Radio Shack 8" DVC'S//Optimal Enclosure? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 06-19-2012, 09:25 PM - Thread Starter
kevin g.'s Avatar
Quoted: 329 Post(s)
Liked: 138
Hello again all...
I have a pair of DVC Rat Shack subs, that, since I have them, I would like to build a simple cheap enclosure...but would require dimensions. I have the specs, and will post below.
My design goal is for a taller, maybe more narrow enclosure, with both drivers front-facing. (similar to the JL Fathom design.) I may or may not add a grille at a later date.
Here are the specs I have, not sure how accurate they are...
Thanks guys
Nominal Impedance:........................................ .4/8 ohms +/- 15%
Frequency Response:......................................... ..40 Hz-2500 Hz
Free Air Resonance (Fs) Frequency:....................................40 Hz
Infinite Baffle Resonance Frequency:..................................39 Hz
Piston Area (SD):............................................. ....0.0214 m2
Rated Power Input - Nominal:.......................................... .50 W
RMS Thermal Power Limit (PMAX):.......................................100 W
Flux Density (BL):............................................. .....5.17 TM
DC Voice Coil Resistance (RE, ohms):...........................2.9/5.5 ohms
Voice Coil Inductance (LVC at 1 kHz):..........................0.49/0.50 mH
SPL:.............................................. .....87/85 +/- 2 dB/1W/1m
Moving Mass (Mms):............................................ ......25.9 8 g
Electrical Q Factor (QES):.........................................0.7 2/1.4
Mechanical Q Factor (QMS):............................................ .3.26
Total Q Factor:........................................... ........0. 59/0.97
Equivalent Acoustic Volume (VAS):....................................36.8 I
Mechanical Suspension Compliance (CMS, UM/N):...................561.28 UM/N
Mechanical Mass of Cone Assembly and Free Air Load:.................25.98 g
Mechanical Mass of Cone Assembly Only:..............................24.18 g
Peak-to-Peak (Maximum) Linear Excursion:............................3.35 mm
Cutout:........................................... .......7 Inches (17.8 cm)
Depth:............................................ ...3 7/16 Inches (8.7 cm)
Power Handling:......................................... .......50 Watts RMS
Magnet Weight:........................................... .......... ...18 oz
Speaker Weight:........................................... .........5 4.31 oz
__________________
"Once you learn good English...Can't nobody take it away!"
Xbox LIVE Gamertag: KEVIN G 40
kevin g. is offline
