post #4 of 13 Old 06-04-2012, 10:04 PM - Thread Starter
Ronoman's Avatar
Originally Posted by WiSounds View Post
Put it in a THT.
Ok. But could I have some plans? I really don't know what I'm doing, and I also have a plate amp, is there a nice way to integrate that into a THT?
Ronoman is offline
post #5 of 13 Old 06-04-2012, 10:26 PM
WiSounds's Avatar
For plans go to billfitzmaurice.info, choose the THT page.
Build a small cabinet/box to hold the plate amp, keep it close to your receiver and run speaker cable to the THT.
WiSounds is offline
post #6 of 13 Old 06-04-2012, 11:43 PM
zora's Avatar
Quoted: 48 Post(s)
Liked: 51
Why go complicated at first? Get one of Erich's boxes and mount the plate amp in the box. With 1K on tap, the sealed system will really sound good.
JP
zora is offline
post #7 of 13 Old 06-22-2012, 01:52 PM - Thread Starter
Ronoman's Avatar
BUMP.
My friends and I just ordered our Titanic 3 and we are trying to figure out some dimensions for our box. Our first idea is 28"wide by 28"high by 26"deep, then having a slot port of 8"wide by 2"tall and in order to have a tune of 25hz it needs to be 4" long.. Is that a good idea? Any other dimension ideas?
Ronoman is offline
post #8 of 13 Old 06-22-2012, 03:04 PM
Mrkazador's Avatar
Quoted: 252 Post(s)
Liked: 378
25hz is too high of a tune for that size enclosure, theres a big peak at the tuning frequency. I would go with at least a 20hz tune.
Roughly 245 liters (8.652cu ft), this accounts for enclosure size (3/4"), driver, bracing, and port.
580w
18hz tune and a 18hz highpass
2.5 x 14 x 28.5" port
Mrkazador is offline
post #9 of 13 Old 06-22-2012, 03:35 PM
LTD02's Avatar
Quoted: 2340 Post(s)
Liked: 2575
"Our first idea is 28"wide by 28"high by 26"deep, then having a slot port of 8"wide by 2"tall and in order to have a tune of 25hz"
most would tune it to 20hz or a little lower.
you've got roughly 9 cubic feet there. a port of 8" x 4.5" x 24" will tune it to 20hz and lower your air speed in order to reduce port chuffing.
Listen. It's All Good.
LTD02 is offline
post #10 of 13 Old 06-22-2012, 07:34 PM - Thread Starter
Ronoman's Avatar
580w
So what box dimensions for that 18hz tune? if the port is 28.5" long, and my dimensions are only 26" deep, that doesn't work.
Ronoman is offline
post #11 of 13 Old 06-22-2012, 07:35 PM - Thread Starter
Ronoman's Avatar
That actually sounds pretty good. We might go with that.
Ronoman is offline
post #12 of 13 Old 06-22-2012, 08:48 PM
LTD02's Avatar
Liked: 2575
make sure to leave at least 2" on the inside between the end of the port and the back wall or the port might not function properly.
the 8" x 4.5" is 36 square inches. any combo that has the same area will work. you could use 3"x12", 4"x9", 6"x6", etc. they will all work the same.
you could use the full width of 28" (less 0.75 for the wood on the sides gives 26.5"). that would give you a slot port that is 26.5" wide and 1.36" high for the same tune.
all these assume a 24" deep/long slot port.
LTD02 is offline
post #13 of 13 Old 06-22-2012, 10:57 PM - Thread Starter
Ronoman's Avatar
Well in this box we are going to have the Dayton 1000w plate amp(Will be in the box 5.25"), so 2" between the port and back wont be a problem, should it?
And is this what you mean for the full width port?
299
Ronoman is offline
