Does ABS Glue ruin speakers? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 07-08-2012, 12:42 PM - Thread Starter
Subjga's Avatar
I'm using the glue to hook up the internal flared port past the fitted brace - must be done in-box.
Do you have to wait 24 hrs like you do with silicone?
Subjga is offline
post #2 of 2 Old 07-08-2012, 02:07 PM
Bill Fitzmaurice's Avatar
Liked: 5687
No, as it doesn't outgas over a number of hours like silicone does.
Bill Fitzmaurice is offline
