AESPEAKER td18h-4ohm t/s specs - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 06-04-2012, 06:26 PM - Thread Starter
cookieattk's Avatar
Quoted: 111 Post(s)
Liked: 91
just some quick testing much lower fs others seem close enough. ill put it in a box tomorrow and see how it does. i bought 3 of these from someone on here and they all test the same. also a jbl 2226 measures within 10% of its specs so the dats is accurate enough.
cookieattk is offline
post #2 of 11 Old 06-04-2012, 07:02 PM
WiSounds's Avatar
Broken in, or fresh out of the box?
Originally Posted by Bill Fitzmaurice:
It's also the very sort of Voodoo Engineering that should never be done.
WiSounds is offline
post #3 of 11 Old 06-04-2012, 07:36 PM - Thread Starter
cookieattk's Avatar
Quoted: 111 Post(s)
Liked: 91
fresh im breaking all 3 in atm ill take the same measurements again tomorrow.
post #4 of 11 Old 06-06-2012, 09:13 AM
John_E_Janowitz's Avatar
Quoted: 26 Post(s)
Liked: 81
Looking at your parameters I see some inaccuracies right away. First, please see the article I wrote on measuring T/S parameters I wrote some time ago. The Mass added method is not an accurate way to measure parameters for a woofer.
http://www.aespeakers.com/phpbb2/viewtopic.php?f=4&t=927
I see that the Mms according to your measured parameters is 270 grams. This cannot be correct. Measured Mms is around 165 grams. This is easily verified by physically measuring the coil, cone, then half the surround and spider. This also throws off the Bl and SPL measurements.
John
John E. Janowitz
Acoustic Elegance, LLC
"Learn from the mistakes of others... you can't possibly live long enough to make them all yourself"
John_E_Janowitz is offline
post #5 of 11 Old 06-06-2012, 02:52 PM - Thread Starter
cookieattk's Avatar
Quoted: 111 Post(s)
Liked: 91
John
i got within 10% of your specs last night using magnets on each side of cone and clamped to the side of a pool table i have in my garage with weights about a ton besides for the fs with i was getting 20hz or below did u change cones ? i noticed its different then the pics on your site.
post #6 of 11 Old 06-09-2012, 09:42 AM
Chris.ib's Avatar
Quoted: 50 Post(s)
You can measure Fs directly using REW and a series resistor in line with any low power amp.
Connect your Line-in cable to the driver terminals instead of your test mike and run a sweep.
REW then measures impedance instead of level.
Are links to other forums acceptable on here?
Original suggestion from Dan on the REW forum back in 2007:
http://preview.*******.com/btbyshd
Chris.ib is offline
post #7 of 11 Old 06-09-2012, 05:44 PM - Thread Starter
cookieattk's Avatar
Quoted: 111 Post(s)
Liked: 91
the fs is correct ive tested bunches of drivers now and they are all within 3db of the fs on the spec sheet besides the ae driver.
post #8 of 11 Old 06-24-2012, 11:58 PM - Thread Starter
cookieattk's Avatar
Quoted: 111 Post(s)
Liked: 91
near field test of td18 4ohm both graphs 1/24th no eq
236
also crossed it @ 1500 with my tweeter
236
post #9 of 11 Old 06-25-2012, 12:30 AM
A9X-308's Avatar
Quoted: 1506 Post(s)
Liked: 1142
^^ Were these done with tone sweeps? Where was the mic and speaker placement in room?
“You are not special. You are not a beautiful and unique snowflake.” Chuck Palahniuk
A9X-308 is offline
post #10 of 11 Old 06-25-2012, 12:51 AM - Thread Starter
cookieattk's Avatar
Quoted: 111 Post(s)
Liked: 91
both done with the pseudo noise near field one was taken from 3'' from the phase plug and 2nd graph is from about 5-6'' i should also note this is in a 2.2-2.35 cf box with a single 18'' ae pr. speaker is about 1'' from side walls between 2-3 ft from back wall with a 24x48 basstrap in the corner
post #11 of 11 Old 06-25-2012, 07:38 AM
Quoted: 26 Post(s)
Liked: 81
Here is a curve someone else measured on here awhile ago nearfield with the TD18H-8ohm. curves should be nearly identical between 4-8ohm.
295
The dip seen at 200hz is typical with what is measured with a speaker placed in front of a wall. The reflected wave from the back wall often causes a dip. Wavelength of 200hz is right around 67". So the distance of 2-3ft from the back wall would be right in that range. Try moving it forward or backwards and measuring the same way. That should move the dip around.
John
John E. Janowitz
