Differences between DNA-360 & DNA-350 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 23 Old 06-26-2012, 12:00 PM - Thread Starter
Maxjr's Avatar
Hi Everyone,
I'm having a very difficult time in choosing between the two DNA CD's. I've seen the specs and it looks like they are very similar with the 350 rolling off 1 kHz sooner and starting 50 Hz later as well. They have the same power handling and sensitivities. Is the biggest difference the recommended crossover frequencies? or is there more differences between the two that can't be seen in specs (such as how they sound)?
I will be using these primarily for surrounds, but may in the future use them as two ways. Should I just purchase the 360's and not look back? Any and all feedback is greatly appreciated. Thank you for your help and support!
Cheers,
Joel
Maxjr is offline
post #2 of 23 Old 06-26-2012, 12:25 PM
Mrkazador's Avatar
Quoted: 252 Post(s)
Liked: 378
IIRC, the 360 measures slightly better than the DE250. Doesn't roll off early in the high end. The 350 is a clone of the DE250 in that it measures almost the same. I don't remember for sure if this is correct, you'll want someone else to confirm.
Mrkazador is offline
post #3 of 23 Old 06-26-2012, 10:22 PM
LTD02's Avatar
Quoted: 2340 Post(s)
Liked: 2576
if $20 x2 is a lot to you, 350, otherwise 360. i'm not being a smartass, that is really about what it comes down to. the comparable de250 is much more in either case.
Listen. It's All Good.
LTD02 is offline
post #4 of 23 Old 06-26-2012, 11:38 PM - Thread Starter
Maxjr's Avatar
Its not only the cost difference. I'm not sure if I'll be able to hear the difference between the two. If the difference is noticeable, I'll definitely go with the 360's. I guess if I knew in advance what all the upcoming designs will use, it would also make it easier to make a decision.
For what its worth, I really enjoy how DE250s sound. I'll be using these DNAs with SEOS-12 as surrounds for now. Unless things change and I get bitten by the upgrade bug again, these may be used as 2-ways in the future if my whole system gets changed around. biggrin.gif
Maxjr is offline
post #5 of 23 Old 06-27-2012, 08:06 AM
tuxedocivic's Avatar
Quoted: 1907 Post(s)
Liked: 1726
The cheaper builds will use the 350 and the nicer builds the 360. Where that cut off is I don't know. But if you're extreme one way or the other you could pick which one.
Ryan
tuxedocivic is online now
post #6 of 23 Old 12-17-2012, 11:09 AM
dheflin83's Avatar
Even though the response curve between the DNA-360 and DE250 are almost identical, is the impedance curve between the two also closely matched if I'm trying to use an existing XO design for the DE250?
Darrell
dheflin83 is offline
post #7 of 23 Old 12-17-2012, 11:15 AM
Thatsnasty's Avatar
Quoted: 51 Post(s)
Liked: 42
Darrell
It's been confirmed you can swap the 360 for the DE250.
I currently use 3 360's in the 4PI's for LCR.
Thatsnasty is offline
post #8 of 23 Old 12-17-2012, 12:00 PM
mtg90's Avatar
Quoted: 413 Post(s)
Liked: 783
Here is the measured FR of both the 360 and 350 that I have:
mtg90 is online now
post #9 of 23 Old 12-17-2012, 01:48 PM
dheflin83's Avatar
Thanks Nasty, the 4PIs are just what I'm planning.
post #10 of 23 Old 12-17-2012, 02:28 PM
Thatsnasty's Avatar
Quoted: 51 Post(s)
Liked: 42
You won't be disappointed.
I just finished the center this weekend, and got a pair of JBL 8340's as surrounds for dirt cheap.
post #11 of 23 Old 12-17-2012, 02:57 PM
zheka's Avatar
Quoted: 29 Post(s)
Liked: 26
interesting. how do you interpret this? would you say the difference is insignificant if crossed over high enough?
zheka is offline
post #12 of 23 Old 12-17-2012, 05:37 PM
Erich H's Avatar
Quoted: 1406 Post(s)
Liked: 1771
If a design uses the DE250, the 360 could be dropped in. It might not have as good of a high end as the 360, but that shouldn't be a big deal.
A crossover built around the 360 was likely designed to take advantage of the extended high end, so the DE250 might not test as good in that speaker design. Or at least you wouldn't get the most out of the speaker.....unless you can't hear that high. smile.gif
Jeff Bagby has response and distortion tests for the 360 here (post 23 and 27):
http://techtalk.parts-express.com/showthread.php?235069-So-who-s-going-to-build-Jeff-Bagby-s-Definimax-12-SEOS-Econowave/page2
_______________________
The SEOS Waveguide Project
Erich H is offline
post #13 of 23 Old 12-17-2012, 08:41 PM
Max Phan's Avatar
Would you mind showing the FR on the 205 also?
