Need help with some patchwork - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 07-02-2012, 08:49 PM - Thread Starter
wasteofmoney's Avatar
This subwoofer suffered some shipping damage on the top rear corner. A claim was filed, but I will be keeping the sub and get parially reimbursed by insurance. I'm no DIY, but just want to patch this up and paint it black so it blends in better. I was thinking maybe a black dyed polyester resin. 450
wasteofmoney is offline
post #2 of 4 Old 07-02-2012, 11:03 PM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 220
Really blurry pic. Sand it out so the edges of the damaged area are smooth. If it is MDF, you will then want to seal the grain, you can use resin like you said, but wood glue diluted with a little water works too. Then you will need to build the corner back up, bondo works very well for this. Apply bondo/sand/apply/sand until it's flush and level, then paint black.
Jay1 is offline
post #3 of 4 Old 07-03-2012, 10:48 PM - Thread Starter
Here is more 450450450450
post #4 of 4 Old 07-04-2012, 12:25 AM - Thread Starter
Thanks for the advice Jay
I'm not too worried about getting it back to it's original condition/color. As long as the MDF is sealed from decay and the edges are flush i'll be happy.
