DIY LCR - Econowave, PI, or SEOS? - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 40 Old 06-28-2012, 07:06 PM
Jesse S's Avatar
So that's the 2432 CD and the 2380 horn? Do you prefer bi-amp or passive? I think I'd prefer a single 2226 in each, dual is really large and overkill-city. I'd rather keep the extra drivers for another pair of speakers for my living room.
The 2432 look to be around $200 each, couldn't find any of the horns for sale.
Jesse S is offline
post #32 of 40 Old 06-28-2012, 07:16 PM
louisdamani's Avatar
Take a look here.
http://www.jamminjersey.com/speakers.php?prod=jblcomp
louisdamani is offline
post #33 of 40 Old 06-29-2012, 03:56 PM
Jesse S's Avatar
Thanks. They don't appear to have the parts mentioned earlier. Are any of them comparable?
Jesse S is offline
post #34 of 40 Old 06-29-2012, 04:16 PM
The 2380 horn is on there for $100. Scroll down to JBL Used Horns, Lenses, and Adapters.
post #35 of 40 Old 06-29-2012, 06:04 PM
LTD02's Avatar
Quoted: 2341 Post(s)
Liked: 2577
the horn on the 4722 is not the 2380.
call them and ask. one source shows it as the 2384 horn part #126-00177-01 for $172, another source shows it as jbl part #365359-001 for $102.
http://www.jblproservice.com/pdf/Horn%20List/Horn%20List.pdf
http://www.jblproservice.com/parts.html
jamm'n jersey is a pretty good source for the other components, such as the 2432H compression driver. they tend to cost a lot from jbl directly.
Listen. It's All Good.
LTD02 is offline
post #36 of 40 Old 06-29-2012, 10:01 PM
Erich H's Avatar
Quoted: 1406 Post(s)
Liked: 1771
I've got a good number of JBL 2352 horns if that would help anyone get something up and running for pretty cheap. They're left over from the group buy last year. I also had to throw away some of the really big JBL horns because they were taking up a lot of room. I can't recall the model number, but they were about 36" wide! Not sure how many of those I have left though.
_______________________
The SEOS Waveguide Project
Erich H is offline
post #37 of 40 Old 06-29-2012, 11:05 PM
MKtheater's Avatar
Quoted: 1589 Post(s)
Liked: 1121
That would be the 2360 from the 4675c's! Huge is right!
Marantz 7702 Atmos
MKtheater is online now
post #38 of 40 Old 06-30-2012, 09:22 AM
Jesse S's Avatar
Is 90 degrees the best horizontal dispersion for good coverage across 2-3 seats?
The 2384 is 90 degrees by 20, whereas the other JBL 238x are 40 vertical. Less "junk" bounced off the ceiling, more sensitivity, more "beamy"?
Jesse S is offline
post #39 of 40 Old 07-09-2012, 08:11 AM
hometheaterdoc's Avatar
Liked: 33
I'll take at least one pair of the 2352s to hold me over until SEOS-24 mold is made and we can get that from Poland. I'll take two pairs if you have a couple nice ones and the combined shipping isn't too outrageous. Please let me know via my email to you. Thanks!
Shane
hometheaterdoc is offline
post #40 of 40 Old 04-03-2013, 01:54 AM
Ash R's Avatar
Resurrecting this thread to add information I've found researching these speakers. The waveguide used in Pi Speakers has been updated with the latest 'pure catenary' technology. Econowave (QSC), SEOS and Pi are compared here with measurements:
http://audioroundtable.com/forum/index.php?t=msg&&th=17246&goto=73408#msg_73408
http://www.avsforum.com/t/1422151/wayne-parhams-h290c-waveguide-measurements
Hope it is useful to others that stumble on this thread.
Ash R is offline
