Plate amp speaker input impedance and running speakers and sub in parallel - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 06-29-2012, 11:53 AM - Thread Starter
cel4145's Avatar
Quoted: 2668 Post(s)
Liked: 3002
Not the normal type of question for this forum, but I knew that the people that know the most about plate amps hang out here smile.gif
Two questions:
1) What is the impedance of the speaker level inputs on a plate amp? Specifically the kind that doesn't have any pass through for speaker level output?
2) Is it reasonable to run a pair of 8 ohm speakers in parallel with the sub--connected by the speaker level inputs--of a 2 channel amp?
Sorry for the oddball question, but here's the situation. I have an old HK 35 AVR that all the DSP burned out. Only the front L/R are left, and it still sounds great with a pair of speakers in a budget computer 2.0 setup. The HK can run 4 ohms no problem.
I'd like to hook a sub up to it. But since the sub line out is gone on the receiver and there is on the L/R out, that limits my options to budget subs that have speaker inputs and outputs, which is very limiting on the choices. On the other hand, if I can hook a sub with speaker level inputs in parallel with the speakers, that opens up my options a lot.
I've seen this kind of problem pop up in other budget 2.1 setups.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | HE-400i | NAD HP50 | Sony MDR-1A | Soundmagic E50 & E80 | X5ii | DX50 | E12
cel4145 is offline
post #2 of 4 Old 06-29-2012, 01:43 PM
garciab's Avatar
Quoted: 151 Post(s)
Liked: 69
Yes, it is reasonable. It is typically a high-resistance, voltage divider network. Whether it has a pass-through is a matter of convenience, as the pass-throughs are usually equipped with a simple 6dB hp filter. I just looked at a Klipsch BASH amp schematic. It looks like the high level inputs will present roughly a 220ohm load. In the electronics world, any parallel, resistive load that is 10x higher can safely be ignored. Hope this helps.
bg
garciab is offline
post #3 of 4 Old 06-29-2012, 01:52 PM - Thread Starter
cel4145's Avatar
Liked: 3002
Cool. I was wondering if it would be that high. I wonder if the plate amps on all commercial subs are likely that high?
cel4145 is offline
post #4 of 4 Old 06-29-2012, 05:54 PM
garciab's Avatar
Quoted: 151 Post(s)
Liked: 69
I'd guess so, since most are expected to be run with front mains as well. I wouldn't think they'd include high-level inputs, if they didn't make sure it would not be a significant load on your amp or receiver.
bg
garciab is offline
