Noob wants to build a < $800 sub for a smallish room - AVS Forum | Home Theater Discussions And Reviews
post #1 of 16 Old 06-12-2012, 07:16 PM - Thread Starter
skinney6's Avatar
I live in an apartment so i dont want to shake the place down but i want try to get down to 20hz.
The room is half kitchen half living room. total room is 15' 4" x 22 but the theater portion is 15'4" x 13
the other thing is i dont have a workshop w/ woodworking tools to build a box.
I'm looking at trying to find an old sub on craigslist that i can reuse the box.
I've read a bit about the SVS SB12-Plus (or the NSD is all i see now) and i'm tempted to just buy that... but building is so satisfying
Supposing I can get a hold of a box what would be a good woofer / amp combo for my situation?
Is recycling a box a good idea?
What do i need to consider as far a the structure for the box for good sound / resonance or whatever?
You like that 'resonance' bit there? i'm trying to act like i know what i'm doing / talking about... lol
thanks in advance
Display: Panasonic TC-P50ST30, AVR: Pioneer VSX-1019AH, Fronts: Klipsch SB-1, Center: Polk CS 10, Surrounds & SB's: Infinity TSS-750, Sub: CSS Quartet 10 Kit, Win7 HTPC, XBOX 360
skinney6 is offline
post #2 of 16 Old 06-12-2012, 07:50 PM
LTD02's Avatar
Quoted: 2341 Post(s)
Liked: 2578
erich has flat pack enclosures. diysoundgroup.com. he is a member here and does it for a hobby, not for a profit.
a driver and an enclosure work as a team. you can't just plop any driver in any enclosure and expect it to work.
an inuke nu1000dsp will be enough power for an apartment and it has on board eq.
i wouldn't worry about trying to get down to 20hz with authority in an apartment because the sound is going to go right through the walls and buzz everybody in the complex.
Listen. It's All Good.
LTD02 is offline
post #3 of 16 Old 06-12-2012, 07:53 PM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 220
If you're okay with a bit of work, these flat packs are great
http://www.diysoundgroup.com/flat-packs-1/subwoofer-flatpacks.html
Glue them together, then sand, and paint/veneer. If that is still to much, then these Dayton cabinets might be better.
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=302-847
You would simply us a jig saw to cut out the woofer and amp cut outs. if you completely botch one of the baffles, you just order a new one
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=302-862
Use the following woofer/amp combo in either the 3ft3 or 3.5ft3 box and you're golden
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=295-420
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=301-514
Jay1 is offline
post #4 of 16 Old 06-12-2012, 10:08 PM - Thread Starter
skinney6's Avatar
thanks fellas!
I like the DIY 1.25cu ft... small footprint in my small space.
I can screw and glue ( i do it to my girlfriend on a regular basis!! lol)
What would be a good 10" woofer (is that the driver?) and amp combo?
skinney6 is offline
post #5 of 16 Old 06-12-2012, 10:28 PM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 220
The TC Epic 10, with the same 500 watt amp I linked earlier. The TC woofer is .07" smaller then the cutout Eric has for the 1.25 ft3 box, so it will fit just fine.
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=293-656
Jay1 is offline
post #6 of 16 Old 06-13-2012, 02:02 PM
Point Source
beastaudio's Avatar
Quoted: 3518 Post(s)
Liked: 2835
Originally Posted by skinney6 View Post
thanks fellas!
Good for you! not too sure about the glue part, that's unfortunate biggrin.gif
Use PL PREMIUM for any "gluing" of boxes, works great, expands into gaps and bonds rediculously well.
beastaudio is online now
post #7 of 16 Old 06-13-2012, 03:01 PM - Thread Starter
skinney6's Avatar
I will thank you!
skinney6 is offline
post #8 of 16 Old 06-13-2012, 04:21 PM
qguy's Avatar
Quoted: 122 Post(s)
Liked: 91
Rythmik has matching driver and amplifier kits
qguy is offline
post #9 of 16 Old 06-15-2012, 11:35 AM - Thread Starter
skinney6's Avatar
they look sweet but i'm gonna go a little less expensive
i'll do the CSS QUARTET10 Subwoofer Kit
and follow the sugested box specs
there's a build proj here..
http://www.hometheatershack.com/forums/creative-sound-solutions/16761-creative-sound-solutions-sdx10-sub-kit.html
he did the box basicly as CSS recomends
it's my first build so i'll try to keep it by the book as much as i can
skinney6 is offline
post #10 of 16 Old 06-18-2012, 09:08 AM
caper_1's Avatar
Liked: 26
I did the TRIO12 in a huge box earlier this year, and now have a SDX10 kit that I just received. I am doing it to spec this time, and also have the 2 passive radiators. This option lets you change the tuning of the sub without disassembling it (external access to weighted discs). You may find some tips on my build thread to help you. That was my first one too: [ TRIO12 build ]
HT: Yamaha RX-V565 | 3 X Energy Take FPS, 2 X VS Surround, 2 X Take LCR | DIY Subs: SDX12 APR15 & TRIO12 Dual APR 12's | 47" LCD
Music: Yamaha RX-V863 | 2 X Energy RC-70 | MA RXw12 Sub
Bathroom: 2 X Energy Take LCR
Car: Sony Xplod HU, Xplod 6X9s, Kenwood 4"s, Alpine 12" Type-S, Rockford Amp,...
caper_1 is offline
post #11 of 16 Old 06-18-2012, 10:22 PM
Socketman's Avatar
Quoted: 130 Post(s)
Liked: 148
I recently finished the sdx 10 from css and its a pretty decent performer. Only change i made was the actual dimensions,the volume remained the same. Only thing i did not like about it was i built the box while waiting for the sub to arrive and found the sub to have a very thick surround which would not allow flush mounting. If i were to do it again i would put a second layer of mdf on the inside . Aside from that it sounds really good musically and adds a real pounding when watching movies. You can surely piss of your neighbors with this biggrin.gif
Oh and you can see my finished sub in the diy gallery if interested.
Socketman is offline
post #12 of 16 Old 06-19-2012, 04:20 AM
caper_1's Avatar
Liked: 26
on my TRIO12, I added another layer on the outside of the front baffle and rounded over the corner of the outer circle. I like the look, but couldnt imagine doing all the way around on that beast.
caper_1 is offline
post #13 of 16 Old 06-19-2012, 06:57 AM
garciab's Avatar
Quoted: 144 Post(s)
Liked: 56
Socketman, was it the sub's actual surround (which is quite big) or the rubber ring that's installed? I've removed the rubber gasket before, and flush mounted the driver's frame. Then only the actual surround protrudes from the baffle. Still not flush-looking, but it looks better this way to me.
bg
garciab is offline
post #14 of 16 Old 06-19-2012, 07:59 AM
caper_1's Avatar
Liked: 26
here is a close up with the hard rubber 'surround' AND weatherstrip installed to prevent airleaks.
file.php?n=8866
caper_1 is offline
post #15 of 16 Old 06-23-2012, 06:25 PM - Thread Starter
skinney6's Avatar
I got my woofer yesterday. i see what your talking about. that gasket is huge, wraps around the how edge.
i dont really care but your way lays it more flat
skinney6 is offline
post #16 of 16 Old 06-23-2012, 09:06 PM - Thread Starter
skinney6's Avatar
caper_1 , your Trio12 box looks fantastic! i like the DuraTex
my box came out looking pretty rough. i did kinda of a fast and loose job.
it'll work but to make it look ok i'm going to have to do some more work
skinney6 is offline
