Old Audiomobile Mass 12, blown or bad connection in sub. Can it be fixed? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 06-24-2012, 03:32 PM - Thread Starter
darkhorror's Avatar
I am not sure what exactly is wrong with it. Sounds like a rattle or scratching at a certain point. I tried it in parallel with another sub that works well, and that scratching noise happens on both subs. Maybe something is causing the speaker to lose it's connection in the sub at certain excursion points for a very short time? If I move the speaker by hand when it's not being powered, I don't hear any scratching noise.
Any way to remove part of the speaker like the spider or what else I might want to check and then reattaching it?
Or are there any other uses for it, like I don't know as a passive radiator or find a recone kit?
I hate having something that seems like it should be fixable or used to just be thrown away.
darkhorror is offline
post #2 of 5 Old 06-24-2012, 06:53 PM - Thread Starter
darkhorror's Avatar
It seems that there was a loose connection or something right under the spider. I moved the sub up and down a couple times and I could feel something down there, might have been wires going to the voice coil. But I did a little massage and trying to see if anything was stuck or messed up by feel. Then if I could get it unstuck or working without the scratching noise again. It seems to have worked! I don't hear that scrape sound anymore. Looks like it's time to build a box for this bad boy now.
post #3 of 5 Old 06-24-2012, 07:22 PM
zora's Avatar
Quoted: 48 Post(s)
Liked: 51
Glad you got it fixed. Never throw those bad boys away, the driver is still very good compared to today's models and the motor assembly alone has value.
JP
zora is offline
post #4 of 5 Old 06-25-2012, 05:35 AM
rlj5242's Avatar
Quoted: 48 Post(s)
Liked: 40
If you blow it, I know a guy with 2 factory replacement coils. Probably the only 2 left in the entire world. If your scratching issue comes back, you may need a recone and this would be your only option to get it back to factory specs.
rlj5242 is offline
post #5 of 5 Old 07-08-2012, 09:46 AM - Thread Starter
darkhorror's Avatar
Well it's working great, I now have it in a 4 foot tall 18" diameter sonotube, tuned to ~18hz. and it's flat to 13.5hz in my room. sounds amazing.
