SEOS12/2512 Build - Page 11 - AVS Forum | Home Theater Discussions And Reviews
Old 08-30-2012, 06:06 PM
datranz's Avatar
Quoted: 56 Post(s)
Liked: 40
can you take a picture of the whole crossover? i like to see it for future reference
thanks
datranz is offline
Old 08-30-2012, 09:00 PM
bwaslo's Avatar
Quoted: 66 Post(s)
Liked: 178
One thing to note is that when you window your measurement, your low frequency measurement becomes unreliable (and usually downright nonsensical). Typically the lowest frequency data you can start to believe is about 2/(window time) in Hz. i.e. with a 2msec window, you could believe down to maybe 1kHz.
That said, it does look like the response is pretty flat. BUT, I think I might bring the high end down a little, that's bound to sound pretty bright in most rooms and with most material unless you have a well-damped room. If your receiver has EQ, then no problem, you can do it there with a "house curve". Or you can do it in the "L-Pad" section of the crossover (yeah, I know, you'd probably not want to go into the itchy stuff again... I never use fiberglass fill anymore for that reason!). You could change R8 to about 5 ohms to make the speakers sound warmer to do that if you wanted. Also, using with a subwoofer helps also - odd thing is that speakers with flat high end will sound more balanced if low bass response is improved.
Glad the crossover issues got worked out, though. Your center channel measurement does look like the gating is off or the measurement system has latched onto a reflection rather than the main impulse response.
DIY Synergy horn spreadsheet http://libinst.com/SynergyCalc/
XSim -free crossover designer and simulator http://libinst.com/Xsim/XSimSetup.exe
Easy and cheap sound diffusers (the "Depot Diffusers") making-easy-diy-depot-sound-diffuser-panels-step-step.html
bwaslo is offline
Old 08-31-2012, 08:01 AM - Thread Starter
Java's Avatar
thanks
Sorry. I should have taken a full shot of the "fixed" board before I closed up the boxes. Below are a full shot of the "old" board and partial shot of the "fixed" board. Hopefully you get the picture with both.
"Old" Board
"Fixed" Board
Java is offline
Old 08-31-2012, 08:13 AM - Thread Starter
Java's Avatar
Hey, Bill
They sound great. Thanks for all your help!!!
On the high end, my AVR's EQ (MCACC) trimmed some of the high end off of the mains. I'm working on acoustic treatment, so that should help, too. To me, they don't sound so bright. I'll get input from other/younger ears this weekend.
As odd as it may sound, they didn't sound that bad with the wonky tweeter setup I did. Now they sound phenomenal. Night/Day improvement over my Paradigms.
To your point, they blend very well with the sub and provide a full sound. I only have a 12" paradigm sub, but it with the 2512's give a healthy kick to the chest. I'm extremely happy.
On the center, maybe it's because it's picking up the screen wall reflections? I measure the left and right at an angle to the front/side walls but just pulled the center straight forward. I'll try some re-testing.
Thanks, again
Java is offline
Old 08-31-2012, 09:37 AM
coctostan's Avatar
Liked: 134
Good job Java. Anyone who has wired up a crossover has mixed up a few things.
What you heard when they were "mixed up" is about what people will hear when they a newb tries to implement a DSP crossover without proper design. You can't always tell something is off without a frame of reference. I've seen commercial speakers that measure that poorly and people thought they were great.
I'm not suggesting that a DSP is inherently bad, but in the wrong hands you end up with that kind of response.
With those components and Bwaslo's design you are in good hands. It should be night and day.
coctostan is offline
Old 09-01-2012, 03:30 PM - Thread Starter
Java's Avatar
Surrounds. Decisions...
I think I have the mains sorted out so it's time to move on to the surrounds.
I've been bouncing between two BWaslo designs. The Malcolm and Designer 10.
I already bought the waveguide (glossy, this time), DNA-350, and Designer 10 woofers. I was all set until I saw Erich's Malcolm baffle and discussion about kits.
On the one side, I like the Malcolm since its shape (short/wide), seems like it a good fit for on the wall. I also think they look cool. But, the crossover (i.e., 4 tweeters, etc.) is kinda scaring me given my goof on the mains' crossover.
On the D10 side, they are pretty similar to the mains I just built and I have got the bulk of the gear ready to go. The downside is they won't look as good on the wall (may be wrong on that) and looking at the pre-made baffles, I don't think I can use them. The baffles have the woofer cutout at 10.15 and designer 10's are 10.625.
I was concerned with the height of the D10 boxes being too big to get the full tilt needed (-20 degrees), but I played around with the mounts I'll be using: http://www.parts-express.com/pe/showdetl.cfm?partnumber=182-392, and found that mounting them in the center gives around 13 degrees tilt, but mounting it on the bottom quarter can provide up to 25 degrees tilt. Given these mounts are heavy duty, I'm thinking this is doable.
So, I'm thinking to "custom" build an 18" BWaslo D10. Again, I already have the drivers/WG and the pre-made baffles don't look like they will work.
Thoughts?
