Help me decide on the 15" woofers for my enclosures - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 07-02-2012, 02:38 AM - Thread Starter
omegaslast's Avatar
I bought some 21x21x25" enclosures (thanks to member forin)
Theyre dual opposed 15" enclosures. They should have approx 2.5 cu ft of space for each woofer after bracing and displacement of the woofer itself
I need some woofer suggestions.
>i already bought two alpine sws-15D2
T/S: http://support.alpine-usa.com/products/documents/OM_SWS-101215_D4_2.pdf
Their cone is cheap and overall feel is pretty cheap too... but they were $300 for the pair from an authorized dealer so i figured might as well give them a try.
>I am also looking at Sundown SA-15 D2
T/S: http://sundownaudio.com/index.php/products/subwoofers/item/sa-series.html?category_id=2
>The alpine SWR-1522D look nice except theyre ugly
t/s: http://www.alpine.de/fileadmin/user_upload/manuals/car_audio_manuals/SWR-1542D/OM_SWR-1542D_EN.pdf
>I have a chance to pick up two of these audiopulse 15"... i assume theyll work fine in 2.5cu ft?
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=293-622
Please ignore price for now, i guess what im most interested in is if you think ill run into any problems using any of these subs in 2.5cu ft, just so i know which ones NOT to buy.
omegaslast is offline
post #2 of 11 Old 07-02-2012, 02:44 AM
Bass Enabler
Scott Simonian's Avatar
Quoted: 5338 Post(s)
Liked: 4224
Dual Dayton DVC15's would work in that enclosure.
Scott Simonian is offline
post #3 of 11 Old 07-02-2012, 04:20 AM - Thread Starter
omegaslast's Avatar
post #4 of 11 Old 07-02-2012, 08:21 AM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 220
How much power are you going to be running? The Obsidian 15"s will work. They're only $160ea, and you can get them with D4 VC's.
http://obsidiancaraudio.com/index.php?id=6
Jay1 is offline
post #5 of 11 Old 07-02-2012, 09:35 AM
WiSounds's Avatar
Ricci has an SA15 that he is testing currently, results are coming. He said after the T/S spec run that it looked quite promising. If you aren't in a hurry, the results may help your decision.
I will say I beat the crap out of 4 SA12s, and they are really great performing.
Originally Posted by Bill Fitzmaurice:
It's also the very sort of Voodoo Engineering that should never be done.
WiSounds is offline
post #6 of 11 Old 07-03-2012, 12:50 PM - Thread Starter
omegaslast's Avatar
Do the obsidian work in 2.5 cuft of space? They're tempting. The sa15 looks super robust as well I trust them to be good drivers its just whatever driver does the best in a small enclosure. I just bought an ashly klr3200 and I have an nu3000. Guess I'm using that for power
post #7 of 11 Old 07-04-2012, 12:44 AM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 220
They model Qtc .793, F3 43hz.
Jay1 is offline
post #8 of 11 Old 07-04-2012, 09:05 AM
WiSounds's Avatar
The KLR3200 is a great amp.
WiSounds is offline
post #9 of 11 Old 07-04-2012, 12:19 PM
thucker's Avatar
Quoted: 65 Post(s)
Liked: 24
I ran an Alpine Type S subwoofer for a couple years back in the days. It sounded good in a sealed enclosure and never had any problems with it.
I sent you a PM in regards to the audiopulse. Good luck with your build.
thucker is online now
post #10 of 11 Old 08-24-2012, 01:48 PM
popalock's Avatar
Quoted: 1234 Post(s)
Liked: 1717
Dual Opposed LMS-R!
Not sure if 2.5^ft is enough for each though? mj, Scott, edogg...where you at!
popalock is offline
post #11 of 11 Old 08-24-2012, 02:58 PM
Bass Enabler
Liked: 4224
Dual LMS-R15 might work. In that size you'll get a sub .9Qtc system which isn't too bad. Most people won't go for it cuz it sounds high but it has perfect excursion control and you can put 4-5kw of power into the box with no issues. Now if they both could physically fit in there... probably. wink.gif
EDIT: G'damnit. Made a mistake and had selected four drivers in that space. Le sigh. I do make mistakes every once in a while. wink.gif
Sooo...two LMS-R15's model VERY well in that 5cuft size. A perfect .7Qtc so that's good, yes. 1,000w input per driver is a good optimal amount.