Max Phan is offline
post #14 of 23 Old 12-17-2012, 11:22 PM
Erich H's Avatar
Liked: 1771
The 205 actually took longer to nail down than the 360. I had a diaphragm at the beginning that measured very good. It was more expensive but there was a bit of variation between each one. Here's that one in red and the DE10 in black, I believe on a SEOS-12:
After a good amount of testing and changes, I decided it made sense to go with the more consistent diaphragm to keep things pretty much identical between each unit. The new one ended up looking nearly identical to the DE10, except the 205 goes a bit lower (even lower than the example above). But it also has that similar dip around 2khz as you can see in the DE10 above. I think the measurement for the end product is on my laptop though, I'll have to find it. They sound really good and they're used in the Karma-10, Delta Pure, 8" B&C Minion, and the 8" model Jeff Bagby is currently working on.
Erich H is offline
post #15 of 23 Old 01-09-2013, 03:03 PM
Eyleron's Avatar
Quoted: 250 Post(s)
Liked: 142
What are the major differences between DNA-205 and DNA-350?
Distortion, crossover, and power handling, I imagine...but at what point would someone notice in the home?
SEOS Fusion 10 Max, 88 Special, Volt 10 LX, SVS PB10 and DIY SI18 subs, Denon X4000, JVC RS400 & 2.35:1 AT Screen
Eyleron is offline
post #16 of 23 Old 01-09-2013, 06:10 PM
Erich H's Avatar
Liked: 1771
Pretty much what you said. There probably wouldn't be much difference in a home. But there are benefits to lower crossover points that the designers would have to explain. I personally have the DNA-205 going in my living room and really like the way they sound.
Erich H is offline
post #17 of 23 Old 01-09-2013, 06:48 PM
Eyleron's Avatar
Quoted: 250 Post(s)
Liked: 142
I ordered the Fusion Max because I worried about second guessing the decision if I got the Karma (for the lower x-max, thinking "is there higher distortion with this model than the Delta-10A?"
My limited skills with WinISD seemed to show the woofer reaching x-max at low frequencies like 100hz so I worried about that.
Or with the Fusion Pure "will I regret the DNA-205, since that's lesser than the DNA-350, and at least with Selenium 220 people report harshness?" I couldn't find a DE10 vs DE-250 comparison. I probably shouldn't have suffered in silence and should've just asked. smile.gif
Mainly what I could find between AVS and DIYSoundGroup is you or Tux or someone saying about a lower crossover something like, "it brings it down in the range where the CD and horn are handling more of the sound, which usually does a better job, unless your CD runs out of steam."
Eyleron is offline
post #18 of 23 Old 01-11-2013, 06:54 AM
Martycool007's Avatar
Quoted: 280 Post(s)
Liked: 176
How did the B&C DE10 sound compared to the DNA-360 or DNA-350? Would the DE10 be better than the 360/350 if used as a tweeter only, crossing over to a dedicated mid-range driver? What about using the DE10 versus the 360/350 in a 2 way configuration? Just curious
Martycool007 is offline
post #19 of 23 Old 01-11-2013, 07:19 AM
Mike Garrett's Avatar
Quoted: 5568 Post(s)
Liked: 3550
The 8340's make a nice surround and the cabinets are decently constructed. I use a pair of them in my room. Mine were dirt cheap also. smile.gif
mjgarrett100@gmail.com
Mike Garrett is online now
post #20 of 23 Old 01-11-2013, 10:10 AM
Liked: 1726
When I say this, I'm talking about the DNA-205. I found the 205 to manage in a two way reaching down to 1450hz. If a lower sensitivity application, maybe even lower. So it can do a mid sized 2way. It measures wickedly smooth on the seos12. The 350/360 just have way more balls, and that matters. So depends where you're crossing. If like you say, to dedicated mids, I'd use the DNA-205 for sure.
Ryan
post #21 of 23 Old 01-12-2013, 12:13 AM
maxcooper's Avatar
Quoted: 13 Post(s)
I don't see the DNA-205 listed for individual purchase on the website -- is it available individually?
-Max
maxcooper is offline
post #22 of 23 Old 01-12-2013, 01:17 AM
Thatsnasty's Avatar
Quoted: 51 Post(s)
Liked: 42
Indeed they do! I remember you posted in my thread about patching the foam. I ended up going through with it and they're good as new.
I also followed your SEOS/TD12M build.
How are you enjoying them?
We have a similar setups.... it's always cool to hear what someone thinks.
vegasbaby likes this.
post #23 of 23 Old 07-13-2013, 03:54 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
Mfusick is offline