This "Modified BWaslo Designer 10" modified (lose the fins)
Tilt Test. Using 19" board mounted on the lower 1/4 yield a tilt range up to -25 degrees
Java is offline
Old 09-02-2012, 08:24 AM - Thread Starter
Java's Avatar
Final Outcome Page
I updated the 2nd post of this thread with the final outcome for future readers. http://www.avsforum.com/t/1417294/seos12-2512-build#post_22162851
Please let me know if you think I need to add anything.
Thanks again to all that have helped me. I could not have done this without you. Thank you.
Java is offline
Old 09-04-2012, 05:50 AM
mobeer4don's Avatar
Quoted: 116 Post(s)
Liked: 114
It may be possible to enlarge the opening to 10.625 using a 1/4" rabbeting bit and flush trim bit. Having it in hand would help clarify. Another option, probably easier and less prone to goofing would be to cut your own 10.625 template and clamp it down over the pre-cut baffle and use that to cut the larger opening. Or you could talk Erich into selling SEOS templates so you could cut your own baffles to size.
mobeer4don is online now
Old 09-04-2012, 06:10 AM
coctostan's Avatar
Liked: 134
Java-
I would go with the Malcolm's if it fits your space better. The performance differences will be negligible. If anything, I'd give the edge to the Malcolms. The shorter Malcolms do have the advantage of wider null spacing due to their shorter center-to-center distance. This is an advantage with surrounds given their needed dispersion pattern.
You will get the crossover right. Just post pictures and let the guys on the forum confirm if it is wired properly.
Old 09-04-2012, 06:21 AM - Thread Starter
Java's Avatar
Depending on the route I go, if I need a different woofer cutout I think using Erich's blank baffles would be best. I forgot he has the blanks already made up with the SEOS cutout (the PITA part): http://www.diysoundgroup.com/speaker-baffles/seos-19-tall-baffle.html. I can just use a circle jig to cut out the woofer cut outs.
Java is offline
Old 09-04-2012, 06:34 AM - Thread Starter
Java's Avatar
Originally Posted by coctostan View Post
Java-
I'm bouncing all over the place on the surrounds. Here's the sub-thread in the Rally thread: http://www.avsforum.com/t/1291022/hey-guys-we-need-a-little-rallying-here/5130#post_22365524
Erich raised a good point on the difference in efficiency between the designers and the eminence drivers. I'm now leaning heavily toward using Tuxedocivic's Delta 10A design.
Looking at the Designer 4 sensitivity (SPL: 85.5 dB 2.83V/1m) versus the Delta 10A (SPL: 98.8 dB 1W/1m), the difference is like 10dB, right? Given my fronts are slightly higher, don't you think the Delta 10A are a better fit?
I'm barely keeping my head above water with single drivers. Dealing with 4 drivers is confusing. Is the sensitivity changed with multiple drivers? Also, how do 4 4" drivers compare sonically with 1 10" driver? Low end? I'm crossing at 80hz to sub, but I'm concerned/confused on how the 4" drivers will reach down.
Thanks for the input and help, Coctostan
Java is offline
Old 09-04-2012, 07:28 AM
Erich H's Avatar
Quoted: 1352 Post(s)
Liked: 1625
When I mentioned efficiency, I was thinking along the lines of your DS-10 versus the Delta 10A. Not sure on the four 4" woofers compared to those other designs.
At some point in the near future I'm going to shut the site down for a few weeks so it can be updated with much more information on each design.
_______________________
The SEOS Waveguide Project
Erich H is offline
Old 09-04-2012, 07:41 AM - Thread Starter
Java's Avatar
Understood. The Designer 10 (SPL: 90.1 dB 2.83V/1m) is more efficient than the Designer 4 (SPL: 85.5 dB 2.83V/1m), so your point is amplified. Still don't know how multiple drivers impact those numbers, though.
Java is offline
Old 09-04-2012, 08:11 AM
NicksHitachi's Avatar
Quoted: 182 Post(s)
Liked: 189
Like 3db for every doubling of drivers or like 6db increase for 4 drivers v/s 1 but its rarely exactly that much, 3-6db increase is prob inclusive of the actual increase as it depends on response shape and what has to be done with crossover to keep flat or slightly tilted through crossover range.....
NicksHitachi is offline
Old 10-19-2012, 04:07 PM
smokarz's Avatar
Quoted: 30 Post(s)
Liked: 83
Hey Java, which black paint did you use? Did you prime?
smokarz is offline
Old 10-19-2012, 04:50 PM - Thread Starter
Java's Avatar
Hey Smokarz,
I used Rustoleum oil based flat black. I used it with a foam roller. I tried it with a rattle can, but it looked like crap.
Yes. Definitely prime. The mdf soaks up the paint, especially the edges. I did 2-3 coats each box. I found Zinsser Cover-Stain worked the best for me.
Here are my "tips":
http://www.avsforum.com/t/1417294/seos12-2512-build/210#post_22318116
Java is offline
Old 10-19-2012, 05:00 PM
Erich H's Avatar
Liked: 1625
There was a guy on the PE forums that gave a good tip about sealing mdf with diluted wood glue. He diluted 50/50 with water, then rolled it on. I used that method with my NHT clones and it worked really well.
