test how many watts your speakers use - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 06-16-2012, 12:18 AM - Thread Starter
cookieattk's Avatar
Quoted: 111 Post(s)
Liked: 89
cookieattk is offline
post #2 of 7 Old 06-16-2012, 12:53 AM
arande2's Avatar
I know what music I listen to has the lowest loudness vs. transient levels, which is some percussive music. I don't have enough sensitivity/amp (2.83v/8ohm/91dB/1m - amp rated 150w, 12x15x9ft room) to listen to it at my absolute loudest levels, by a lot. Conversely, I have some modern "loudness war" tracks (Death Magnetic) that leave me 3-4dB peak headroom at my loudest levels.
I also know that since movies are standardized to the same mixing levels (although newer releases seem to be louder - there is clipping on the Waiting For A Train scene in Inception) and have a higher dynamic range (debatable I guess), the power requirements are different because music varies from person to person while movies are more standardized (and yes, I know many don't watch at reference). Personally, my loudest music levels require about 10x the power from my main channels as my loudest movie levels.
arande2 is offline
post #3 of 7 Old 06-16-2012, 01:11 AM - Thread Starter
cookieattk's Avatar
Quoted: 111 Post(s)
Liked: 89
I also know that since movies are standardized to the same mixing levels (although newer releases seem to be louder - there is clipping on the Waiting For A Train scene in Inception) and have a higher dynamic range (debatable I guess), the power requirements are more robust.
it measures your peak levels that u listen to.
post #4 of 7 Old 06-16-2012, 01:25 AM
arande2's Avatar
Which, in my case, would be in clipping if I were to try the test as described.
arande2 is offline
post #5 of 7 Old 06-16-2012, 01:33 AM - Thread Starter
cookieattk's Avatar
Quoted: 111 Post(s)
Liked: 89
shouldnt its -12db
post #6 of 7 Old 06-16-2012, 07:17 AM
Bill Fitzmaurice's Avatar
Liked: 4641
Not as simple as modeling the speaker with design software, which will tell you the displacement limited power, the voltage swing required to get there, and the dB levels produced when you do.
arande2 likes this.
Bill Fitzmaurice is online now
post #7 of 7 Old 06-16-2012, 07:51 AM
LTD02's Avatar
Quoted: 2341 Post(s)
Liked: 2577
+1 to bill's post. then perform a spectral analysis of the content in order to see what the peak to average difference is. we tend to set the "volume" at the average value, but in order not to compress anything, you need to allow headroom for the peaks. how much compression we can hear is debatable, but if you don't want any with a well recorded track, you might need 15-20db of headroom. most folks don't listen at much more than 100db at the listening position average, which is why the "rule of thumb" for an accurate system starts around 115-120db at the listening position.
Listen. It's All Good.
LTD02 is offline
