How do you protect your compression drivers? - AVS Forum | Home Theater Discussions And Reviews
Old 06-10-2012, 09:51 AM - Thread Starter
johnbomb's Avatar
http://www.audioheritage.org/vbulletin/showthread.php?17513-1st-Order-High-Pass-on-Compression-Driver
Hadn't thought about this before, but I don't like the thought of a DC pulse destroying my compression driver at amp turn on or from inadequate high pass filltering from an active crossover "oopsie" on my part. Since I like to cross these drivers pretty low, usually at around 900 hz, how would you approach capacitor selection such that it wouldn't significantly affect the final acoustic slope after the addition of an active 2nd order LR slope with an F3 of 900 hz?
johnbomb is offline
Old 06-10-2012, 02:10 PM
Bill Fitzmaurice's Avatar
Liked: 4631
Use the cap value for a 1st order passive one octave down from your crossover frequency. You should reconsider using a 2nd order HP, which offers minimal protection and maximum phase issues. One of the benefits to active crossover is that you can use much higher slopes and have far less phase issues than practical with passives.
Bill Fitzmaurice is offline
Old 06-10-2012, 06:57 PM - Thread Starter
johnbomb's Avatar
Thanks, Bill. Looks like a 47uf cap will be close enough, based on the online calculators I found.
John
Edit: That is, for an 8 ohm load.
johnbomb is offline
Old 06-10-2012, 07:39 PM
LTD02's Avatar
Quoted: 2340 Post(s)
Liked: 2576
489
Listen. It's All Good.
LTD02 is offline
