minidsp 2x4 question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 06-29-2012, 10:54 PM - Thread Starter
WagBoss's Avatar
Is there any difference between http://www.minidsp.com/products/minidspkits/2-x-in-4-x-out and http://www.minidsp.com/products/minidsp-in-a-box/minidsp-2x4 other than the cover? The kit one is $25.00 cheaper.
I am looking to use it for a DIY subwoofer, using it as a HPF and an equalizer.
WagBoss is offline
post #2 of 4 Old 06-30-2012, 06:26 AM
petew's Avatar
Quoted: 25 Post(s)
Liked: 68
The case is the only difference. The A and B versions are the same circuit board too. There's a jumper on the board to switch between A and B.
Building Bass - Subs
Surrounds - Easy as Pi
Storage - unRAID unDELL
Mains - Another piece of Pi
petew is offline
post #3 of 4 Old 06-30-2012, 10:26 AM - Thread Starter
WagBoss's Avatar
ok thank you. Do you know which plug-in package I would buy? I just want to take my LFE from my subwoofer and set a band pass filter from like 16 hz to 120 hz and also eq that range and output it to 1 channel.
WagBoss is offline
post #4 of 4 Old 07-01-2012, 07:56 AM
petew's Avatar
Quoted: 25 Post(s)
Liked: 68
Any of the advanced plug ins will work for 1 in 1 out. You need the advanced plug in to work with REW (IIRC)
I got the two way in case I ever decide to use the board for an active crossover project. Currently using it for four subs:
preamp sub out > splitter > two DSP inputs > four DSP outputs > four channel amp > subs
petew is offline