Erich H is offline
Old 10-19-2012, 05:13 PM - Thread Starter
Java's Avatar
Was this it? http://techtalk.parts-express.com/showthread.php?219784-What-is-the-best-way-to-paint-mdf/page2
or http://techtalk.parts-express.com/entry.php?22-My-quot-canned-quot-spray-paint-methods
When I was "in the search", I found some threads on some of the "piano finish" experts that used a sealer before primer. Didn't you do a mirror finish on one of your builds? I seem to remember a reflection shot of a gum pack. Very nice!!
Java is offline
Old 10-19-2012, 05:26 PM
Brad Horstkotte's Avatar
Liked: 68
That's what I did on my cabinets, Titebond II thinned about 2 parts water to 1 part glue, then brushed it on over the rounded edges, worked well for me.
Brad Horstkotte is offline
Old 10-19-2012, 05:27 PM
smokarz's Avatar
Quoted: 30 Post(s)
Liked: 83
Thanks Java.
I was somehow thinking you've used Duratex.
My builds will probably be with Ply.
smokarz is offline
Old 10-19-2012, 05:33 PM - Thread Starter
Java's Avatar
Thanks Java.
Nope on the duratex. I thought about it, but it looks like it might have too much texture and sheen. I wanted a "black hole" given they are right below my screen and subject to light from the front projector.
I've seen some really nice finishes done with Duratex, though.
Java is offline
Old 10-19-2012, 05:44 PM
Quoted: 3075 Post(s)
Liked: 2579
Duratex, smooth foam roller, lightly sanded first coat.
Old 10-19-2012, 05:52 PM
smokarz's Avatar
Quoted: 30 Post(s)
Liked: 83
Now that is nice.
What do you get Duratex? Doesn't look like it's available at the local HD and Lowes.
smokarz is offline
Old 10-20-2012, 07:16 AM - Thread Starter
Java's Avatar
Ah. Your build was the one I had in mind when I said I've seen some nice finishes with Duratex. Your speaker finishes look awesome and was my mental benchmark for mine.
A question though. I sense from Smoke's comment on using ply that he is looking for some filling capabilities from duratex. I believe you get the filling from the bondo and priming, correct. Your boxes at the priming stage looked better than most do at the final stage. What did duratex add to the equation? Durability?
Java is offline
Old 10-27-2012, 11:02 AM - Thread Starter
Java's Avatar
Quick Update
Yes. Still loving the LCRs. Going to have a showing of Avengers tonight for friends. Should be a blast.
I'm starting to work on my surround build (SEOS12, DNA-350, Delta 10a) and will start a seperated build thread when I get cranking.
The reason for the update, was I re-ran the MCACC autoEQ last night and noticed how much of an imbalance I have between the LCR and the surrounds. Not like I didn't already know this, but now I saw the hard numbers. A full 10 db difference.
My surrounds are Paradigm ADP-170 v2. Back in the day, they were considered "highly efficient" (I couldn't find any numbers).
MCACC is trimming the mains 7 db and boosts the sides 3 db. If I remember correct, each 3db is equal to double the loudness. So the mains are 3x louder?? I'm assuming the MCACC is mainly balancing the efficiency vs size difference.
Anyway, this is why I leaned toward the Delta 10's over the Designers. I wanted to get as close as I could in the efficiency of the mains, so I ran them run at full.
More to come...
Java is offline
Old 10-27-2012, 01:30 PM
mtg90's Avatar
Quoted: 366 Post(s)
Liked: 675
Think about it this way Java.
If your LCR is 10dB more sensitive that means your surrounds need 10 times the power (if same impedance) to equal the same SPL level.
Or if put another way going to speakers 10dB more senstitive is like upgrading your amp to one 10X more powerful. smile.gif
mtg90 is offline
Old 10-28-2012, 07:36 AM - Thread Starter
Java's Avatar
Wow!! 10X
Well there is the advertising tag line: "I got 10 times the power than my Paradigms for less than $1k".
Java is offline
Old 10-28-2012, 09:16 AM
tuxedocivic's Avatar
Quoted: 1848 Post(s)
Liked: 1662
tuxedocivic is offline
Old 10-29-2012, 09:15 AM
Point Source
beastaudio's Avatar
Quoted: 3284 Post(s)
Liked: 2701
For sure, but think of it this way, if you have 87db sens. surrounds right now and the mains are 97dB's sensitive, this is a HUGE disparity, that I would more than likely work towards fixing, however, once MCACC ends up doing its thing, all the speakers should be withing 1 dB of each other. Having the lower sens surrounds at +3 and the mains at -7 might be what it takes for all them to measure to 75dB's at your main seat. This most certainly doesnt or at least SHOULDNT mean the mains are playing 10dB's hotter than the rest...
beastaudio is offline
Old 10-29-2012, 09:32 AM
Quoted: 182 Post(s)
Liked: 189
What amplification do you have?  AVR power?  I would put my most capable amplification on the lower sensitivity speakers......
