AVS Forum | Home Theater Discussions And Reviews
AVS Forum | Home Theater Discussions And Reviews (http://www.avsforum.com/forum/)
-   DIY Speakers and Subs (http://www.avsforum.com/forum/155-diy-speakers-subs/)
-   -   6 DIY eD A7S-650 kits with FP14K clone (http://www.avsforum.com/forum/155-diy-speakers-subs/1417924-6-diy-ed-a7s-650-kits-fp14k-clone.html)
MKtheater 06-28-2012 02:49 PM
Hey guys,
So I put this system together basically because I got a great deal and Alex at eD had told me they deliver lower frequencies better than the 190v2's I had before. I just needed more of them for the midbass region. You know me, I could not say no so here I am. I still have to paint them but you all have seen my unfinished DIY subs before. At least these don't have sonotube written on the outside. biggrin.gif
Anyways, I wired them all as one sub going to my FP14K bridged. This is the first time I tried using multiple subs with one channel of amplification. I don't have to split the sub signal anymore at the output, yeah!
These are tiny little guys compared to everything else I have owned. I took some pics but the final pic was with my phone so I need to use my other camera so I will post new pics. I want to say that these are the first subs I did not need to run hot to feel the same effects as the DTS-10's. They actually feel stronger than the DTS-10's down low.
Here are some pics, I can't get my nearfield graph to load but I will try to resave it as a jpeg. It is a Mdat file some how.
I will do measurements and keep updating. I am getting two more DR speakers so the front stage will look just like my center channel with the subs on their sides going across the front. I am impressed with these little guys. Each sub weighs 200 pounds each!
Scott Simonian 06-28-2012 02:50 PM
135 Attachment(s)
Matman1970 06-28-2012 03:13 PM
James...your threads always deliver!!
Your going to have 6 DR200's for the front stage plus those subs?!?!
It must be some peace of mind to know if Motorhead or Metallica show up unexpectedly at your house and feel like plugging in, you'll be good to go.biggrin.gif
Mrkazador 06-28-2012 03:25 PM
40 Attachment(s)
gpmbc 06-28-2012 03:57 PM
qguy 06-28-2012 04:20 PM
What tire manufacturer did they order the edges from ?
edoggrc51 06-28-2012 04:27 PM
Very nice MK!!! I bet it sounds/feels incredible!
pokekevin 06-28-2012 04:30 PM
WHOA
and I thought 4 12s would be awesome haha
gpmbc 06-28-2012 04:49 PM
MK what's the back of the room lookin like these days-pic?
MKtheater 06-28-2012 05:07 PM
Just seats and bass traps like before. I have two wedge 8's in the corners. When I am finished I will have dual stacked arrays of DR-250's for my center and dual stacked DR-200's for the left and right with either the wedge 8's for surrounds or DR-250's.
carp 06-28-2012 05:08 PM
I've read that having more than 4 subs, unless co-located, don't add much to the spl. Obviously that isn't the case right? I guess they are kind of co-located though...
Looks awesome man, 200 pounds a piece? eD makes some serious enclosures, huh? eek.gifsmile.gif
So would you say this is the best the bass has ever sounded overall? I know you said the low end is amazing, just wondering if you feel there are any compromises whatsoever with this setup. What are the dimensions of the enclosures?
MKtheater 06-28-2012 05:18 PM
Each enclosure is 16x16x38. The drivers weigh 60 pounds each and the enclosure is 80 pounds. Very robust! This is the best system yet, due to the low end. I have not lacked in the Midbass since I went DIY and these are no different.
LTD02 06-28-2012 06:20 PM
which drivers have you got there?
qguy 06-28-2012 06:23 PM
How did you wire them ?, what was the resulting impedance with your wiring ?
Jay1 06-28-2012 06:39 PM
29 Attachment(s)
I'm guessing it's these
http://www.edesignaudio.com/product_info.php?cPath=1_21&products_id=554
LTD02 06-28-2012 07:12 PM
underhung 3" coil with 28mm xmax that will eat 1200 watts continuous?
interesting.
if the coil is 1 inch high, that means the gap is about 2 inches? something doesn't seem right with those specs.
Scott Simonian 06-28-2012 07:18 PM
135 Attachment(s)
John, I believe this driver tested by Josh has the same motor.
http://www.data-bass.com/data?page=driver&id=40
notnyt 06-28-2012 07:52 PM
222 Attachment(s)
interesting.
I don't think the specs are very accurate from my experience.
LTD02 06-28-2012 07:54 PM
the inductance in that one is a disaster scott. hopefully it is no where near as bad in the small drives.
Scott Simonian 06-28-2012 08:45 PM
135 Attachment(s)
Yeah. It's got quite a hump, eh. I don't know much about the intricacies of underhung drives but if the the power rating is accurate, it must be a rather wide gap and big, heavy coil. But...I'm just speculating.
gpmbc 06-28-2012 08:56 PM
So the million dollar question, if the driver specs bad (inductance hump) but graphs good, what does it sound like?
MKtheater 06-28-2012 09:39 PM
That is just it, deepest flattest graph ever, do the specs matter at all? You guys loved my 190v2 system but this one is suspect? I don't know but the low end has never been better than the Danley's. I boosted the CHT's and came close to the DTS-10's. These are stronger than the DTS-10's on the same scenes without boost!
Scott Simonian 06-28-2012 09:45 PM
135 Attachment(s)
Hey, I'm not knockin' your new gear. Just curious about the topology. Obviously the results are outstanding! smile.gif
MKtheater 06-28-2012 10:14 PM
I wish you guys could hear my room.
notnyt 06-28-2012 10:16 PM
222 Attachment(s)
Careful when you push these, they bottom out fairly easily and won't be too happy taking more than 600w or so for any duration. Otherwise, nice fr, would like to see how it looks when pushed.
Scott Simonian 06-28-2012 10:39 PM
135 Attachment(s)
Damn right! I've always wanted to come out there for a listen and hang out and stuff. smile.gif
MKtheater 06-28-2012 10:55 PM
My room is 2100 cubic feet, your room is 3-4 times the size. If I had your room I would use LMS5400's too. I will push them.
edoggrc51 06-29-2012 01:05 AM
+1!
desertdome 06-29-2012 08:17 AM
MKtheater, I can't believe you are going to get more DR-200's\DR-250's. Is Scott making them? He did a nice job on the Wedge 6's. I haven't installed the Wedge 6's yet, but I am listening to a pair on my office desk. My coworkers think I'm a little strange - especially when I say they are just little surround speakers. I guess everyone thinks Bose is the "correct" size for a speaker. rolleyes.gif
Originally Posted by edoggrc51 View Post
+1!
stormwind13 06-29-2012 08:28 AM
those look like 13av.2 's Wish I would have bought some when they were on sale for like 180ea
Powered by vBulletin® Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
